Flow Control LED Problems
sean76034
2017/09/17 18:54:18 (permalink)
I started using 2.0.3 and all was working fine, except the breathing effect which isn't a big deal. Then the next day the light will change to a different color, blink back to the one I have set, blink again and then stay the wrong color. (no it is not because of pulse or the temp options, they are not enabled and the temp one is set to different colors.) This must be a software issue. I downgraded to 2.0.2 and it was working flawlessly, including the breathing option that wouldn't work before. However, a few hours later I started to get the same blinking effect as seen in 2.0.3. Can this be fixed on my end or is a 2.0.4 hopefully coming out soon? It is bugging me so much that I am considering returning it because I just want the LED to stay the same color as my RGB fans.
2 Replies Related Threads
    sean76034
    Re: Flow Control LED Problems 2017/09/19 22:47:14 (permalink)
    I'm not sure if it's a faulty device or the software. I tried the newest update 2.0.4 and it still didn't solve the problem. Then I uninstalled the software altogether and the problem persists. Common EVGA help a customer out.
    • Ribbons : 115
    Re: Flow Control LED Problems 2017/09/20 20:14:31 (permalink)
    You may need to call tech support on that.
                My Affiliate Code: 8WEQVXMCJL
     &nbsp
