Gold Vs Platinum Wall Power Draw
ssj92
2021/07/26 21:00:44 (permalink)
Hi everyone, I am trying to figure out how much of a difference I should expect from a power supply that is gold vs platinum.
For this example I will use 1300 G+ vs 1300 P+
Does it mean there's only around 2% efficiency difference between the two and wall power draw would be only 2% less between the two (assuming all same components/load)?
Alienware Area-51M Laptop: Intel Core i9-9900K @ 5.3Ghz | 64GB Ram | nVidia GeForce RTX 2080 | 1080p @ 144Hz | 1TB 970 Evo Plus | AX200
CS Server: Intel Core i9 10980XE | 32GB RAM | nVidia GeForce RTX 3090 + TITAN V| EVGA X299 Micro | EVGA SuperNova 1000 G5 | 1TB SK Hynix NVMe | 2x 8TB WD Red
3 Replies Related Threads
    • Ribbons : 119
    Re: Gold Vs Platinum Wall Power Draw 2021/07/26 22:44:21 (permalink)
    RTX Project EVGA X99 FTWK 2xEVGA2080Ti EVGA1200P2  Nibbler EVGA X99 Classified 3-GPU Water cooled 1600P2 AIO Folding  X99 2x1080Ti FTW3 Hybrid, 1200P
    Thank You for Your Support      I'm a Volunteer Moderator on the EVGA Forums ... Not an EVGA employee
    ssj92
    Re: Gold Vs Platinum Wall Power Draw 2021/07/27 11:03:54 (permalink)
    So from what I gather it sounds exactly like what I was thinking...
    A full load on a
    1300 P+ consumes 1443W
    1300 G+ consumes 1469W
    difference of 26w.
    50% load [650w] would be
    1300 P+ consuming 702W
    1300 G+ consuming 715W
    Difference of 13w.
    Idk difference of $90 price seems a lot for that difference of power consumption. I always thought the difference was greater.
    EVGATech_LeeM
    • Ribbons : 14
    Re: Gold Vs Platinum Wall Power Draw 2021/07/27 12:29:57 (permalink)
    If your only focus is on efficiency, then you are correct about the relatively close difference in efficiency.  The other differences, however, have to do with the ability of platinum or titanium models essentially doing the same as each level below it more efficiently, while also generating less heat, which also means less noise.  In some cases or applications, the heat and noise is very important.
    You're not wrong if you're thinking that gold is already a great option.  The whole point of the 80PLUS system is geared towards driving more people to buy efficient power supplies, but you don't have to buy necessarily the most efficient power supply to have a very efficient power supply.
