DesirableUsername
So a couple days ago I got my GTX 570 1280 MB DDR5 in the mail so I went to uninstall my old drivers and I plugged on my 570.... To my surprise it wouldn't show video for the mini hdmi port, and when I go install the drivers it says it can't find the 570 what do I do now?
Re: GTX 570 plugged into motherboard, fan spinning, no connection
2018/05/02 09:16:13
Try a different output, try a different mini hdmi cable, try the card in a different pci-e slot, & make sure your motherboard bios is completely up to date. If all that fails to correct the issue try the card in another system.
DesirableUsername
2018/05/02 10:05:18
I have tried a different HDMI cable should I try DVI-i? Also if I use the integrated graphics can the computer still read the graphics card when plugged in.
2018/05/02 10:09:31
DesirableUsername I have tried a different HDMI cable should I try DVI-i? Also if I use the integrated graphics can the computer still read the graphics card when plugged in.
Yes. & Yes, but sometimes if the bios options aren't setup correctly it won't show up.
DesirableUsername
2018/05/02 10:18:14
Ok, do you know what options should be turned to what or should I take pictures?
2018/05/02 10:24:52
I'll lookup the settings. What motherboard do you have?
DesirableUsername
2018/05/02 11:17:13
2018/05/02 11:32:14
Inside the bios navigate to... Advanced, chipset, south bridge configuration primary, and make sure primary graphics adapter is set to pci-e -> pci -> igp. Note: Make sure to unplug all display cables from the motherboard igp & only have display cables connected to the 570.
DesirableUsername
2018/05/02 11:37:13
Ok I'll keep in touch with you first I need to get my DVI-i to vga
DesirableUsername
2018/05/12 11:58:20
Hey, Just bringing back this thread back. I got my DVI-i adapter, and it still doesn't show any video, but I did get a two beep code
2018/05/12 12:21:50
☄ Helpfulby DesirableUsername 2018/05/21 20:17:41
Sounds like the card may have a problem. I'd suggest testing it in another machine at this time.
Much2Pink
2018/05/16 03:02:48
I guess the age old question would be. Are you sure the 570 is getting enough power ? I had this same problem with my old 580. long story short, I left the unit running over night and woke up the next day to find the window logon screen on. [ I blame the old gremlins in old tech ]
When the Creator thought he had finished coloring the flowers, he heard one whisper "Forget me not!" There were no colors remaining except a very small amount of blue, and the forget-me-not was delighted to wear it.
DesirableUsername
2018/05/21 19:09:42
Well, is a 620W PSU good enough for the 570?
DesirableUsername
2018/05/21 19:13:59
I also forgot to mention I have a single PCI-e slot on my motherboard
2018/05/22 08:35:21
DesirableUsername Well, is a 620W PSU good enough for the 570?
Yep.
Much2Pink
2018/05/22 11:01:55
☄ Helpfulby DesirableUsername 2018/05/23 07:01:49
Yep.
I'm going to have to rebuttal your comment. Off the main EVGA website - 550 or greater power supply
- with a minimum of 38 Amp on the +12 volt rail.****PCI Express, PCI Express 2.0 or PCI Express 3.0
- compliant motherboard with one graphics slot.
- Two available 6-pin PCI-E power dongles
While you are right in that if you use base information a 620watt should cover this need. However, it's not taking into account everything else that needs power. If you're using old core from the early 2000 before they started doing the power supply rating system ; you may have a lemon for a power supply. I'd use a thermaltake dr.power ii atx12v power supply tester to make sure. I'd start with this website and work your way though it. coolermaster power-supply-calculator I'm not saying throw money into the wind but, be sure with all angles not just one. "hypothesis Vs theory"
post edited by Much2Pink - 2018/05/22 11:05:25
DesirableUsername
2018/05/22 19:14:07
If I recall, I have an AMD Athlon II X4 640 Processor clocked at 3.00
DesirableUsername
2018/05/22 19:15:08
3.00 GHz Sorry, was in a rush
DesirableUsername
2018/05/22 20:34:41
Update: I reslotted the graphics card for the millionth time, now I get a two short beep boot noise
Much2Pink
2018/05/22 21:01:54
I'm up for the task. mainly cause i'm bored List all the parts you have running in the system list the brand if you can
CPU : MEM : MOTHERBOARD : PS : CASE : LED/LCD Strips : HDD : 1394 : ETC. I mean everything that draws power ~ even the optical drive
2018/05/22 21:03:42
So you can't test the card in another pc?
Hoggle
2018/05/22 23:54:31
What is the model of power supply since knowing the model could help though sometimes it can just be the random underperforming one that is the issue.
DesirableUsername
2018/05/23 05:03:48
It's the Antec Neo Eco 620C
bob16314
- Ribbons : 761
2018/05/23 06:15:35
You could try: • Clearing CMOS as described in your Motherboard Manual• With the GTX 570 removed, updating to the Latest BIOS if needed using EZ Flash (page 2-2 of mobo manual) If no joy, try the card in another PC as suggested earlier or take it to a PC repair shop and have it tested. Your PSU should be good enough.
DesirableUsername
2018/05/23 07:00:23
The thing is that I don't have any other computers to try my graphics card in so I am thinking about going to Geek Squad to have them test it for me should I trust it although?
2018/05/23 08:12:25
They should be able to do the job, but they will most likely charge a high price. Take the card to a local computer repair shop instead of the geek squad.
DesirableUsername
2018/05/23 08:50:37
There's a Milwaukee PC by me I can go to
2018/05/23 10:11:38
DesirableUsername
2018/05/23 11:52:44
I'll get back to ya
DesirableUsername
2018/05/24 13:56:09
Omg Omar gosh, I was reseating and resetting the CMOS Batterie and graphics card, and when I booted up it gave me a award Boot message, "1 long 2 short" video error no additional information
