First Time Water Cooling Build Thermaltake
Fuzzypunks
2019/12/10 09:24:02 (permalink)
New to the boards and I'm currently building my first "real" rig. i am using the Thermaltake 20 GT RGB case, Gigabyte z390 motherboard, 9900kr chip, 4133 patriot memory, EVGA Kingpin Card (currently looking for EVGA Kingpin hydro copper water block as I don't have yet) Bykski Kingpin water block, Thermaltake custom water cooling kit with a 360 and 420 radiator both over 60mm thick and a ton of Thermaltake ring 2 fans. I am a little disappointed that the case cam with 2 usb 3.0 connectors and most motherboards only have 1 USB 3.0 connector and I don't have a solution to fix this. Please give any advice on this as I'm currently getting parts in and about to build it. Also this is my first time doing water cooling so any advice there is very welcome also. Thanks!
Use my Associate Code to get great deals on EVGA Products. Use it at Checkout!
MVELW6K047QP0BC
9 Replies Related Threads
    flyinion
    • Ribbons : 8
    Re: First Time Water Cooling Build Thermaltake 2019/12/10 09:48:59 (permalink)
    There are adapters out there that can allow you to plug a USB 3.0 header cable into a USB 2.0 header.  I was looking for something similar myself after deciding on a board that only had 1 USB 3 header on it.  Unfortunately I can't recommend anything because I haven't bought anything yet.  The few things I found on Amazon and Newegg were littered with poor reviews about falling apart or causing shorts and damaging the header on the board (along with the usual "works great" type reviews)  Since they were all from unknown brands I really didn't want to take the chance right now and decided to hold off.
    AMD Ryzen 5950X | Asus Crosshair VIII Hero | Gigabyte Gaming OC 4090 w/EK Vector2 | GSkill Trident Z Neo 2x16GB DDR4-3600 | WD SN850 2TB | Samsung 970 EVO Plus 500GB & 860 Evo 2TB | Phanteks Enthoo 719 | Seasonic Prime Ultra Gold 1000W | Steelseries M750 TKL | SteelSeries Prime Wireless | SteelSeries Arctis Pro + GameDAC | Kanto YU2 + Yamaha sub | Schiit Magni 2 Uber & Modi 2 Uber | LG 34GN850 | Asus PG279Q | Win 11 Pro | Custom water loop
    Fuzzypunks
    Re: First Time Water Cooling Build Thermaltake 2019/12/10 11:22:15 (permalink)
    Is there a usb 3.0 to usb C converter as I am out of USB plugs but I do have that plug still available.
    MVELW6K047QP0BC
    flyinion
    • Ribbons : 8
    Re: First Time Water Cooling Build Thermaltake 2019/12/10 11:26:56 (permalink)
    Fuzzypunks
    No idea, never tried to look for one.  My board has a USB C header so it wasn't an issue.
    GTXJackBauer
    • Ribbons : 48
    Re: First Time Water Cooling Build Thermaltake 2019/12/10 12:18:38 (permalink)
    If you need more internal USB headers, look at the HUBBY7.  Great device as I use two of them chain back to back since my MB only has 1 USB 2.0 header.  I know shocking. lol
    If you need more external USB 2.0 headers, just grab a simple hub.  This is the one I use and works great.
    LMD3DNZM9LGK8GJ
    Fuzzypunks
    Re: First Time Water Cooling Build Thermaltake 2019/12/10 12:38:44 (permalink)
    I bought the NZXT USB 2.0 hub just in case as it looked like it was good quality. That's great info GTX thank you!
    MVELW6K047QP0BC
    Fuzzypunks
    Re: First Time Water Cooling Build Thermaltake 2019/12/10 12:43:07 (permalink)
    It just sucks not being able to use all of the USB plugs on the case due to this whole case having two usb 3.0 plugs.
    MVELW6K047QP0BC
    flyinion
    • Ribbons : 8
    Re: First Time Water Cooling Build Thermaltake 2019/12/10 16:08:59 (permalink)
    Fuzzypunks
    It's not the case's fault though, many motherboards have 2xUSB3 headers but it's a newer thing (and only newer case designs support it).  MSI and ASRock both have Z390 boards with dual USB 3 headers.  Gigabyte has them for X570 (and maybe MSI I don't remember offhand).  I was originally going to go with the Gigabyte X570 Master but ended up with the Asus.  I didn't lose out on ports overall, they just moved them to the rear I/O instead of an internal header but yeah now I have a set of unusable front panel ports myself.  Like I said, I'd totally buy a USB 2 header to 3.0 front panel adapter if I could find one that is for sure reputable, but I'm not really looking to blow up a $350 motherboard with a $10 adapter cable of questionable quality.
    blaise
    Re: First Time Water Cooling Build Thermaltake 2019/12/12 08:39:45 (permalink)
    flyinion
    Fuzzypunks
    Yeah, my Phanteks Enthoo 719 (nee. Luxe 2)  has 4 x USB 3.0 & 1 x USB type-C front ports. I tried using a USB 2.0 -> 3.0 adapter on my Z370 Classy but no devices registered when I plugged USB keys in. The end result was I simply ordered a couple USB 2.0 silicon dust caps from Amazon to plug the non connected 3.0 ports and save any confusion. Not really an issue as I cannot see a point where I absolutely- positively need more than 2 devices plugged in at once and if that became an issue, I can quite easily access the rear USB ports.
    Hoggle
    Re: First Time Water Cooling Build Thermaltake 2019/12/12 08:44:52 (permalink)
    Would you consider a PCI-e 3.0 expansion card with an internal header? Just make sure to get a powered one and you should be good to go since you could use the internal motherboard header for one and then the PCI-e card for the second one.
