GTX1070 must have EVGA Precision running in order for fans to run...
sasuke781
2022/05/14 20:45:10 (permalink)
Pretty much like the title states....Precision must be running or my fans dont come on and the card runs a little warmer than need be.
5 Replies Related Threads
    loveha
    • Ribbons : 65
    Re: GTX1070 must have EVGA Precision running in order for fans to run... 2022/05/14 23:23:32 (permalink)
    Some cards don't run the fans till temps hit a predetermined temp. With Precision running, and fans set to auto, do the fans spin?
    Case - Phanteks Enthoo Evolv X
    Mobo - EVGA X570 FTW
    CPU - AMD Ryzen 9 5900X @ 4.8GHz 1.375V
    RAM - 32GB Trident Z Royal 3600MHz 14-14-14-34
    GPU - EVGA RTX 3080 Ti FTW3 Ultra Gaming
    PSU - Seasonic Prime TX-1000
    Heatkiller IV CPU Waterblock / Heatkiller V GPU Waterblock
    Heatkiller V EBC Active Backplate / Heatkiller Rad 360 L & S
    Noctua NF-A12x25 & NF-A12x15 / Heatkiller Eheim Pump
    sasuke781
    Re: GTX1070 must have EVGA Precision running in order for fans to run... 2022/05/15 18:47:11 (permalink)
    Yea I get that, but usually it would hit some higher temps, in the 50C region, before turning the fans on and I see no point for the card to idle at that. I've seen thats normal idle as it shuts off the fans for noise, but I dont even hear it with the fans running as is.
    so...basically this is normal and what I'm doing is abnormal...I keep it around 30C at idle and low MHz
    BiggyNewton
    Re: GTX1070 must have EVGA Precision running in order for fans to run... 2022/05/17 08:45:09 (permalink)
    Set up a custom fan curve so they never shut off.
    Associate code: EKA5I8R4C7M401L
    Thanks to anyone using my code!
    • Ribbons : 245
    Re: GTX1070 must have EVGA Precision running in order for fans to run... 2022/05/17 12:12:30 (permalink)
    BiggyNewton
    For that, they would use Precision. Which is why they made post #1.
    • Ribbons : 120
    Re: GTX1070 must have EVGA Precision running in order for fans to run... 2022/06/03 08:48:26 (permalink)
    check the version of BIOS on your card
     (same as link below) https://forums.evga.com/FindPost/2573491
    EVGA GeForce GTX 1080/1070/1060 BIOS Update
    Updates:
    • Updated fan curve for reduced PWM temperature
    Learn your way around the EVGA Forums, Rules & limits on new accounts Ultimate Self-Starter Thread For New MembersThank you for your support - I am a Volunteer Moderator not an EVGA employee RTX Project EVGA X99 FTWK 2xEVGA2080Ti EVGA1200P2  Nibbler EVGA X99 Classified EVGA 3080Ti FTW3 Ultra 1600P2
