ivan.kalashnjuk
Hi there. I want to know whether my graphic card definitely artifacts. So, while playing Battlefield 3 Kafarov mission, I saw some problems with graphic drawing - https://www.youtube.com/watch?v=FoS74d0FjyE I hope you will support me and let me know everything in relation to the situation. Thanks a lot in advance!
arestavo
- Ribbons : 76
Re: GTX 980ti ACX 2.0 is it artifacting? Help me to understand it. Problem with Battlefiel
2017/07/23 13:53:47
Does it only happen in BF3? Does it only happen in that area? If either of those answers is a "yes" then it is very likely a game issue. If no for both, then there's a chance that the video cable is the culprit - try changing it out with a different cable. Or even try a different monitor/cable if that is an option. If that's not an option, try using an older version of Nvidia drivers (or newer if you are using an old version) - use step 2 to clean install the driver(s) that you choose: https://forums.evga.com/Basic-troubleshooting-steps-Windows-clean-boot-clean-driver-install-debug-mode-etc-m2451023.aspx
ivan.kalashnjuk
2017/07/23 14:03:34
arestavo Does it only happen in BF3? Does it only happen in that area? If either of those answers is a "yes" then it is very likely a game issue. If no for both, then there's a chance that the video cable is the culprit - try changing it out with a different cable. Or even try a different monitor/cable if that is an option. If that's not an option, try using an older version of Nvidia drivers (or newer if you are using an old version) - use step 2 to clean install the driver(s) that you choose:
Actually speaking, something like that once happened in CS GO.
arestavo
- Ribbons : 76
2017/07/23 17:49:47
ivan.kalashnjuk
Not repeatable?
JosephL
2017/07/23 18:05:48
Download a program called Display Driver Uninstaller, you can find it HERE. Before you run DDU, download the latest driver version from our website HERE and save the file on your computer. Install and run the Display Driver Uninstaller program and this usually fixes any driver related errors. If that does not fix the issue it does seem to be a game related issue as it is occurring at the same spot and same game. You may try reinstalling the game as well or searching for similar issues with others in the same location in-game.
ivan.kalashnjuk
2017/07/24 00:19:12
EVGATech_JosephL Download a program called Display Driver Uninstaller, you can find it . Before you run DDU, download the latest driver version from our website and save the file on your computer. Install and run the Display Driver Uninstaller program and this usually fixes any driver related errors. If that does not fix the issue it does seem to be a game related issue as it is occurring at the same spot and same game. You may try reinstalling the game as well or searching for similar issues with others in the same location in-game.
Already done it, all the same. I installed another repack and the same situation. How to exclude a problem with the GPU?
Stardust_One
2017/07/24 03:56:17
Did you oc'd the card? If you have that, go back to the stock-settings.
ivan.kalashnjuk
2017/07/24 04:11:40
Carbonshape Did you oc'd the card? If you have that, go back to the stock-settings.
No, it works with stock-settings. Guys, GPU does not already display anything.... I even do not know what to do... Already written to EVGA support.
Stardust_One
2017/07/24 05:08:48
ivan.kalashnjuk
2017/07/24 05:23:38
Carbonshape It's gone dark?
Hah I've already fixed it. VGA cable was not connected enough into the monitor socket. However what about these stripes, appearing in Battlefield 3 only while this scene? Is it hardware or software problem? Yet, I would be honoured to know how to exclude a problem with GPU.
Stardust_One
2017/07/24 05:39:34
Hah I think your good with that - a gpu-cable can cause this issues. You should observe it a little more.
ivan.kalashnjuk
2017/07/24 05:56:31
Carbonshape Hah I think your good with that - a gpu-cable can cause this issues. You should observe it a little more.
Actually speaking I don't think it could cause this problem. Once I have a possible to check it one more time, I will and tell you.
fearpoint
2017/07/24 11:52:46
☼ Best Answerby ivan.kalashnjuk 2017/07/25 15:20:51
Game issue. You can repeat the issue which means some change newer drivers or an error in the game itself results in the rendering issue.
ivan.kalashnjuk
2017/07/25 15:22:20
It seems like it is actually game issue. Thanks a lot those who paid themselves attention to my post.
SystemsOgreLoad
2017/07/26 10:50:47
ivan.kalashnjuk It seems like it is actually game issue. Thanks a lot those who paid themselves attention to my post.
Glad to hear it's fixed!
