yaggaz
After letting the box sit next to my PC for three weeks I finally kicked myself in the teeth and forced myself to install it today. Boy am I glad I did. I let it run on Extreme/Max settings using Uniengine Heaven for a couple hours and the temps hovered around 45c to 48c, that seems amazing to me, although I still have the side off. Back when I benchmarked my 2080 Super using Heaven the results were: Average FPS: 136.7 Score: 3443 Temps: 69c On the exact same test with my 3080, Temps: 45c to 48c With the pessimistic moods I've been in lately I feel like this is too good to be true, that something wasn't reading right. That's a 70% increase in performance right? Edit: I suspected real world gaming would be the best test. Borderlands 3 in game benchmark ran at average of 80fps on the 2080, now 109fps on the 3080. But that game is a resource hog.
post edited by yaggaz - 2022/01/23 17:39:01
|| CPU: Intel 10700k || GPU: evga 3080 XC3 Ultra Hybrid || MB: Gigabyte z490 UD AC || RAM: 2 x 16GB 3000mhz DDR4 SDRAM || Samsung EVO 970 Plus 2TB || Dell S2417DG Monitor || Soundblaster AE-7 || Phanteks p400a Case || be Quiet! Dark Rock Slim CPU Cooler || Corsair AX1600i PSU || 9 Fans total in system ||
andross182
Re: Finally installed my 3080 Hybrid
2022/01/22 19:44:34
those are insanely low temps for a 3080 hybrid. What is your ambient tempature? My 3080 and 3080ti hybrids both were 60c with fans going full tilt as their max temp. I didnt drop into the 45-50c range till I got my hydro copper 3080ti and did a full custom loop.
GTXJackBauer
- Ribbons : 48
2022/01/22 19:57:21
yaggaz After letting the box sit next to my PC for three weeks I finally kicked myself in the teeth and forced myself to install it today. Boy am I glad I did. I let it run on Extreme/Max settings using Uniengine Heaven for a couple hours and the temps hovered around 45c to 48c, that seems amazing to me, although I still have the side off. Back when I benchmarked my 2080 Super using Heaven the results were: Average FPS: 136.7 Score: 3443 Temps: 69c On the exact same test with my 3080, Temps: 45c to 48c
Awesome and congrats! Told ya you'd like it. I think these GPUs chew through Unigine Heaven. You'll have to put it through 3DMark if you wanna push it some more and see the temps you get there. andross182 those are insanely low temps for a 3080 hybrid. What is your ambient tempature? My 3080 and 3080ti hybrids both were 60c with fans going full tilt as their max temp. I didnt drop into the 45-50c range till I got my hydro copper 3080ti and did a full custom loop.
I think it's based on the benchmark he used but those temps can be achievable if you have very cool ambient temps, amazing airflow, fan replacements, cable management, etc, etc. Usually you'll see folks with Hybrids in the 50c range and custom in the 40c range if they have a proper loop. I also have seen some upgrade their 240mm hybrids by replacing the fans with premium rad fans in push and pull and reach high 40s before.
post edited by GTXJackBauer - 2022/01/22 19:59:24
yaggaz
2022/01/22 20:25:57
I should add this is 1440p, not 4k
yaggaz
2022/01/22 20:38:22
GTXJackBauer Awesome and congrats! Told ya you'd like it. I think these GPUs chew through Unigine Heaven. You'll have to put it through 3DMark if you wanna push it some more and see the temps you get there.
Thanks Okay what about Unigine 2.0, Superposition? That's more for modern cards yeah? Did the 8k optimised test:
GTXJackBauer
- Ribbons : 48
2022/01/22 21:56:46
yaggaz
2022/01/22 22:55:41
GTXJackBauer Looks good. You sure it's not in a custom loop?
lol it's weird that no matter what load I throw at it, what game I play, what benchmark I run it doesn't go over 48c. Can these GPUs incorrectly report temps?
NereusHixon
2022/01/23 00:10:30
I am also curious to know how are you getting temps < 50c. My 3080Ti hybrid has never seen temps below 65c @ 100% load.
yaggaz
2022/01/23 02:26:42
NereusHixon I am also curious to know how are you getting temps < 50c. My 3080Ti hybrid has never seen temps below 65c @ 100% load.
Yes something is nagging at me about this. When I tried the 8k load test above it still refused to go over 48c, almost as if it's maintaining that speed by throttling FPS. I thought about disconnecting the fans and running the test again but that feels very risky. Does anybody know of a specific test/benchmark that shows how hot your GPU can get?
