fadsarmy
Hello, My GTX 970 has been making an irritating chirping noise at idle since day one. It doesn't happen all the time. Initially, I thought it was coil whine. I just discovered that it happens when the fan is attempting to move at idle. Please see video of fan attempting to move. Is this normal?
Re: GTX 970 Fan Attempting to Turn at Idle and Making Chirping Noise
2018/04/14 14:27:54
Didn't hear any chirping. It's normal for the fans to move like that.
Dr.Death
- Ribbons : 9
2018/04/14 17:09:04
maybe something in the fans PCB that controls that [fans speeds ] I replace a few GPU fans for what ever reason and its been in the fan and to add they been power logic fans at that.. seems like power logic is what EVGA uses .. you couls try a gpu fan to test with or like you say when the -0- fan deal is activating or trying to just set up a custom fan profile with some fan software [look up how to's ] and set the fan to run full time or at idle at say like 20% speed a lot of guys never liked the -0- fan option of these later cards and just did that now if it chirps when running maybe a dry bearing ? look up how to lube case fans and give that a try maybe the chirp is so minor like sajin said he did not hear it and your cards not over heating and the fans do spin up as temps rises just grin and bare it . evga don't offer replacement fans and the evga fans on e-bat are not so cheap as fans go [wonder why ? ] last card I just pulled a fan from a hd 6850 [ non power logic] and scabbed it in where a junk power logic was . had to use super glue in place of screws and the 6850 fan was a tad smaller size but the card work fine and dandy and runs and cools as normal and expected to this day , and you'd never know it was swapped out unless you took it apart to see or see if its a issue to you if evga will RMA ?
fadsarmy
2018/04/15 02:30:27
I don't know why my phone mic won't pick up the chirp but it's definitely present when the fan attempts to turn. Is there a bios to get rid of the zero fan mode as my 970 doesn't have a switch?
Dr.Death
- Ribbons : 9
2018/04/15 04:44:05
don't know ? the twitching seems normal in that -0- fan mode . lots of posts on that in forums around asking this [any brand ] . some say theres twitches some say theres don't , but the cards cool normal and fans do speed up when the temp threshold is reached . [60c +/- ] . https://forums.evga.com/ACX-2-fans-39wiggling39-every-10-seconds-or-so-m2279719.aspx https://forums.evga.com/GTX-980-ACX-Fans-Twitching-m2325162.aspx now the chirp ? hard to say with out hands on right there . maybe something in the fan motor ele. or mech. that causes the twitching in some cards and not others and yours adds the chirp ? these fans are serviceable I looked at my powerlogic fand from cards and there is lube hole in to oil the brg. easy / no plug but some kinda tape covering the hole ? maybe to prevent you from getting oil on the fans PCB that is what controls the fans action from the cards sensors . most folk tend to blame the card at fault 99% of the time its in the fan electronics and most times just needs a good known working fan in replacement not replace the card heres a powerlogic fan with a look under the sticker . bearing under the black tape cover thing and some of the exposed PCB of the fan no bios switch then like I say do / try a custom fan curve profile . [example] https://forums.evga.com/What-should-my-GPU-fan-settings-be-for-my-new-EVGA-Gtx-970-ACX-20-m2451866.aspx
post edited by Dr.Death - 2018/04/15 05:11:02
2018/04/15 12:05:16
fadsarmy I don't know why my phone mic won't pick up the chirp but it's definitely present when the fan attempts to turn. Is there a bios to get rid of the zero fan mode as my 970 doesn't have a switch?
I'll upload a modified vbios that has 0db mode disabled for ya if you tell me what the part # of your card is.
fadsarmy
2018/04/15 13:49:13
Thanks that's great news but I have a few questions: 1) Will this invalidate the warranty? 2) Will I be able to revert to the original bios if I'm not happy? 3) Will you be able to mod it so that it runs at 10% (450rpm) instead of 0rpm until 60 degrees celcius? Any higher is just too noisy at idle. My card is 04G-P4-2974-KR.
2018/04/15 16:48:23
fadsarmy
2018/04/15 18:15:07
Sajin 1. Yes, but you can always flash back to the original vbios before sending the card in for service to keep the warranty intact. 2. Yes. 3. Yep. Here is the modified vbios... http://www.mediafire.com/file/5xvhj9nlyycdy4i/gtx970.rom
Thanks Sajin for the bios. I noticed you set the profile so that the rpm starts to climb at 30 degrees C. I think this will be noisy since the card idles at around 40 degrees C.
2018/04/15 18:27:47
fadsarmy
2018/04/15 20:01:52
Tech_JoseC
2018/04/15 20:55:30
fadsarmy Hello, My GTX 970 has been making an irritating chirping noise at idle since day one. It doesn't happen all the time. Initially, I thought it was coil whine. I just discovered that it happens when the fan is attempting to move at idle. Please see video of fan attempting to move. Is this normal?
Hey Fadsarmy, Sorry that your fans are twitching constantly like that, that fan behavior is definitely not normal. A vbios would not necessarily fix that issue. Upon checking your account it looks like both GTX 970's that you have registered are within warranty, open up a support ticket on the card with the fan issues. A RMA for that particular issue is definitely recommended. Our EU support team will take care of you.
fadsarmy
2018/04/16 04:17:45
EVGATech_JoseC
Thanks JoseC. I will do just that.
