Helpful ReplyHot!For those with RGB LED and/or Fan Control Issues
EVGA_JacobF
EVGA Product Manager
  • Ribbons : 26
2018/10/26 18:44:26 (permalink)
EDIT:
Please use PX1 0.3.4 located here: www.evga.com/px1
post edited by EVGA_JacobF - 2018/10/29 10:55:21
butadol
Re: For those with RGB LED and/or Fan Control Issues 2018/10/26 19:26:34 (permalink)
Installed to the system drive just fine.  Would not let me install to a secondary drive.
brahmzy
Re: For those with RGB LED and/or Fan Control Issues 2018/10/26 20:35:27 (permalink)
So first, the MCU firmware upgrade throws a checksum error, and halts, so no go there. Ran as Administrator, no go.
At first it seemed the fans were fixed with 3.3.3. Upon initial install, fans 2 n 3 spun up pretty quick. After saving some profiles, going between mild overclocks, loading defaults etc., the same exact problem with fans 2 n 3 returned. The card runs up to 85/87 degrees, memory at almost 90, and fans 2 n 3 are not even spinning up.
It seems like as soon as I started messing with profiles, things went south. Now, all profiles are gone completely as I deleted them and the problem still exists.
EVGA_JacobF
  • Ribbons : 26
Re: For those with RGB LED and/or Fan Control Issues 2018/10/26 21:29:01 (permalink)
brahmzy
Re: For those with RGB LED and/or Fan Control Issues 2018/10/26 21:46:47 (permalink)
Yes - the first thing I said in my post was I tried running the MCU updater and got a checksum error and it halted the update.
aj_hix36
Re: For those with RGB LED and/or Fan Control Issues 2018/10/27 00:50:50 (permalink)
Edit: Hit Default, then exited, now it works again. Presumably the previous fan curve didn't play nice with the software.
I'm now unable to save profiles or move to the custom fan curve page, it crashes.
Event Viewer says,
Application: PX18.exe
Framework Version: v4.0.30319
Description: The process was terminated due to an unhandled exception.
Exception Info: System.NullReferenceException
at PX18.ViewModel.FanCurveVM.set_Nodes(System.Collections.Generic.List`1<System.Windows.Point>)
at PX18.ViewModel.VgaFanCurveVM.OnActivated(System.Object, PX18.Enumeration.ProductFunction)
at System.EventHandler`1[[PX18.Enumeration.ProductFunction, PX18, Version=0.3.3.3, Culture=neutral, PublicKeyToken=null]].Invoke(System.Object, PX18.Enumeration.ProductFunction)
at PX18.ViewModel.ViewManagerBase.OnActivated()
at MS.Internal.Commands.CommandHelpers.CriticalExecuteCommandSource(System.Windows.Input.ICommandSource, Boolean)
at System.Windows.Controls.Primitives.ButtonBase.OnClick()
at System.Windows.Controls.Button.OnClick()
at System.Windows.Controls.Primitives.ButtonBase.OnMouseLeftButtonUp(System.Windows.Input.MouseButtonEventArgs)
at System.Windows.RoutedEventArgs.InvokeHandler(System.Delegate, System.Object)
at System.Windows.RoutedEventHandlerInfo.InvokeHandler(System.Object, System.Windows.RoutedEventArgs)
at System.Windows.EventRoute.InvokeHandlersImpl(System.Object, System.Windows.RoutedEventArgs, Boolean)
at System.Windows.UIElement.ReRaiseEventAs(System.Windows.DependencyObject, System.Windows.RoutedEventArgs, System.Windows.RoutedEvent)
at System.Windows.UIElement.OnMouseUpThunk(System.Object, System.Windows.Input.MouseButtonEventArgs)
at System.Windows.UIElement.RaiseEventImpl(System.Windows.DependencyObject, System.Windows.RoutedEventArgs)
at System.Windows.UIElement.RaiseTrustedEvent(System.Windows.RoutedEventArgs)
at System.Windows.Input.InputManager.ProcessStagingArea()
at System.Windows.Input.InputManager.ProcessInput(System.Windows.Input.InputEventArgs)
