Re: Flow Control v2.0.7 Device not found CLC 280
2018/05/17 15:47:54
redleader00
Dooms87
Will there be any fix on this issue? I've tried to force my fan speed to be at 100% via bios but I don't think that is a permanent fix. (MSI Gaming Pro Carbon x270) I'm again receiving the CPUWB Device not found error. I own a Corsair keyboard but didn't install the software and I have Corsair RGB ram that's controlled by my MSI software. If I'd like to use Flow control I have to reinstall the application entirely I've also noticed that the temps it reports seem to be wrong as Realtemps provided readings are usually different.
You need to supply the CLC-280 100% power from the motherboard (that's why you need to set it in the the bios to 100%) and use Flow to set the fan curve and pump speed. This is not a bug or something that can be fixed. It is designed to work this way.
So I'm not sure if I can permanently do that in my bios I have the option to force all fans to 100% which I did but the problem returns afterward Msi Fan control only options are force to 100/default and smart fan control
NZXT Phantom 630 - Asus P6X58D-E - EVGA GTX 680 FTW 4gb - Intel I7 930 2.8 Ghz OC @ 4.0Ghz - H80
Corsair HX1000W - Corsair 12gb DD3 Dominator ram 1600 - Intel 80 gig X25m SSD -
Samsung 500g HDD -Logitech G15 - Logitech G9X -Win 8.1 Pro 64-bit
