GTX 1070 TI FTW2 fan problem
-gravef1ghter-
2019/05/23 07:46:02 (permalink)
Hey guys,
Okay, so this is a B stock item first off and still under warranty, second, the fans do not come on no matter what the GPU temperature reaches. They do, however, work when PXOC is loaded. So what gives here? Thanks for the help!
Just call me "grave" everyone else does lol
7 Replies Related Threads
    bob16314
    • Ribbons : 429
    Re: GTX 1070 TI FTW2 fan problem 2019/05/23 08:23:45 (permalink)
    There may or may not be a problem.
    First of all, what GPU/Power/Memory temps are you seeing in PXOC?..The fans won't run until temps get hot enough, and I think that's around 60C.
    Turn off Automatic Fan Control in PXOC and check on it.
    Those cards have a Double BIOS..Sounds like maybe you have just the opposite of what's described in this thread..Check the Double BIOS switch position.
    * Cooler Master NV-334 * ASUS ROG Maximus X Hero (Wi-Fi AC) * Intel i7-8700K @ 5.2GHz * 16GB G.SKILL Trident Z 4000MHz * Crucial MX500 M.2 1TB * WD Black 500GB (x2) * Seasonic M12 II 750W * Corsair H80i V2 * EVGA GTX 760 SC * Dual-Boot Win7 Home 64-bit/Win10 Home 64-bit *
    God created man... Samuel Colt made them equal.
    -gravef1ghter-
    Re: GTX 1070 TI FTW2 fan problem 2019/05/23 08:39:41 (permalink)
    GPU Temp is 33, power temp is 34, memory temp is 34 also. That's with PXOC running. The fans aren't coming on at all without PXOC running. How I found this out was when I was playing Sniper Elite III and I started getting Windows warning messages about GPU temps reaching 82, 87, 90, 95 C. Had a heart attack, shut down the game, then downloaded PXOC. If I turn off auto fan control the fans will still operate. It's when I exit PXOC that they will stop and not come back on again until I reload the app. The BIOS switch is set to Master.
    bob16314
    • Ribbons : 429
    Re: GTX 1070 TI FTW2 fan problem 2019/05/23 09:01:10 (permalink)
    I would Contact EVGA and see about maybe setting up an RMA, or return the card to where you bought it from.
    If you uninstall PXOC, the card should work fine on it's own without software intervention..You can use GPU-Z to monitor temps.
    -gravef1ghter-
    Re: GTX 1070 TI FTW2 fan problem 2019/05/23 09:10:00 (permalink)
    It doesn't work without PXOC running so an RMA is a way to go I guess. Thanks for your time sir and have a great day!
    bob16314
    • Ribbons : 429
    Re: GTX 1070 TI FTW2 fan problem 2019/05/23 09:14:53 (permalink)
    -gravef1ghter-
    Unfortunately, yeah..But sending it back to where you bought it from (if other than EVGA) for replacement might be better, if you can.
    Thanks, you too..And welcome to the forums.
    post edited by bob16314 - 2019/05/23 09:19:25
    DavidO
    Re: GTX 1070 TI FTW2 fan problem 2019/05/23 11:36:15 (permalink)
    Hello -gravef1ghter-,
    For something like this, we might be able to look this for over you before an RMA, Please give us a call at the U.S. EVGA Customer Support Line 1 (888) 880-3842 or Email Support@EVGA.com. This would so we can go over this with you.
    Kbird666
    Re: GTX 1070 TI FTW2 fan problem 2019/05/24 15:56:56 (permalink)
    I have this card , on the main bios the Fans don't spinup to 60°c is reach , so I switched it to the slave bios on which the GPU Fan (only) spins at about 15-20% RPM  = +/- 600rpm at all times even when not loaded , which just feels "safer" to me especially with high Summer ambient Temps.  ( it also allows 130% power target on the Voltage).
    However at 80-90° they should both be running hard, so it sound like you need a bios flash at a minimum.....
    Asus X99-A II MB with a 5820K at 4.4GHz
    32GB Corsair Vengeance Ram @3200mhz
    EVGA Nvidia GTX 1070Ti FTW2
    Win10 Pro on (3) 32" BenQ BL3200PT Monitors
