Brand new install, when 5 other cards,( 2 of which are EVGAs as well, although different models) all are mining within 1-2% of each other the FTW3 Hybrid is at 40-60% depending on which algorithm it’s mining. I have changed risers twice, changed PCIE lanes, changed Power supply cables, and when I Rebenchmark between each step, NOTHING changes.... sent a request to EVGA support for help with things to check for and they’re response was “We Don’t officially support mining, check the forums and see if someone will help you”... my response was “I officially spent $900 with you for a product, that product isn’t performing as other products I’ve bought from you, can you at least give me some things to check instead of telling me to piss off?”
Any help would be appreciated
