GTX 980 Ti fan speed question
MystikalFrank
2017/04/29 15:56:35 (permalink)
I have a GTX 980 Ti, both my Corsair LINK and the EVGA PrecisionX OC software are reporting high temps (90 C) while idling and fans are showing 0rpm - 250rpm sporadically.
Thanks
3 Replies Related Threads
    Tech_RayH
    • Ribbons : 7
    Re: GTX 980 Ti fan speed question 2017/04/29 16:07:28 (permalink)
    Welcome to the Forums. That is much hotter than the card should be running. Does Precision X OC let you control the fans manually?
    ...an untrammeled flow of words in an open forum.
    - Adlai E. Stevenson
    MystikalFrank
    Re: GTX 980 Ti fan speed question 2017/04/29 16:20:29 (permalink)
    It seems like it should.  On the right hand side - I can turn off Auto and keep the slider all the way at the top and there is still no change.  If I adjust the curve based on temperature to create a custom profile, there is also no change.
    Re: GTX 980 Ti fan speed question 2017/05/02 06:41:52 (permalink)
    Uninstall both corsair link & precision. Reboot PC. Reinstall precision. Can you adjust the fan speed now?
