ArgH_216
Re: GeForce RTX 3090 XC3 ULTRA - Clocks Throttle Reasons: nvidia-smi SW Power Cap Active
2021/02/22 07:38:12
Sorry - Linux workstation here - for GPU-Z I'll have to do a Windows install. Temps: RTX 3090 around 60 under load, with spikes up to 65C (=> over 60C the fans seem to ramp up the rpm, pushing the temps down again) CPU around 75C (AIO) when doing mersenne prime, otherwise around 40-50 (governor: ondemand) Specs: AMD Ryzen 3900X / 64GB RAM MB Asrock Taichi X570 2 x HDD 4TB (SW RAID1) with one 500GB NVME drive configured as cache No overclocking. ***update*** Did put both cards in my system and did some logging: nvidia-smi --query-gpu=name,temperature.gpu,fan.speed,pstate,power.draw,temperature.memory,clocks.current.graphics,clocks.current.memory,clocks.current.sm,clocks.current.video,clocks_throttle_reasons.active --format=csv -l 5GeForce RTX 3070, 65, 35 %, P2, 197.63 W, N/A, 1950 MHz, 6800 MHz, 1950 MHz, 1710 MHz, 0x0000000000000000GeForce RTX 3090, 65, 53 %, P2, 288.92 W, N/A, 1560 MHz, 9501 MHz, 1575 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 66, 38 %, P2, 198.78 W, N/A, 1950 MHz, 6800 MHz, 1950 MHz, 1710 MHz, 0x0000000000000000GeForce RTX 3090, 64, 54 %, P2, 292.67 W, N/A, 1365 MHz, 9501 MHz, 1365 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 67, 41 %, P2, 199.59 W, N/A, 1950 MHz, 6800 MHz, 1950 MHz, 1710 MHz, 0x0000000000000000GeForce RTX 3090, 64, 54 %, P2, 293.11 W, N/A, 1230 MHz, 9501 MHz, 1230 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 68, 43 %, P2, 200.23 W, N/A, 1935 MHz, 6800 MHz, 1935 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 65, 54 %, P2, 293.57 W, N/A, 1320 MHz, 9501 MHz, 1320 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 69, 45 %, P2, 201.12 W, N/A, 1935 MHz, 6800 MHz, 1935 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 65, 54 %, P2, 290.16 W, N/A, 1575 MHz, 9501 MHz, 1575 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 70, 47 %, P2, 201.88 W, N/A, 1935 MHz, 6800 MHz, 1935 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 65, 54 %, P2, 289.66 W, N/A, 1530 MHz, 9501 MHz, 1530 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 70, 49 %, P2, 202.19 W, N/A, 1935 MHz, 6800 MHz, 1935 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 65, 54 %, P2, 291.50 W, N/A, 1215 MHz, 9501 MHz, 1215 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 70, 50 %, P2, 202.74 W, N/A, 1935 MHz, 6800 MHz, 1935 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 65, 55 %, P2, 292.28 W, N/A, 960 MHz, 9501 MHz, 975 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 71, 51 %, P2, 203.37 W, N/A, 1935 MHz, 6800 MHz, 1935 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 65, 55 %, P2, 291.48 W, N/A, 1215 MHz, 9501 MHz, 1215 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 71, 52 %, P2, 203.91 W, N/A, 1935 MHz, 6800 MHz, 1935 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 65, 55 %, P2, 288.55 W, N/A, 1560 MHz, 9501 MHz, 1560 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 72, 53 %, P2, 204.55 W, N/A, 1935 MHz, 6800 MHz, 1935 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 65, 55 %, P2, 289.43 W, N/A, 1455 MHz, 9501 MHz, 1455 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 72, 54 %, P2, 204.60 W, N/A, 1935 MHz, 6800 MHz, 1935 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 65, 55 %, P2, 291.12 W, N/A, 975 MHz, 9501 MHz, 975 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 72, 55 %, P2, 204.93 W, N/A, 1935 MHz, 6800 MHz, 1935 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 65, 55 %, P2, 290.73 W, N/A, 1320 MHz, 9501 MHz, 1320 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 72, 55 %, P2, 205.35 W, N/A, 1935 MHz, 6800 MHz, 1935 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 65, 55 %, P2, 288.45 W, N/A, 1560 MHz, 9501 MHz, 1560 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 72, 56 %, P2, 205.33 W, N/A, 1935 MHz, 6800 MHz, 1935 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 65, 55 %, P2, 287.37 W, N/A, 1485 MHz, 9501 MHz, 1485 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 72, 56 %, P2, 205.81 W, N/A, 1935 MHz, 6800 MHz, 1935 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 65, 55 %, P2, 290.70 W, N/A, 1305 MHz, 9501 MHz, 1305 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 73, 56 %, P2, 205.72 W, N/A, 1935 MHz, 6800 MHz, 1935 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 65, 56 %, P2, 291.12 W, N/A, 990 MHz, 9501 MHz, 990 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 73, 57 %, P2, 205.68 W, N/A, 1935 MHz, 6800 MHz, 1935 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 65, 57 %, P2, 288.17 W, N/A, 1470 MHz, 9501 MHz, 1470 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 73, 57 %, P2, 205.73 W, N/A, 1935 MHz, 6800 MHz, 1935 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 64, 59 %, P2, 287.77 W, N/A, 1470 MHz, 9501 MHz, 1470 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 73, 58 %, P2, 206.02 W, N/A, 1935 MHz, 6800 MHz, 1935 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 64, 60 %, P2, 290.40 W, N/A, 1155 MHz, 9501 MHz, 1185 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 73, 58 %, P2, 206.25 W, N/A, 1920 MHz, 6800 MHz, 1920 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 64, 61 %, P2, 291.81 W, N/A, 975 MHz, 9501 MHz, 975 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 73, 58 %, P2, 206.14 W, N/A, 1920 MHz, 6800 MHz, 1920 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 64, 62 %, P2, 291.00 W, N/A, 1485 MHz, 9501 MHz, 1485 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 73, 58 %, P2, 206.40 W, N/A, 1920 MHz, 6800 MHz, 1920 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 63, 63 %, P2, 288.01 W, N/A, 1560 MHz, 9501 MHz, 1560 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 73, 59 %, P2, 206.61 W, N/A, 1920 MHz, 6800 MHz, 1920 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 62, 64 %, P2, 291.35 W, N/A, 1185 MHz, 9501 MHz, 1185 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 73, 59 %, P2, 206.85 W, N/A, 1920 MHz, 6800 MHz, 1920 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 62, 65 %, P2, 292.17 W, N/A, 1305 MHz, 9501 MHz, 1305 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 74, 60 %, P2, 206.70 W, N/A, 1920 MHz, 6800 MHz, 1920 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 62, 66 %, P2, 291.63 W, N/A, 1470 MHz, 9501 MHz, 1470 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 73, 60 %, P2, 206.71 W, N/A, 1920 MHz, 6800 MHz, 1920 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 61, 67 %, P2, 290.00 W, N/A, 1575 MHz, 9501 MHz, 1575 MHz, 1395 MHz, 0x0000000000000004GeForce RTX 3070, 74, 60 %, P2, 206.74 W, N/A, 1920 MHz, 6800 MHz, 1920 MHz, 1695 MHz, 0x0000000000000000GeForce RTX 3090, 61, 67 %, P2, 290.36 W, N/A, 1590 MHz, 9501 MHz, 1590 MHz, 1395 MHz, 0x0000000000000004
post edited by ArgH_216 - 2021/02/22 08:46:47
