VegetaCreeper
- Ribbons : 9
Re: Founders Edition Plastic Window Removal Question about Temps
2018/02/16 13:25:33
now that the plastic is removed, my GPU clocks consistently stay boosted to 1947 with tolerable fan acoustics/low temps =)
Be The change in the World you want to seeUse my associate code if you want to save money on your purchases : DIC39SVDZOR8D11
evgapcbuilds
2018/02/17 19:23:19
Very interesting I wonder why they have the plastic if its so bad
VegetaCreeper
- Ribbons : 9
2018/02/18 22:24:43
evgapcbuilds Very interesting I wonder why they have the plastic if its so bad
It protects the heatfins. Also, the card is designed to blow all heat out the rear of the case. Doing it this way dumps some heat into your case. If you have even decent case cooling, then this is definitely a great option
squall-leonhart
- Ribbons : 24
2018/02/22 05:32:21
It made a difference because of the mounting of the GPU in this set up with the card standing on a riser, heat is trapped in the top of the shroud and dragged into the fan before being thrown back at the heatsink. taking the plastic piece out allows cooler air to be drawn into the top of the shroud and displace the hot air as it is pulled in. With it mounted normally in a mainboard pci-e slot, the hot air doesn't accumulate, it spreads across the width of the board and is pushed out with air drawn into the fan from below.
post edited by squall-leonhart - 2018/02/22 07:32:53
CPU:Intel Xeon x5690 @ 4.2Ghz, Mainboard:Asus Rampage III Extreme, Memory:48GB Corsair Vengeance LP 1600 Video:EVGA Geforce GTX 1080 Founders Edition, NVidia Geforce GTX 1060 Founders Edition Monitor:BenQ G2400WD, BenQ BL2211, Sound:Creative XFI Titanium Fatal1ty Pro SDD:Crucial MX300 275, Crucial MX300 525, Crucial MX300 1000 HDD:500GB Spinpoint F3, 1TB WD Black, 2TB WD Red, 1TB WD Black Case:NZXT Phantom 820, PSU:Seasonic X-850, OS:Windows 7 SP1 Cooler: ThermalRight Silver Arrow IB-E Extreme
transdogmifier
- Ribbons : 17
2018/02/22 07:27:23
Dunno why people think HH is angry...I read it as he doesn't understand (or believe) and is asking for clarification so that he can reconcile the information..
At any rate...nice vid...if I ever get a new machine and a FE 1080 I'll have to try it.
chrisdglong
- Ribbons : 7
2018/02/22 09:09:18
VegetaCreeper
Why not just buy a FTW? OR, other custom fan solution? I see you have the FE, did they not have ICX cards when you got yours?
repo1979
2018/02/22 09:14:54
chrisdglong
VegetaCreeper
He got it on a great price and he likes the way it looks
VegetaCreeper
- Ribbons : 9
2018/02/22 11:01:54
repo1979
chrisdglong
VegetaCreeper
With the plastic window off, it really looks super awesome (IMO).
Vexidius
2018/07/19 03:14:34
Sorry to dredge up old posts, but this is literally the only post of its kind I could find. Did anyone ever test the 1080 ti FE in the PCI slot, and not on the Riser? I would imagine nothing but positives from opening the card, but I can certainly imagine the riser helping more with the window open than the PCI slot position.
cwarren77
2019/01/20 21:19:31
Vexidius Sorry to dredge up old posts, but this is literally the only post of its kind I could find. Did anyone ever test the 1080 ti FE in the PCI slot, and not on the Riser? I would imagine nothing but positives from opening the card, but I can certainly imagine the riser helping more with the window open than the PCI slot position.
I just did it. I was getting, prior to performing this "mod", temps of 85-89c w/ the fan almost at 70% and performance was suffering due to temp throttling. For example in Black Ops 4 Multiplayer I was barely pushing 60-70 FPS. In prep I took the shroud off, removed the heatsink, and replaced the thermalpaste with some Noctua NT-H1. I then replaced everything, including the window and tested. Same frames and temps were holding at 85C I then removed the plastic window and the difference was mind blowing. I still can't believe it worked this well. I'm now pushing 140+ FPS in Black Ops 4 and temps max out at 57C. I run the settings @ Max in game (only 1920x1080 144hz). GTX 1080 Ti is now running custom fan curve that will max at 55% and the Power is set to 110% in MSI Afterburner w/ no OC. I let boost do all the work. - My specs on userbenchmark.com : https://www.userbenchmark.com/UserRun/14007340 I'll post a 3DMark Run in Firestrike soon.