GTXJackBauer
- Ribbons : 48
2022/01/23 07:07:43
yaggaz
3DMark and GPUz for temps. Being a 3080 HYBRID (240mm), the less power hungry GPU compared to its bigger brothers plays a role in those temps you're getting in good ambient temps, airflow and case, etc, presumably speaking since I don't know what your ambient temps, etc are.
post edited by GTXJackBauer - 2022/01/23 07:09:00
03whitegsr
2022/01/23 08:33:49
Sounds like you are on the stock fan curve on the normal switch position? I don't think the fans turn in until 60C. Setting a custom fan speed curve in afterburner overrides the "silent fan mode" the card uses. With the XC3 3080, I would see high 40s on the hybrid under full load (340W). The FTW3 3080Ti puts it more around mid 50s but that's with 80W more power being cooled.
yaggaz
2022/01/23 14:44:35
GTXJackBauer 3DMark and GPUz for temps.
Played Fallout 76 on max settings for two hours and GPU-Z records highest temp as 48c. Surely there must be throttling going on???
post edited by yaggaz - 2022/01/23 14:50:31
GTXJackBauer
- Ribbons : 48
2022/01/23 15:20:31
yaggaz
No where near throttling unless you get way up there in temps like shutting off the fans (don't do it). lol
yaggaz
2022/01/23 15:30:45
GTXJackBauer
yaggaz
I'll take your word for it and drop the "This feels too good to be true" worry lol
benjamingreen22
2022/01/23 16:21:56
Just finished my RTX 3080 FTW Ultra conversion, for anyone who is wondering, it wasn't that difficult. Surely a little time-consuming, but everything works as it should. Did the BIOS updates, fans are working perfectly and running at 450W.
CPU:i7 9700K @ 5.4GHz Motherboard: Aorus PRO z390 RAM: TridentZ 32GB @ 3866Mhz GPU: EVGA RTX 3080 FTW Ultra FHR (Hybrid Kit) COOLING: NZXT Kraken X72 360mm STORAGE: 970 EVO (500GB,1TB)
rjbarker
- Ribbons : 21
2022/01/23 16:24:09
Yeah odd on temps....my Custom Loop w 3 Radiators will max 43c - 46c looping Heaven....
rjbarker
- Ribbons : 21
2022/01/23 16:27:07
Try running HWinfo sensors....something isnt right if your Card never exceeds 49c ..."its a miracle" ;) Or try running Kumbuster.... I'll try looping Heaven and see what I get.....I know it never exceeds 47c....once it did and I pulled Water Block apart and re-installed....chaulked that up to re-using little plastic washers that were already squashed. These are 12900K 5.2P / 4.1E OC DDR5 6000 C36 3080Ti +120 / +725 Heaven Benchmarks I always run 2560*1440p 8xAA Full Screen Ultra / Extreme as is below. I recall my Heaven Benchmark was higher with this same Card running W10....I'm on W11 21H1, obviously the Heaven Score isnt really representative running W11 Fairly large loop, 480*360*240 Rads..all Noctua High Static Pressure Fans 3080Ti w EK Vector Block....
post edited by rjbarker - 2022/01/23 17:20:54
yaggaz
2022/01/23 17:31:34
rjbarker Try running HWinfo sensors....something isnt right if your Card never exceeds 49c ..."its a miracle" ;) Or try running Kumbuster....
Okay looking at your results something is really bizarre here. Did they put a 3090 ti in mine and sell it as a 3080 lol? Seriously though, how can a 3080 Hybrid possibly beat a 3080 ti with the type of loop you have in FPS, score and temps on Heaven. Now if it WAS throttling to keep the temps at that level, the score and FPS would drop. Mysteries, I must solve them... Downloading kombuster
rjbarker
- Ribbons : 21
2022/01/23 17:34:28
yaggaz
Cause you had AA disabled...those runs above are with AAx8 Look under Mode: 2560*1440p AAx8 in my first scores.... Below is with AA disabled, as you had yours (I always run Heaven maxed out, but in all honesty don't really use it anymore other then for a quick test of my GPU temp, as its very old DX11 Test)..
post edited by rjbarker - 2022/01/23 17:36:16
yaggaz
2022/01/23 17:40:23
Ah okay that solves the FPS question, but still not the temps.
rjbarker
- Ribbons : 21
2022/01/23 17:46:46
yaggaz Ah okay that solves the FPS question, but still not the temps.
