- Ribbons : 282
Re: For those with RGB LED and/or Fan Control Issues
2018/10/29 20:59:38
DisplacerGoat 0.3.4 installed well. LED worked again, well, that is until I restarted. LED no longer work. Also, since restart, from once seeing all three of my fans, the software only sees two.
That is what seems to be happening for me as well under 1809 https://forums.evga.com/FindPost/2875490
2018/10/29 21:52:13
Try powering all the way down, pull the plug from the wall & all self powered items (monitor, usb hub, printer ....) Hold the start button for 30 seconds to discharge the capacitors ... plug everything back in and Start PC Is Windows 10 Fast Startup OFF ? --- it should be when upgrading drivers, firmware or hardware With Windows 10 there is a new “hybrid” startup mode that should cut down on boot up times. It does this by putting the PC into hibernation instead of fully shutting down." Windows Central - How to disable Windows 10 fast startup (and why you'd want to)
aj_hix36
2018/10/30 01:07:03
After using 0.3.4 all day, it is STILL BROKEN. If I run your PX1 all day, and come back to my computer, fans 2 and 3 stop working and refuse to function until I power flush my system. Seriously, I keep reporting this version after version after version, and still nothing. PS, when this happened before Wattage would disappear, well at least this time now it just reads 0w instead of disappearing, that's literally the only difference between versions.
post edited by aj_hix36 - 2018/10/30 01:17:18
Stabicron
2018/10/30 04:11:24
Stabicron I am having an odd problem trying to download the MCU update, namely that it just spins forever and doesn't allow me to download the file. Tried multiple browsers. Even on the latest version of the X1 software LED is turned off
Try downloading it to your phone.
That worked. Odd that I couldn't download via browser though
badboy64
2018/10/30 04:16:10
badboy64
bcavnaugh No-Go for me on the LED Settings, worked a few reboots and now back to Gone. https://forums.evga.com/FindPost/2875491 Saving Profile is still not working as well https://forums.evga.com/FindPost/2875490
Both are working for me just fine.
Good to hear, how do you like Windows 10 1809?
I am still on 1803 since 1809 makes 3 of my games that I play not to work properly. Anyways I lost 1 fan again and sensors also and why do I have close out the program as on a reboot into windows it see's my 2080Ti FTW3 Ultra as just a plain 2080Ti?
14th Intel® Core™ i9 14900KF CPU 3.2GHz@6.0ghz, Memory 2x24GB GSkill Trident Z Trident Z5 7200 mhz DDR5 Ram,4,000 GB MSI M480 PRO 4TB , Motherboard eVga 690 Dark , Operating System Windows 11 Pro 64-Bit, Msi Suprim X24G 4090, Monitor Acer CG437K, Logitech G910, Razer Lancehead Tournament Edition, Thermaltake View 91 RGB plus, eVga 1600w P2 PSU, Custom watercooling. Speed Way Score 11,055 points. https://www.3dmark.com/sw/1112818
EVGA_JacobF
- Ribbons : 26
2018/10/30 08:16:00
aj_hix36 After using 0.3.4 all day, it is STILL BROKEN. If I run your PX1 all day, and come back to my computer, fans 2 and 3 stop working and refuse to function until I power flush my system. Seriously, I keep reporting this version after version after version, and still nothing. PS, when this happened before Wattage would disappear, well at least this time now it just reads 0w instead of disappearing, that's literally the only difference between versions.
Are you using custom fan speeds or auto?
2018/10/30 10:33:23
Stabicron
aj_hix36
2018/10/30 10:59:51
EVGA_JacobF
Custom fan curve. It breaks on auto fan as well if I leave precision x1 open. The only way for my gpu to work currently is to not let px1 be open in the background, after I've restarted and the card is recognized again, which forces me to only use auto fan mode.
EVGA_JacobF
- Ribbons : 26
2018/10/30 11:02:36
aj_hix36
EVGA_JacobF
Thanks, let me look into this.
badboy64
2018/10/31 06:16:15
I hope you guys are working on another since I can't go 5 hours and I lose 1 fan I fan plus the half of the sensors are at zero and have to reboot to get it working again. Why does it say I have a regular 2080Ti on reboot and have to exit the program to get to recognize it as a 2080Ti FTW3 Ultra?
post edited by badboy64 - 2018/10/31 06:20:11
brahmzy
2018/10/31 08:12:24
Any update from eVGA? 0.3.4 is still broken.
post edited by brahmzy - 2018/10/31 20:56:20
TahoeDust
2018/10/31 08:54:20
Any word on a fix for getting X1 to save your settings? The presets don't work at all for me, or maybe I am doing it wrong.
d.burnette
- Ribbons : 17
2018/10/31 08:54:57
TahoeDust Any word on a fix for getting X1 to save your settings? The presets don't work at all for me, or maybe I am doing it wrong.
Seems to be hit or miss at this time.
Don EVGA Z390 Dark MB | i9 9900k CPU @ 5.2 GHz all cores | EVGA RTX 3090 FTW3 Ultra | 32 GB G Skill Trident Z 3200 MHz CL14 DDR4 Ram | Corsair H150i Pro Cooler | EVGA T2 Titanium 1000w Power Supply | Samsung 970 Pro 1TB m.2 Nvme | Samsung 970 Evo 1TB m.2 Nvme | Samsung 860 Evo 1TB SATA SSD | EVGA DG 87 Case |
EVGA_JacobF
- Ribbons : 26
2018/10/31 10:03:21
What do you mean by presets?
