geswek
- Ribbons : 9
Anyone have thoughts on how to fix the random error at "wake" that reports CPUWB not found. I usually reboot computer and all is well--but not sure what in my sleep mode is causing Flow to lose communication with the waterblock. It is connected to the internal USB header on the motherboard.
Fractals [build thread] [heatware]Case & PSU: Fractal Meshify C Mini Dark · EVGA SuperNOVA 850 G3 System Core: I7-8700K 5GHz @ 1.330v · EVGA Z370 Micro · 32GB Corsair Dominator Platinum DDR4-3200 16-18-18-35Storage & OS: Samsung 960 EVO 500GB NVMe · Western Digital Caviar 1TB · Windows 10-64bit Pro Multimedia: EVGA RTX 2080ti XC Hybrid · Dell Ultrasharp 27in Gaming · SteelSeries Arctis 7 Watercooling: EVGA CLC 240 AIO CPU
- Ribbons : 282
Re: Flow Control: CPUWB Not Found
2019/02/23 18:44:30
Is Sleep Turned Off on your USB Ports? This is under Device Manager
post edited by bcavnaugh - 2019/02/23 18:47:25
geswek
- Ribbons : 9
2019/02/23 18:46:16
bcavnaugh Is Sleep Turned Off on your USB Ports?
I looked under profile and I see; USB selective suspend setting: enabled That is only thing referencing USB that I can find in the profile.
- Ribbons : 282
2019/02/23 18:48:00
"USB selective suspend setting: enabled" I would set this to Disable
geswek
- Ribbons : 9
2019/02/23 18:50:00
Ok; I did that so I'll give it a try -- my wife has the same cooler and she has same error at times. Also; my Generic USB Hub does have check on "allow computer to turn off this device."
- Ribbons : 282
2019/02/23 21:12:52
I turn this Off or Un-Check it on All my USB Items "allow computer to turn off this device." in Device Manager. You may want to check all of them in Device Manager. No Sleeping on my Watch...
geswek
- Ribbons : 9
2019/02/27 05:18:43
I turned off those settings and no dice--I just woke up my computer and got the error. The only way to get control of waterblock back is to reboot machine.
coolmistry
- Ribbons : 45
2019/02/27 10:22:47
Sometime happen to me after restart the Windows that pop up 'Device not found' unknown why. Try go open Task Scheduler and find Task Scheduler Library > EVGA Flow Control on the right 'Action' click 'End' and restart click 'Run' it should fix your Flow Control work. Post us back how getting on
Windows 11 Home 64bits up to Dated i9 11900K 5,275 MHz (3,500 MHz) || EVGA Z590 FTW WIFI || 2 x Nvidia RTX 2080 Ti FE || 32Gb Dominator Platinum DDR3 3600mhz XMP OC 3800mhz || 500gb Samsung 980 Pro NVMe || 500gb Samsung 970 EVO and Sata M.2 (1 x SSD and 1xHHD) || EVGA CLCx 360 Cooler || EVGA Supernova 1300w X3 || EVGA Z10 Keyboard || EVGA TORQ X10 mouse ||EVGA DG 77 case || Acer Predator X35 35" 200Hz G-Sync || Logitech Z906 5.1 system sounds SPDIF|| Kaspersky Internet Security
geswek
- Ribbons : 9
2019/02/27 11:06:50
coolmistry Sometime happen to me after restart the Windows that pop up 'Device not found' unknown why. Try go open Task Scheduler and find Task Scheduler Library > EVGA Flow Control on the right 'Action' click 'End' and restart click 'Run' it should fix your Flow Control work. Post us back how getting on
It only happens when the computer comes out of sleep; not when it's been powered completely off or rebooted.
coolmistry
- Ribbons : 45
2019/02/27 11:30:36
geswek
Same here.. only way to restart in Task scheduler that Flow Control is working again....
geswek
- Ribbons : 9
2019/02/27 11:32:05
coolmistry
geswek
AH; I got you -- you restart it in task scheduler instead of just rebooting your computer? I've been just doing a reboot for it to recover.
coolmistry
- Ribbons : 45
2019/02/27 11:34:29
Not really it happen very few times not all the time so right now so far seem okay no more pop up 'Device not found' restart Windows is okay but next few days it happen... that why I start wonder why...
coolmistry
- Ribbons : 45
2019/02/27 11:43:09
AH; I got you -- you restart it in task scheduler instead of just rebooting your computer? Sorry I miss this.. Yes it no need reboot your PC just use Task Scheduler to restart Flow Control that it..
