Good Fan Hub for PWM
warcobra
2018/08/31 17:06:03 (permalink)
Like the title I need a PWM Fan hub that can run off a mother board Header and have the ability to run at least 10 Fans per hub. I know of some that exist but I want to know what others ave experienced.  I have currently NZXT Grid+ V3 and to be honest it is the biggest pile of crap I have ever experienced so I have wasted my money on some of them and have no interest in wasting my time on that brand anymore. Thanks in advance.
:TR 3960x
:Custom Water Loop
:ASUS Zenith II Extreme Alpha
:Corsair Dominator Platinum RGB 64gb DDR4 @ 3200mhz
:WD 2TB / Samsung 850 Pro 512GB
:Samsung 970 Evo 2TB NVME
:EVGA RTX 3080 12gb FTW3 Hydro Copper 2115mhz
:EVGA RTX 2080 Super Hydro Copper 2145mhz
:EVGA GTX Titan X Hydro Copper SLI 1500/8000
:EVGA 1600T2
:Custom Desk   https://www.modsrigs.com/detail.aspx?BuildID=39791
:36x Corsair SP120 High Performance Fans
http://www.heatware.com/eval.php?id=102641
9 Replies Related Threads
    • Ribbons : 122
    Re: Good Fan Hub for PWM 2018/08/31 18:04:14 (permalink)
    What I use does only eight fans (unless you use 2 to 1 cable)
    • 1-to-8 PWM connectors
    • 2200μF capacitor provides stable voltage
    • Support speed detection for accurately controlling fans
      SATA powered
      only $14
      Great Low profile Design, fans connect horizontal through the sides
      Silverstone PWM Fan Hub System CPF04
    warcobra
    Re: Good Fan Hub for PWM 2018/08/31 18:25:22 (permalink)
    Ok thanks I am just trying to fin my Desk pc and this fan hub stuff from nzxt is killing me right now.
    :TR 3960x
    :Custom Water Loop
    :EVGA 1600T2
    Nereus
    Captain Goodvibes
    • Ribbons : 58
    Re: Good Fan Hub for PWM 2018/09/02 22:58:47 (permalink)
    Can you run that many fans from a single motherboard fan header? There's a limit on amps supplied through there - not sure what the limit is, but I'd hate to see you melt the header down to slag. You might be better to run a fan controller straight from a SATA/molex plug with a controller mounted in one of the bays.
      BUILD 1 2   |   MINI-ITX BUILD   |   MODSRIGS $1K WIN   |   HEATWARE 111-0-0   |   ASSOCIATE CODE CSKKXUT5Q9GVAFR
    • Ribbons : 270
    Re: Good Fan Hub for PWM 2018/09/03 01:43:50 (permalink)
    Yes.
    The PWM output can "run" nearly an infinite number of fans since the PWM signal is high impedance and transfers near zero current flow. The trick is, these "hubs" just properly route the PWM signal and one RPM feedback signal to the motherboard, while the higher current required for the fan operation comes from the hub straight from the power supply, instead of the motherboard fan header.
    The thing is, if you want to power a lot of fans, you will need to find a special jumbo hub with multiple power supply power inputs, or wire multiple hubs in series (if the product supports it), or just wire up the circuit yourself. The electrical circuit is dead simple and if you have soldering and shrink wrapping skills, you should probably just make the splitters yourself and not even think about spending your money on a fancy looking hub which is merely a plastic enclosure around a handful of electrical traces with not a single electrical chip or any additional fanciness.
    Argh. Typed out the circuit construction and then the connection was lost. Oh well. Just google. The capacitor is unnecessary and is just a marketing thing to make the hub seem more complicated. None of your other computer fans are connected to capacitors.
    post edited by ty_ger07 - 2018/09/03 08:02:20
    Nereus
    Captain Goodvibes
    • Ribbons : 58
    Re: Good Fan Hub for PWM 2018/09/03 14:18:29 (permalink)
    Ahh of course, the power supply is separate, the motherboard header is just for the PWM control. lol, I need to get more sleep. Thanks. :)
    • Ribbons : 122
    Re: Good Fan Hub for PWM 2018/09/03 15:35:15 (permalink)
    Nereus
    Or just drink more Coffee maybe Espresso
    Nereus
    Captain Goodvibes
    • Ribbons : 58
    Re: Good Fan Hub for PWM 2018/09/03 15:38:43 (permalink)
    Nereus
    Already working on it.
    warcobra
    Re: Good Fan Hub for PWM 2018/09/03 19:45:51 (permalink)
    Yea I am going with the silverstone. It just grabs the pwm signal and is powered by sata power. My fan's at max will pull 3 Watt's per fan. I will only have them pulling .5 to 1 watt. Yea My biggest issue is the custom desk pc has 32 fans. So I am making sure it all works perfect. I already have 18 of them controlled. So 14 fan's left to split between 3 silverstone fan hubs. plenty of pwm fan connects left on both mother boards to control them.
    :TR 3960x
    :Custom Water Loop
    :EVGA 1600T2
    Nereus
    Captain Goodvibes
    • Ribbons : 58
    Re: Good Fan Hub for PWM 2018/09/03 19:55:06 (permalink)
    warcobra
    32 fans?   ..does it double as a drone? You'll have to post this build on ModsRigs when you're done! - EDIT - I see you've already started a thread on it.
