Hot!Flow Control software LED issues...
LiquidTN
2017/04/08 05:37:01 (permalink)
Hello all - So I bought the CLC 280 - which has been great! However, when I select the LEDs to represent Temps CPU or Coolant)...it doesn't seem to work well. There are only 3 temp ranges: low, mid and high, (40, 60 and 80 - I know these can be changed). After I select it, sure enough, it'll show blue (lowest temp), but I then can run a cpu stress test (like Cinebench) and the LED doesn't change to represent the proper CPU temp - or, when it does change, it'll go red (80), of which, my CPU has never gotten that hot.  My highest temp has been 62 c (which should show the middle temp range and NEVER does).
All other LED selections (breathing, pulse, rainbow) all work fine, but I like to have LED color temp representation.
Anyone else having this issue? I know the software is probably still undergoing changes.
Thanks...
System:
Asus Maximus XI Code Z270 m/b
i7-7700k w/ EVGA CLC 280 cooler (running v2.0.1 and Firmware 2.10.0.0)
32 gig DDR4-3200 Geil Ram
EVGA 1070 FTW Hybrid (running Precision XOC 6.1.2)
2 Samsung EVO 960 M.2 250
Win 10 Pro
11 Replies Related Threads
    Grapejelly
    Re: Flow Control software LED issues... 2017/04/08 12:00:37 (permalink)
    I too experience this exact same behavior.
    Case: EVGA DG-87
    PSU: EVGA SuperNOVA 1200 P2
    Motherboard: EVGA Z270 Classified K
    CPU: Intel Core i7-7700K
    Cooling: EVGA CLC 280
    Memory: 64GB Corsair Vengeance LPX 3600Mhz
    Disk: Samsung 960 PRO m.2 SSD 512GB
    Graphics: EVGA GeForce GTX 1080 CLASSIFIED
    Affiliate Code: PTDD5CC38F
    MDeckerM
    • Ribbons : 7
    Re: Flow Control software LED issues... 2017/04/08 19:08:00 (permalink)
    Hello,
    very sorry to hear that the software is not allowing these settings to work properly.
    I will notify our Product Management team so we can address this in a future release.
    Thank you
    Have a moment? Please rate our service
    (つ◕౪◕)つ━☆゚.*・。゚X99Micro2 | 5960X | 1080Ti 。゚・*.☆゚
    91gtabird
    Re: Flow Control software LED issues... 2017/04/11 14:42:37 (permalink)
    Same here.
    i5 7600K
    MSI Z270 Gaming Pro Carbon (RGB)
    16GB Corsair Vengence RAM (RGB)
    EVGA CLC 280mm (RGB)
    EVGA GTX 1080 FTW (RGB)
    EVGA 850w GQ
    Corsair 400c Case
    brhodes15
    Re: Flow Control software LED issues... 2017/05/24 16:30:14 (permalink)
    same issue.. any work around yet or just have to wait for update?
    EVGA_JacobF
    EVGA Product Manager
    • Ribbons : 23
    Re: Flow Control software LED issues... 2017/06/21 11:27:08 (permalink)
    This is fixed in 2.0.3 releasing today.
       gordon -  6700k @ 4.6ghz || evga Z170 stinger || evga gtx 1070 ftw acx3 || 16gb 3.2ghz ddr4 || 500gb 840 evo raid0 || evga supernova 750 g3
       hadronGTX - 4770k @ 4.4ghz || evga z97 stinger || evga gtx780 ti acx || 16GB 2.6ghz ddr3 || 480gb vertex3 raid0 || 500w gold
    • Ribbons : 155
    Re: Flow Control software LED issues... 2017/06/21 12:40:22 (permalink)
    EVGA_JacobF
    Koithim
    Re: Flow Control software LED issues... 2017/06/21 13:12:10 (permalink)
    Geting a connection refused message.  I'm from Canada.
    Update: used Edge instead of Chrome and it worked ok.
    Cheers!
    post edited by Koithim - 2017/06/21 13:14:19
    K
    _____________________________
    CASE: EVGA DG-87
    COOL: EVGA CLC 280
    PSU: EVGA SuperNOVA 850 G2L
    MOBO: ASUS ROG Maximus IX Code
    CPU: Intel Core i7-7700k @ 4.6 GHz
    MEM: 4x8GB Corsair vengeance LED 3400
    SSD: Samsung 960 Pro 512GB PCIe M.2
    VGA: EVGA GTX 1080 Ti SC2 Hybrid
    VGA: EVGA GTX 1080 Ti FE
    DISP: Asus PG279Q
    Windows 10 pro 1703
    Koithim
    Re: Flow Control software LED issues... 2017/06/21 13:22:13 (permalink)
    Both problems i had are fixed:  Led temp color and auto fan now load on boot.
    Thank you!!!
    K
    CASE: EVGA DG-87
    COOL: EVGA CLC 280
    DISP: Asus PG279Q
    Windows 10 pro 1703
    brhodes15
    Re: Flow Control software LED issues... 2017/06/22 17:54:33 (permalink)
    EVGA_JacobF
    i have my Rgb fan connected to a controller, so the software says my fan rpm is 0.  could that be why the led still turns red eventually no matter what setting i have it on?
    • Ribbons : 111
    Re: Flow Control software LED issues... 2017/06/22 18:13:48 (permalink)
    Signup and Get Update:
    Log In
    I do not spam or sell your email, period.
    post edited by ty_ger07 - 2017/06/22 18:19:30
    daniel0
    Re: Flow Control software LED issues... 2018/01/13 09:23:48 (permalink)
    Sorry for resurrecting this thread, but I recently installed a clc 240 and it seems that the flow control software won't open when LED sync is open (and LED sync opens before precision and flow control.) I have to close the sync program to open flow control but then if i go to the sync it only shows my 1080.
