GPU Board Power Draw misreading. Saying 800w power draw on 2080 ti FTW3
aTeam
2019/02/27 20:47:30 (permalink)
I've got a 2080 ti FTW 3 with a hydrocopper water block and it's been running fine for weeks now. Precision x1 has been functioning properly, reading between 280w-380w when gaming. The last few days I noticed a few random spikes where it would read like 500w or 800w. When gaming today it was functioning fine and now it's constantly spiking over 800w. That is obviously not the power draw, it's still pulling normal wattage according to my UPS wattage monitor. What could be causing this?
Intel Core i7 920 HT Enabled, ~3.2GHz (160x20)
3GB Corsair Dominator 1600MHz
750 GB WD Caviar Black
EVGA GTX 295+
Acer P243W 24" 1920x1200 2ms, Sony 15" 1024x768
X-Fi XTremeGamer/ATH-AD700
Razer DeathAdder/Razer Goliathus (speed)
Windows Vista Ultimate SP 1
Gigabyte EX58-UD5
Antec P182
8 Replies Related Threads
    aTeam
    Re: GPU Board Power Draw misreading. Saying 800w power draw on 2080 ti FTW3 2019/02/27 20:53:57 (permalink)
    Quick update. HWinfo is reporting wattage correctly. And when under load X1 reports correct wattage, at idle it starts showing spikes to 800w+
    EVGA GTX 295+
    Gigabyte EX58-UD5
    Antec P182
    Re: GPU Board Power Draw misreading. Saying 800w power draw on 2080 ti FTW3 2019/02/27 21:56:39 (permalink)
    Gotta love software readings. If you want more reliable readings you take hardware readings with a multimeter.
    aTeam
    Re: GPU Board Power Draw misreading. Saying 800w power draw on 2080 ti FTW3 2019/02/28 14:32:09 (permalink)
    I know, I was just wondering if something is wrong with the card or psu if it's throwing out wacky readings like that
    EVGA GTX 295+
    Gigabyte EX58-UD5
    Antec P182
    Heini2
    Re: GPU Board Power Draw misreading. Saying 800w power draw on 2080 ti FTW3 2019/02/28 16:52:46 (permalink)
    Some times when running more than one piece of monitoring software anomalies in readings can happen. Choose the one that you trust the most or experiment to see which seems to give the most solid reading and stick with it.
    Z170 Sabertooth Mk1 / i7-6700K + NH-D15 / Trident Z (2x16GB)@3000 / 2080Ti XC Ultra / Essence STX II / 950 Pro 512GB / G3 1000W / MG279Q / HAF XB EVO / Win10 X64 Pro
    Friggy081084
    Re: GPU Board Power Draw misreading. Saying 800w power draw on 2080 ti FTW3 2019/04/26 14:59:18 (permalink)
    I have the same problem with RTX 2080Ti FTW 3 ULTRA Gaming. Has anyone found a solution? Thanks
    post edited by Friggy081084 - 2019/04/26 15:42:21
    whitleyca
    Re: GPU Board Power Draw misreading. Saying 800w power draw on 2080 ti FTW3 2019/05/18 23:19:00 (permalink)
    I have a 2080Ti Kingpin and I have a somewhat similar problem. When the Kingpin card is not in the first slot (either as only card or with other cards) the OLED display (and X1) shows 800W idle and 900+ when loaded (folding). This strange behavior occurs on both kind of recent hardware (Z170 Classified) and an ancient (X58 4 way SLI Classified) motherboard. I sent in screenshots to EVGA a couple of months ago but have not heard anything back from them. The card works fine (folding 24x7 for the last few months) with temps in the low 40s (wall wattage is 900-1000 for a mix of 980Ti, 1070Ti, 1080 and 20180Ti Hybrid GPUs when loaded) so the misreporting of power is purely cosmetic. In my case the problem with the Kingpin card is always with multiple GPUs installed.
    TwoEvilOne
    • Location: NW Ohio. EVGA Associate Code: 2QME1VF65K9ZY8B
    Re: GPU Board Power Draw misreading. Saying 800w power draw on 2080 ti FTW3 2019/05/18 23:23:55 (permalink)
    your on version 3.11 update Px1
    Register your EVGA product with my affiliate code: LDCH3LNSPA
    Check out my MODS RIGS view my system , and +1  TwoEvilOne's Stormbreaker .  Click here to become an EVGA elite member than an Associate. My 3090 Kingpin 3DMark Port Royal Score: 15,239[/alig
    Faradis
    Re: GPU Board Power Draw misreading. Saying 800w power draw on 2080 ti FTW3 2019/06/24 04:39:58 (permalink)
    damn those bugs/readings.....Cringe!!!!!!!!!!!!!!!!
