EVGATech_JoseR
Hello there!
To my knowledge we have not made any changes to the hadron cases or the internal components. For the fan settings in BIOS you have to go to Advanced > HW Monitor Configuration to adjust the fan mode for all available headers but only Cha_Fan and CPU fan support SMART all others can only be set to Max and set to a certain speed percentage.
Did your case not come with a CD/DVD optical drive?
No, it did not come with the DVD drive slot. Not that I mind really as I use an external one in the rare cases I need to read a disc, but still odd.
I did went to
Advanced > HW Monitor Configuration but there is just no option for the
CHA_FAN to set it to smart, the only options available by changing the minus/plus buttons are:
- OFF
- Range of 1% to 99%
- MAX (current setting)
The other fans can be setup though, if you notice there is a blueish background on the
CPU1_FAN and
CPU2_FAN settings which allows me to click on either and set the levels, however, in the
CHA_FAN there is no additional options. I attached a picture displaying that on my first post. What caught my attention is that if I do select the
CHA_FAN option the right sidebar states:
CHA_FAN:Enter a value of 0-100 and the fan will run at that percent of its capacity, this is also refered to as DC/PWM Mode.Smart fan will auto adjust based off of heat.Default is Smart Fan, as that is the balance between cool and quite.So it states that Smart Fan should be supported by the configuration, yet I don't see that option. I would think it has to do with the coolers in the case maybe?
Attaching also a pic of the side of the case without the drive slot (sorry for the dusty front):
