Re: GTX 1080ti FTW3 Hybrid Kit issues No power or memory temp sensors in Xoc+
2018/05/10 16:05:05
SASAME87, confirm that your card currently is boosting to it's max clocks as well as max voltages. There have been instances where your card will be stuck at 1569 Mhz and below 1.0 volts after this happens. Try using heaven 4.0 or Fire Strike to test your GPU and if you're not getting max clocks, you'll need to RMA the card as well.
4.6 Ghz 4790k - Z97I Plus - 1080 Ti FTW3 Hybrid - 16 GB HyperX Savage 2133 DDR3 - Crucial MX500 1 TB - Seasonic SS 660XP Platinum