at System.Windows.Input.InputProviderSite.ReportInput(System.Windows.Input.InputReport)
at System.Windows.Interop.HwndMouseInputProvider.ReportInput(IntPtr, System.Windows.Input.InputMode, Int32, System.Windows.Input.RawMouseActions, Int32, Int32, Int32)
at System.Windows.Interop.HwndMouseInputProvider.FilterMessage(IntPtr, MS.Internal.Interop.WindowMessage, IntPtr, IntPtr, Boolean ByRef)
at System.Windows.Interop.HwndSource.InputFilterMessage(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndWrapper.WndProc(IntPtr, Int32, IntPtr, IntPtr, Boolean ByRef)
at MS.Win32.HwndSubclass.DispatcherCallbackOperation(System.Object)
at System.Windows.Threading.ExceptionWrapper.InternalRealCall(System.Delegate, System.Object, Int32)
at System.Windows.Threading.ExceptionWrapper.TryCatchWhen(System.Object, System.Delegate, System.Object, Int32, System.Delegate)
at System.Windows.Threading.Dispatcher.LegacyInvokeImpl(System.Windows.Threading.DispatcherPriority, System.TimeSpan, System.Delegate, System.Object, Int32)
at MS.Win32.HwndSubclass.SubclassWndProc(IntPtr, Int32, IntPtr, IntPtr)
at MS.Win32.UnsafeNativeMethods.DispatchMessage(System.Windows.Interop.MSG ByRef)
at System.Windows.Threading.Dispatcher.PushFrameImpl(System.Windows.Threading.DispatcherFrame)
at System.Windows.Application.RunDispatcher(System.Object)
at System.Windows.Application.RunInternal(System.Windows.Window)
at PX18.App.Main()
at PX18.Program.Main()
Faulting application name: PX18.exe, version: 0.3.3.3, time stamp: 0x5bd2de35
Faulting module name: unknown, version: 0.0.0.0, time stamp: 0x00000000
Exception code: 0xc0000005
Fault offset: 0x00007ffb11aed2a8
Faulting process id: 0x2a60
Faulting application start time: 0x01d46dc92b951412
Faulting application path: C:\Program Files\EVGA\Precision X1\PX18.exe
Faulting module path: unknown
Report Id: 7c403fe0-591e-49dd-8cf1-6e78f5cfc3d9
Faulting package full name:
Faulting package-relative application ID:
Fault bucket 1537733742022282057, type 5
Event Name: CLR20r3
Response: Not available
Cab Id: 0
Problem signature:
P1: PX18.exe
P2: 0.3.3.3
P3: 5bd2de35
P4: PX18
P5: 0.3.3.3
P6: 5bd2de35
P7: 2fe
P8: 7
P9: System.NullReferenceException
P10:
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERA411.tmp.dmp
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERA4FC.tmp.WERInternalMetadata.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERA52C.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERA530.tmp.csv
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WERA541.tmp.txt
These files may be available here:
\\?\C:\ProgramData\Microsoft\Windows\WER\ReportArchive\AppCrash_PX18.exe_2c1771b590e87967a9c290f0ba8fbd2953a2453_7f703f89_2a6baa99
Analysis symbol:
Rechecking for solution: 0
Report Status: 268435456
Hashed bucket: 6c269a7839a62810555720b0ec5ecb49
Cab Guid: 0
post edited by aj_hix36 - 2018/10/27 00:55:08
Krion
Re: For those with RGB LED and/or Fan Control Issues 2018/10/27 07:48:43 (permalink)
I still can't get X1 to actually save any of my settings. The program will randomly put me back at default when I open it sometimes.
aj_hix36
Re: For those with RGB LED and/or Fan Control Issues 2018/10/27 12:30:40 (permalink)
IT IS STILL BROKEN HOW HARD IS IT TO MAKE A CARD THAT WORKS FOR MORE THAN 4 HOURS AT A TIME
EVGA_JacobF
  • Ribbons : 26
Re: For those with RGB LED and/or Fan Control Issues 2018/10/27 14:21:56 (permalink)
Krion
Do you have save setting on reboot enabled in settings and are you using profiles?