EVGA_JacobF
- Ribbons : 26
badboy64
2018/10/31 10:25:53
EVGA_JacobF
badboy64 I hope you guys are working on another since I can't go 5 hours and I lose 1 fan I fan plus the half of the sensors are at zero and have to reboot to get it working again. Why does it say I have a regular 2080Ti on reboot and have to exit the program to get to recognize it as a 2080Ti FTW3 Ultra?
Uninstall PX1 and delete GpuInfo.bin in the install folder, then reinstall.
I have been and it disappears after uninstall. But is still retaining my saves though. Even after uninstall.
TahoeDust
2018/10/31 11:50:36
EVGA_JacobF
Sorry, I meant profiles. I can not get settings to save to the numbered profiles, unless I am doing it wrong.
brahmzy
2018/10/31 20:55:47
Jacob. 0.3.4 did NOT fix this. When using profiles, fans 2 and 3 quit working. They will not spin up as the GPU temp rises - all the way up past 80 degrees. There is a bug that is still present!
soliex
2018/11/01 05:15:10
I just received my 2080 TI FTW3 yesterday and the day before that my 9900k so my system is as fresh as it gets. Installed 0.3.4 and started having issues right away. Doing anything with profiles seems to be real wonky and sometimes it saves and sometimes it doesnt. My Fan settings never seem to apply, I want them on auto and to be chained. Sometimes I'll go back into X1 and they are not chained and only 1 of my fans is spinning (1st one near display connections) I ran OC Scanner and only received a +90 (Is that good/bad?) and also tried running Time Spy regular a couple times and Ive had it successfully run once, hard crash twice, and subsequent times it will error out at random times and tell me the test failed. I'm sad :(
brahmzy
2018/11/01 05:20:32
^^ Great post - sums up the problems nicely. Welcome to my pain. Fix it EVGA!!!
Andrew_K
2018/11/01 09:14:26
soliex I just received my 2080 TI FTW3 yesterday and the day before that my 9900k so my system is as fresh as it gets. Installed 0.3.4 and started having issues right away. Doing anything with profiles seems to be real wonky and sometimes it saves and sometimes it doesnt. My Fan settings never seem to apply, I want them on auto and to be chained. Sometimes I'll go back into X1 and they are not chained and only 1 of my fans is spinning (1st one near display connections) I ran OC Scanner and only received a +90 (Is that good/bad?) and also tried running Time Spy regular a couple times and Ive had it successfully run once, hard crash twice, and subsequent times it will error out at random times and tell me the test failed. I'm sad :(
I have similar issues with timespy. I can't get it to complete at all. I had no issues with a 2080ti xc ultra, but with the ftw it won't finish. People have suggested it's a problem with my CPU, but it definitely is not. I've tried with no overclock, the same overclock that worked fine with the xc ultra, etc. Super odd.
soliex
2018/11/01 09:22:10
Andrew_K
Thats interesting and concerning, I have a good 5-6 hours dedicated tonight to tweaking and dialing in my system as a whole and that will involve a lot of benchmarks and testing and tweaking. I got mine to run successfully at least once so who knows what it could be. My CPU is also a day old so I need to tweak/test that as well. But If I find out anything I will gladly share.
aldur80
2018/11/01 10:01:11
I feel for you guys that are having these problems. I'm using v0.3.4.0 and I'm not experiencing any of these problems. I've been reading through all the posts trying to figure out what the problem might be, but I'm not sure what I'm doing differently. Hopefully EVGA figures this out soon as it sounds like it makes the card unusable for the people who are affected by it.
soliex
2018/11/01 10:14:36
aldur80 I feel for you guys that are having these problems. I'm using v0.3.4.0 and I'm not experiencing any of these problems. I've been reading through all the posts trying to figure out what the problem might be, but I'm not sure what I'm doing differently. Hopefully EVGA figures this out soon as it sounds like it makes the card unusable for the people who are affected by it.
What are you using X1 to do? How do you make a change? Do you save or only Apply? Do you Apply after each change or after many changes? Can you give a run down of how you use it? I would appreciate it.
aldur80
2018/11/01 10:26:40
soliex What are you using X1 to do? How do you make a change? Do you save or only Apply? Do you Apply after each change or after many changes? Can you give a run down of how you use it? I would appreciate it.
I'm using X1 to: - Set the GPU overclock to +140
- Set the memory overclock to +700
- Set the power target to 124%
- Set the GPU temp to 88
- Custom fan curves for all fans that leave the fans off until the temp reaches 40 degrees for all sensors, then the fans go 100%
When I make a change I hit apply after making all my changes, but I make sure that I only hit apply when under the custom fans screen to make sure the "Enable Automatic Control" option is turned on. If I hit Apply in any other screen then the "Enable Automatic Control" option in the fans screen gets turned off.
soliex
2018/11/01 11:31:27
Thanks for that aldur80, I will mess with mine later today and report back!
EVGA_JacobF
- Ribbons : 26
2018/11/01 11:49:17
TahoeDust
2018/11/01 13:10:21
GTXJackBauer
- Ribbons : 48
2018/11/01 18:01:26
Obviously something is going on that affects some and not others. It could be those that have the newest Win 10 update have issues while the other's don't. At this stage, it looks to be software related to narrow it down.
badboy64
2018/11/01 20:34:52
I lost 1 fan twice today and missing sensors readings. Now I got shut down again to get it back to normal??? This the latest Precision X1 posted today.
