Flow Control 2.0.9.0, is there any way to move the top node in custom fan adjustment?
JimBeamBlack
2019/08/12 15:21:58 (permalink)
 Hey guys, is there any way to move that top node on the Curve/Enable Custom Fan Control graph?
 I would like to slide that top node down or over to make a smoother fan profile, as it is now no matter what you do it's almost straight up.
thanks
EVGA Z590 Dark ; i9 11900k ; 32gig Corsair Vengeance DDR4 3600 ; EVGA 3080 FTW Ultra3 ; Creative AE-7 ; Win 11 64bit Pro : EVGA 1200 Plat PSU
3 Replies Related Threads
    bdary
    • Ribbons : 116
    Re: Flow Control 2.0.9.0, is there any way to move the top node in custom fan adjustment? 2019/08/14 13:24:09 (permalink)
    If I'm understanding what you're asking, just click and hold any of the small squares in the graph(s) and drag them up/down and left/right to your desired setting.
    JimBeamBlack
    Re: Flow Control 2.0.9.0, is there any way to move the top node in custom fan adjustment? 2019/08/14 18:18:23 (permalink)
     Actually I'm talking about this one right here: (see picture)
    And I have tried right clicking, left clicking, clicking above it under it around it....it won't select.
    bdary
    • Ribbons : 116
    Re: Flow Control 2.0.9.0, is there any way to move the top node in custom fan adjustment? 2019/08/15 05:38:27 (permalink)
    Are you able to move any of the other squares?  You may need to uninstall the software and remove any profiles you have then reinstall.  You should be able to drag the set points around under normal conditions.
    Did you create this custom fan curve or is it a preset curve?  I've never used this software specifically, but all these custom fan curve editors work basically the same way.  I was thinking that if this is a preset curve, you may not be able to modify it, but if you can move any of the squares on the curve, you should be able then to move the top one.
