aj_hix36
Re: For those with RGB LED and/or Fan Control Issues
2018/11/03 12:19:35
Hoggle
2018/11/03 12:26:29
I have been wondering if the RGB issues could be realated to the October update. It seems to have caused problems for my EVGA DG77 case. Luckily it seems like a new version of the software will fix the issue. Know that a case and a graphics card are diffrent but seems odd people would have an issue with both.
- Ribbons : 282
2018/11/03 12:33:59
Hoggle I have been wondering if the RGB issues could be realated to the October update. It seems to have caused problems for my EVGA DG77 case. Luckily it seems like a new version of the software will fix the issue. Know that a case and a graphics card are diffrent but seems odd people would have an issue with both.
Are you referring to 1809, MS has even pulled from their website in the https://www.microsoft.com/en-us/software-download/windows10 was reset back to 1803.
Zange
2018/11/03 12:37:04
badboy64 I lost 1 fan twice today and missing sensors readings. Now I got shut down again to get it back to normal??? This the latest Precision X1 posted today.
Im dealing with same issue but with red lights included and middle fan going 100%.
Ankitag
2018/11/03 13:20:36
EVGA_JacobF EDIT: Please use PX1 0.3.4 located here:
I applied the MCU update, BIOS update and now downloaded the latest version of X1 3.5.1 - everytime I open it, it still asks me for the flashing the MCU, I have to say no to it everytime.
EVGA_JacobF
- Ribbons : 26
2018/11/07 08:56:30
☄ Helpfulby Cool GTX 2018/11/07 18:03:28
IronRinn
2018/11/08 06:18:50
EVGA_JacobF Did you try the MCU updater?
I've been having a problem with the LED firmware for a while now. These links do not work for me on my desktop or phone. I just get a connection timeout error. It's very frustrating.
badboy64
2018/11/08 08:12:09
14th Intel® Core™ i9 14900KF CPU 3.2GHz@6.0ghz, Memory 2x24GB GSkill Trident Z Trident Z5 7200 mhz DDR5 Ram,4,000 GB MSI M480 PRO 4TB , Motherboard eVga 690 Dark , Operating System Windows 11 Pro 64-Bit, Msi Suprim X24G 4090, Monitor Acer CG437K, Logitech G910, Razer Lancehead Tournament Edition, Thermaltake View 91 RGB plus, eVga 1600w P2 PSU, Custom watercooling. Speed Way Score 11,055 points. https://www.3dmark.com/sw/1112818
aj_hix36
2018/11/08 10:23:47
This is the first version that made it through the night without failing. Good job. Minor bug still around though is that if you adjust anything in Precision X1 while the main screen is showing (the icx and and fan speed controls), it unchecks your Automatic Control custom fan curve. It has to be the last thing you do or the checkmark is gone and the fans don't work on the curve.
post edited by aj_hix36 - 2018/11/08 10:26:17
TahoeDust
2018/11/08 14:45:44
I have a weird issue. Everytime I restart my computer the fans on my ftw3 all go to 100%. I have to go into PX1 and turn them back to my fan curve.
Kozy88
2018/11/08 14:47:26
Anyone having trouble "saving" anything in PX1? Every reset i'm back to default
Ankitag
2018/11/11 13:22:48
Kozy88 Anyone having trouble "saving" anything in PX1? Every reset i'm back to default
Same here, I apply the overclock click save, restart the pc, back to defaults, why can't it follow cpu overclock pattern, once applied it stays applied.
