HELP! 3080 FTW3 RED LIGHTS
BudzCamacho
2022/10/04 03:23:30 (permalink)
My gpu is all working fine , but I have a static 4 RED LED on my cpu. RGB is not working but I tried plugging it on extra RGB and lit up but its red and I cant control it..
I have an 850w PSU
Using 3 separate 8 pins
gpu seated well and socket
I've also flashed the new bios . Switching bios dont work either
10 Replies Related Threads
    • Ribbons : 84
    Re: HELP! 3080 FTW3 RED LIGHTS 2022/10/04 03:39:28 (permalink)
    I'm a bit confused you say you have 4 red lights on the CPU. Do you mean 4 red lights on the GPU?
    Can you list your full system specs please?
    • Ribbons : 270
    Re: HELP! 3080 FTW3 RED LIGHTS 2022/10/04 04:45:55 (permalink)
    Assuming that you meant 4 red lights on the GPU, it's working fine, but the RGB isn't working, that all seems to indicate that the iCX MCU is stuck in flash update mode.
    I would contact EVGA.
    https://www.evga.com/support/custsupp.asp
    BudzCamacho
    Re: HELP! 3080 FTW3 RED LIGHTS 2022/10/04 12:41:32 (permalink)
    SOrry .. I meant GPU . typo my 3080 hybrid rgb just died and the 4 static red lights is now showing.. but the card is fully functional
    BudzCamacho
    Re: HELP! 3080 FTW3 RED LIGHTS 2022/10/04 13:15:26 (permalink)
    B550M Pro-P Gigabyte
    5900x
    3080 Hybrid FTW3 Ultra (10g-p5-3898-kr)
    850w Cougar ( using 3 8 pin PCIE)
    current bios   (94.02.42.80.FC)
    • Ribbons : 270
    Re: HELP! 3080 FTW3 RED LIGHTS 2022/10/04 14:34:10 (permalink)
    It sounds to me like the iCX MCU is stuck in flash mode. You should contact EVGA to discuss solutions.
    BudzCamacho
    Re: HELP! 3080 FTW3 RED LIGHTS 2022/10/04 15:44:01 (permalink)
    thank you . I will try to find a fix then contact them
    jonathan.schulberger
    Re: HELP! 3080 FTW3 RED LIGHTS 2022/10/06 22:55:16 (permalink)
    In case EVGA doesn't get back to you for whatever reason, google "3080 ftw3 v1 px1 firmware update bricked my led" and take a look at the reddit thread. The dropbox link has firmware files and a flashing tool. You'll definitely want to look at github for the flashing tool instead of the dropbox link, but maybe the firmware files inside could help you.
    I would have sent a PM with links like you requested, but my account is too new and I figured this was the best alternative.
    BudzCamacho
    Re: HELP! 3080 FTW3 RED LIGHTS 2022/10/06 23:59:57 (permalink)
    you can email me  I've been waiting for them to reply .
    BudzCamacho
    Re: HELP! 3080 FTW3 RED LIGHTS 2022/10/07 00:02:08 (permalink)
    post edited by BudzCamacho - 2022/10/09 23:13:46
    Lonestar_1982
    Re: HELP! 3080 FTW3 RED LIGHTS 2022/10/20 12:10:54 (permalink)
    Do you have a link for it so I view it
