ecxtimmy
Have a 1080 FTW Hybrid and love it. Just got this 1080ti FTW Hybrid today and this is what I'm seeing. Only the ftw is lit up, the GPU fan does not spin except for a second at startup but the radiator fan does.
Re: GTX 1080 TI FTW HYBRID Power Up Problem
2018/01/12 19:27:37
Try turning the leds on with precision xoc, or the led visualizer from nvidia.
ecxtimmy
2018/01/12 20:15:12
Computer doesn't even recognize the card, not in windows device manager and not in xoc. Wiggling the card enough causes windows to freak out and some of the other LED's to flicker for a split second.
2018/01/12 20:23:55
Have you tried to reseat the card to the motherboard? Have you tried to use the card in another pci-e slot? Is your motherboard bios completely up to date? Have you tried using the other vbios on the card? I believe the fan spinning up then stopping at startup is normal.
ecxtimmy
2018/01/12 20:25:37
Tried both PCI slots, my 1080 works in both. Tried re seanting multiple times and different PCI cables. Tried both normal and OC from the switch.
Yoda_In_Area51
2018/01/13 13:12:15
Sorry not at home at the moment but... I'm 90% sure... My system won't post until that big EVGA Hybrid light is lit. Not at home for a day or two and really can't remember if the fan on the graphics card shroud spins on boot. The fan on the rad is always spinning of course.
post edited by Yoda_In_Area51 - 2018/01/13 13:18:29
Gaming Rig 1: CPU: Intel i7 8700K @ 5.0Ghz (de-lidded) , Mobo: Asus ROG Extreme Z390, Memory: 16GB DDR4 Gskill Trident Z 3200 Mhz, GFX: EVGA 1080TI FTW3 Hybrid , Cooling: EK custom water loop, HDD1: WD Black 250 GB M2, HDD2: Samsung EVO 850 500GB HDD3: 1TB WD, Audio: Onboard, AKG K702, Astro A40s and Razer Hammerhead Pro V2,Monitor: ROG Asus PG279Q, BenQ 27", Mouse:White Logitech G305, Keyboard:Asus Claymore TKL, 850w EVGA G2! Gaming Rig 2: CPU: AMD 3700X , Mobo: Asus ROG Hero X570 , Memory: 16GB DDR4 Gskill Trident Z 3200 Mhz, GFX: EVGA 2070 Super FTW3 Ultra, Cooling: Deep Cool 360 EX, HDD1: 250 GB WD Black M2, HDD2: 500GB HDD3: 500GB HDD4: 1TB WD, Audio: Asus Essence STX II, Astro A40s and Razer True Wireless, Monitor: Acer Predator 27" 1080p 240HZ , Mouse: Black Logitech G305, Keyboard: Fnatic TKL, 850w EVGA G3
2018/01/13 13:23:28
Looks like you're gonna need to rma the card.
AHowes
- Ribbons : 27
2018/01/13 15:03:48
Don't see a back plate in the pic?? Is thst a original 1080ti hybrid card or a hybrid cooler for the ftw3 that you installed?
AHowes
- Ribbons : 27
2018/01/13 15:05:15
Yoda_In_Area51 Sorry not at home at the moment but... I'm 90% sure... My system won't post until that big EVGA Hybrid light is lit. Not at home for a day or two and really can't remember if the fan on the graphics card shroud spins on boot. The fan on the rad is always spinning of course.
Not understanding.. the hybrid led finally comes on after sitting so long and then the system posts?
Yoda_In_Area51
2018/01/13 17:03:36
AHowes
Basically yes. On a cold boot the light stays off (on the side logo "EVGA Hybrid") for 1-3 seconds I would say with nothing posting on the screen. Once the light appears on the "EVGA Hybrid" logo, I then look over at my monitor and it normally displays the UEFI/bios post for me. Reboots are a different matter they boot quickly. I'm not at home to double check but that's what I have been noticing. I've been testing the new bios fix (Meltdown and Spectre) for my Asus Apex mobo and bad overclocks or bad settings whereby the system won't post - I noticed that the "EVGA Hybrid" light stays off. Could be irrelevant or just how the mobo engages components but none the less thought I would mention it as this is my first hint of trouble ha! I did have some issues with my pump not engaging on some cold boots but I'm trying a theory out at the moment which seems to be working but I'm still testing. That's another story! -Y.O.D.A.
post edited by Yoda_In_Area51 - 2018/01/13 17:17:03