EVGA_JacobF
  • Ribbons : 26
Re: For those with RGB LED and/or Fan Control Issues 2018/10/27 14:22:35 (permalink)
aj_hix36
What exactly is the issue?
pcu38159
Re: For those with RGB LED and/or Fan Control Issues 2018/10/27 21:40:17 (permalink)
Thanks for your help
Got the same issue on my 2080Ti XC with Precision X1 0.3.3.0
After update MCU & Precision X1 0.3.3.3, LED works again.
aldur80
Re: For those with RGB LED and/or Fan Control Issues 2018/10/27 22:16:31 (permalink)
aj_hix36
I had this issue too when I was using v0.3.3.0 and at that time Jacob just posted v0.3.3.1. I uninstalled v0.3.3.0 and installed v0.3.3.1 and I was able to go to the custom fan curve page without it crashing and set my custom fan curve.
badboy64
Re: For those with RGB LED and/or Fan Control Issues 2018/10/27 22:53:14 (permalink)
I have had 2 issues with this beta as sometimes my 2080Ti FTW3 Ultra thinks it is just plain 2080Ti as it did this twice and I lost 1 of my fans also. I can get it back from a 2080Ti to the FTW3 but exiting but I lost 1 fan in the process. Also it keeps on unchecking auto fan control and I have to enable all of the time.
post edited by badboy64 - 2018/10/27 23:08:04
Processor Intel® Core™ i9 7960K CPU 2.8GHz@4.7ghz, Memory 32GB GSkill Trident Z RPG 3000 Ram, Samsung 960 EVO 1Tb M2, Motherboard eVga Dark x299, Operating System Windows 10 Pro 64-Bit, eVga 2080TI FTW3 Ultra 11GB , Monitor Acer X27 Predator , Logitech G910, Razer Lancehead Tournament Edition,Thermaltake View 71 RGB, eVga SUPERNOVA 1600 T2 PSU, EK-KIT X360.
Time Spy Extreme eVga 2080TI FTW3 Ultra
7,530
https://www.3dmark.com/spy/5356597
Robert0507
Re: For those with RGB LED and/or Fan Control Issues 2018/10/27 23:17:49 (permalink)
Same thing here. Auto fan control unchecking it’s self
Ankitag
Re: For those with RGB LED and/or Fan Control Issues 2018/10/27 23:49:27 (permalink)
I think think 0.3.3.3 version forces flash tool update dialog on every run, I had installed and applied update from the 0.3.3 version and that messed up the led and fan, after that I applied the MCU update, thank god that fixed the issue but now every time I open x1(0.3.3.3) the flashtool dialog box pops up asking to apply update again. I think I will need to uninstall 0.3.3.3 version and install the regular 0.3.3 to get rid of the dialong pop up every time I run it - thoughts admins?
post edited by Ankitag - 2018/10/28 01:46:12
aj_hix36
Re: For those with RGB LED and/or Fan Control Issues 2018/10/28 03:10:10 (permalink)
Ok I described it better in the other thread, but the exact issue is that after some undetermined amount of time of the computer being inactive, I come back, and px1 has the power wattage dissappear, and fans 2 and 3 stay at zero no matter what. I then close and reopen the software, and it then shows the bug where only 2 fans show, no power wattage and you can't control the fans, and if you change the display the software crashes. The only way to then fix that is to turn off my computer and power flush it.
  • Ribbons : 185
Re: For those with RGB LED and/or Fan Control Issues 2018/10/28 08:41:41 (permalink)
Going to give 3.3.3 a try on 1809
brahmzy
Re: For those with RGB LED and/or Fan Control Issues 2018/10/28 09:10:29 (permalink)
Is there a way to check what MCU version the card is running?
Jacob, any update on further fixes for PX1?
badboy64
Re: For those with RGB LED and/or Fan Control Issues 2018/10/28 23:04:34 (permalink)
Robert0507
I finally figured out how to keep the fans option from unchecking itself. Just don't hit apply and I have 2 profiles and did a stress test with clocks of 100mhz gpu and 500mhz memory and the temp never got above 74*C during the whole stress test.
https://www.3dmark.com/3dm/29854164
7,530
EVGA_JacobF
  • Ribbons : 26
Re: For those with RGB LED and/or Fan Control Issues 2018/10/29 10:54:55 (permalink)
Update:
Please use 0.3.4 for any issues relating to this:
www.evga.com/px1
  • Ribbons : 185
Re: For those with RGB LED and/or Fan Control Issues 2018/10/29 11:10:03 (permalink)
 Giving it a go
Maybe it fixes the Saving Profile issues as well.