Dr.Death
- Ribbons : 9
2018/04/16 05:37:42
2018/04/16 14:08:08
EVGATech_JoseC
https://www.evga.com/supp...mmain.aspx?faqid=57713
fadsarmy
2018/04/16 14:17:03
I was thinking the same thing. Some say it's normal and some say it's abnormal. Anyway, I'm going to rma mine becuase of the accompanied chirping noise.
2018/04/16 14:32:17
fadsarmy
2018/04/16 14:43:24
I managed the mic to pick up the chirping noise as the fan twitches if you set your speakers to high.
2018/04/16 14:48:35
fadsarmy I managed the mic to pick up the chirping noise as the fan twitches if you set your speakers to high.
I heard it that time. Looks like it only happens when the fans twitch. The chirping may be normal.
fadsarmy
2018/04/16 14:54:41
It's not normal. I have another identical card that doesn't do it even though it twitches. Weird thing is that it only twitches/chirps after a cold boot. If I restart the pc it stops.
post edited by fadsarmy - 2018/04/16 14:57:56
Dr.Death
- Ribbons : 9
2018/04/17 06:11:08
like said probly just another powerlogic buggy fan . not hard to understand here anymore with them . pretty much told your options - live with it - adjust the profile so it runs full time at a low rpm at idle - service the brg [??] make sure the blades aint hitting something like the shroud or the wires ?- replace the fans - Rma the card . heck may run the fans full time at say 1800-2000 rpm for a hr or so and that may loosen it up or cause something to ware in then mite work properly after that ? ''Weird thing is that it only twitches/chirps after a cold boot. If I restart the pc it stops'' see for me I would lube the brgs to be sure there not sticking cold due to lack or dry lube , but that mat void the rma if you then decide to do that if they were to look in the end all you can do is what TOU feel is best .;/ good luck
fadsarmy
2018/05/08 10:42:02
I did an Advanced RMA and received a replacement GTX 970 today. The replacement card has terrible coil whine so I have not yet sent the old one back. This card is ten times worse than my original card, at least it didn't have any coil whine. Even the fan twitching/chirping is louder and has a loud hiss which the old one didn't have. Given a choice, I would keep my older card. I have a video here of the unbearable coil whine. I want to send the replacement back before I send my original one back.
Dr.Death
- Ribbons : 9
2018/05/08 11:08:36
pretty cheap here if you wanted to try as I said above ? 19 bucks '' Perfect replacement fans for EVGA 980 Ti SC ACX 2.0'' so should be for the 970 as well , but your call https://www.amazon.com/PLA09215B12H-GeForce-GTX760-TiTANX-Graphics/dp/B01MCV6K28 or shop around , here so far them powerlogic fans been short lived and replacing them the cards are still going and cooling fine as normal .. even if you don't try you just don't know and may work out and resolve I'm betting its in there fans PCB goes bad and causes these thing to occur . so far its never been in the card itself or the card to be at blame you can see the fans PCB in this I took the replacement fan for it worked great in the card it was pulled out of . you know there using all high quality JAP components [ lol... ] good luck sorry I did not see /think about I all ready posted all that above
post edited by Dr.Death - 2018/05/08 11:11:23
fadsarmy
2018/05/08 11:35:55
Thank you for your suggestion but it won't get rid of the coil whine.
Dr.Death
- Ribbons : 9
2018/05/08 11:56:26
I thought you said your first ''good'' card just had that fan issue not coil whine .. that just gtx 970 for ya, the #1 complaint of that line from any brand . I mean coil whine and 970's went hand in hand , that's been well known well sorry and good luck
fadsarmy
2018/05/08 12:18:13
Dr.Death I thought you said your first ''good'' card just had that fan issue not coil whine .. that just gtx 970 for ya, the #1 complaint of that line from any brand . I mean coil whine and 970's went hand in hand , that's been well known well sorry and good luck
At the moment, I'm more concerned which card to send back. I'm supposed to send the older one back so that I can get a refund on the collateral I paid for the advanced rma. But I would rather send the replacement back and keep the old one and be done with it.
2018/05/08 12:26:28
You can send the replacement back.
Dr.Death
- Ribbons : 9
2018/05/08 12:39:09
if so as sajin said and alls good on that that try the fan replacement on your first card you decided to keep .. or evga may send you another replacement for the first replacement to test out and it will be satisfactory . then if your still holding on to your original card order the fans and test in the mean time to see if that even resolves [I'm still assuming the original card of yours is just a fan issue and not coil whine as well ?? ] . like here I guess and a few more I don't get why so many are re- rmaing 2 or 3 times getting back as bad a card as they first sent in ? is evga on a pass the buck rma service now a days withn the hopes it works out on your end ?. they claim refurbished or recertified but it seems its just rebox and ship it out with the hope you just give up and go buy there newest latest card at full retail
fadsarmy
2018/05/08 13:08:55
Sajin You can send the replacement back.
Thanks Sajin, that's what I want.
fadsarmy
2018/05/08 13:10:44
Dr.Death if so as sajin said and alls good on that that try the fan replacement on your first card you decided to keep .. or evga may send you another replacement for the first replacement to test out and it will be satisfactory . then if your still holding on to your original card order the fans and test in the mean time to see if that even resolves [I'm still assuming the original card of yours is just a fan issue and not coil whine as well ?? ] . like here I guess and a few more I don't get why so many are re- rmaing 2 or 3 times getting back as bad a card as they first sent in ? is evga on a pass the buck rma service now a days withn the hopes it works out on your end ?. they claim refurbished or recertified but it seems its just rebox and ship it out with the hope you just give up and go buy there newest latest card at full retail
You're spot on. If they say they test all cards before shipping out then something is seriously wrong at EVGA.