post edited by bcavnaugh - 2018/10/29 11:12:38
Stabicron
Re: For those with RGB LED and/or Fan Control Issues 2018/10/29 15:32:55 (permalink)
I am having an odd problem trying to download the MCU update, namely that it just spins forever and doesn't allow me to download the file. Tried multiple browsers. Even on the latest version of the X1 software LED is turned off
  • Ribbons : 189
Re: For those with RGB LED and/or Fan Control Issues 2018/10/29 18:13:47 (permalink)
Stabicron
Try downloading it to your phone.
#23
  • Ribbons : 185
Re: For those with RGB LED and/or Fan Control Issues 2018/10/29 18:26:22 (permalink)
No-Go for me on the LED Settings, worked a few reboots and now back to Gone.
https://forums.evga.com/FindPost/2875491
Saving Profile is still not working as well
https://forums.evga.com/FindPost/2875490
#24
badboy64
Re: For those with RGB LED and/or Fan Control Issues 2018/10/29 18:34:18 (permalink)
Both are working for me just fine.
7,530
#25
  • Ribbons : 185
Re: For those with RGB LED and/or Fan Control Issues 2018/10/29 18:44:03 (permalink)
badboy64
Good to hear, how do you like Windows 10 1809?
#26
ksuaviator
Re: For those with RGB LED and/or Fan Control Issues 2018/10/29 19:25:32 (permalink)
FYI, the 0.3.4 Beta X1 Software shut off all fans on my FTW3. I didn't realize at first and walked away. Luckily I have an annoying alarm when the GPU temp reaches 75C.
Don't know if it's a fluke with my software and the 2080TI FTW3, but heads up it shut down my GPU fans. I was idling around 62C...
I reinstalled 0.3.3 and the fans came back on
My Affiliate Code: NAN23A0AUZ
MODS RIGS: https://www.modsrigs.com/detail.aspx?BuildID=40137
#27
Frammish
Re: For those with RGB LED and/or Fan Control Issues 2018/10/29 20:09:07 (permalink)
Not just you, ksuaviator. 0.3.4.0 also shut off my fans. It doesn’t save settings. It won’t scan for overclocks. It seems a big step back.
Not sure why so many problems with Precision X1 but it sure has them.
#28
brahmzy
Re: For those with RGB LED and/or Fan Control Issues 2018/10/29 20:39:07 (permalink)
0.3.4 seems better for me - did a bit of testing tonight. I didn’t try setting any profiles (that seems to really break it good), but all 3 fans came on at 55 degrees.
* Is 55 degrees the target temp for ICX2 to kick the fans on? *
Overall much more consistent/predictable behavior. Was running 0.3.0 before since 0.3.3 was unusable.
How on earth can so many of us be having different behavior?
I’d still like a slightly more aggressive firmware-based ICX2 fan profile.
**********EDIT: SPOKE TOO SOON AGAIN.  Cannot use profiles or it borks fans 2 and 3. It's as much a mess as 0.3.3.
What brings back proper fan operation for 2 and 3 is unchecking the "AUTO" icon, hitting Apply, checking the "AUTO" fan icon again an hitting apply again.  Then fans 2 and 3 operate properly.
I am unable to keep an overclock since I can't use profiles nd without a profile, the settings get lost on a reboot despite the "Apply previous settings on load" being checked.
THIS SUCKS!!!!!
post edited by brahmzy - 2018/10/30 19:18:54
#29
DisplacerGoat
Re: For those with RGB LED and/or Fan Control Issues 2018/10/29 20:57:28 (permalink)
0.3.4 installed well. LED worked again, well, that is until I restarted. LED no longer work. Also, since restart, from once seeing all three of my fans, the software only sees two.
Intel i7-8700K @ 5.2 Ghz
Asus ROG Maximus X Apex
EVGA 2080 TI FTW3
2x 16 GB G. Skill F4-3000C14
2x Samsung 960 Pro 1 TB m.2
EVGA Supernova 1300 G2
#30