Yeah no idea ....Im quite "intimate" with my loop / temps and know exactly when they arent right....generally a quick Heaven loop for 10 min lets me know whether or not I have a good "seat" on my GPU Block...provided I peak at 46/47c Im golden....if I see into the low 50's I know something isnt quite right. My Max temp on my 3080Ti playing any game or any benchmark is 46c/47c.....if ambient temp is cooler than 20c it will drop in temp as ambient drops. Try playing a AAA title and see if your GPU gets above 49c....it should....especially if fans are only ramping up to 65-75%.....if it "Never" goes above 49c...I would think perhaps a sensor isnt quite right....have you ran PX1 and flashed fw / vbios? You could also throw Port Royal and Timespy at it....Kumbuster will max out your Power Draw....so should see temps higher than 49c there as well......if not you either have a GPU sensor not reading correctly or an amazing Hybrid Card :) Enjoy your 3080.....I had one previous to this 3080Ti and in all honesty if I had to do this all over again I would have kept the 3080 and passed on the Ti version. Great Cards!
post edited by rjbarker - 2022/01/23 17:51:06
kevinc313
- Ribbons : 22
2022/01/23 17:52:47
Not enough information. You need to monitor your card and other parameters as you run it. Stop posting Heaven results and GPU-Z max figures, that's not useful. Post readable plots of power, temp, fan speed and clock from HWiNFO or AB or X1, under a heavy gaming or benchmark load. Heaven at 1440P is a light load. What is the ambient temp and case config? Should be no problem for the 240mm hybrids to run at under 50C at 325w constant.
post edited by kevinc313 - 2022/01/23 18:03:57
yaggaz
2022/01/23 17:53:15
rjbarker Yeah no idea ....Im quite "intimate" with my loop / temps and know exactly when they arent right....generally a quick Heaven loop for 10 min lets me know whether or not I have a good "seat" on my GPU Block...provided I peak at 46/47c Im golden....if I see into the low 50's I know something isnt quite right. My Max temp on my 3080Ti playing any game or any benchmark is 46c/47c.....if ambient temp is cooler than 20c it will drop in temp as ambient drops. Try playing a AAA title and see if your GPU gets above 49c....it should....especially if fans are only ramping up to 65-75%.....if it "Never" goes above 49c...I would think perhaps a sensor isnt quite right....have you ran PX1 and flashed fw / vbios?
Yep I know exactly what you're saying when you know your system and something doesn't feel right. Below was the test with AA on this time, but I was watching the temps and it was furiously flicking between 48/49 the whole time, so either sensor is off or it's throttling? I'm a bit worried about the PX1 thing as well. I do have TPM disabled but there is absolutely no option anywhere to disable Fast Boost, although that could mean it doesn't have it at all. But I'll check it out and see what it's saying. Is there an average difference between GPU and mem temps? Because mem is 70c when GPU is 48
rjbarker
- Ribbons : 21
2022/01/23 18:06:10
kevinc313 Not enough information. You need to monitor your card and other parameters as you run it. Stop posting Heaven results and GPU-Z max figures, that's not useful. Post readable plots of power, temp, fan speed and clock from HWiNFO or AB or X1, under a heavy gaming or benchmark load. What is the ambient temp and case config? Should be no problem for the 240mm hybrids to run at under 50C at 325w constant.
^^^^ See here.....also as I said check out temps running Kumbuster...PR...TS or simply gaming on a AAA Title..CP77....Red Dead Redemption 2 or Valhalla......Shadow of Tomb Raider....all but CP77 have built in benchmark capabilities. Heaven is far to old to get a handle on things (DX11).....
GTXJackBauer
- Ribbons : 48
2022/01/23 18:10:45
rjbarker
Been custom liquid cooling for 10 years now. HYBRIDs have come along way with more rad, newer pumps, better rad fans to choose from, etc. that I will be making the switch to minimalize the current setup I have. I've had my fun and now looking to move on, mainly because I don't have the bug anymore, dread tear downs for hardware changes, breakdowns, etc. While AIOs have come closer to custom temps with a larger selection to choose from, custom is still great for it's customization and not have the limitations AIOs have. Because of the use of 240mm rad for Hybrids, you will see more folks with high 40c and 50c+ range in temps. It depends on the GPU used and a few other things to account. 120mm I always felt wasn't enough and most were iirc in the 60c+ range which was still great for what it was compared to on air at 80c+. P.S. - Yaggaz, stop overthinking it and stop using old benchmarks. Your temps are fine for what you're doing. Have steam? If yes, get 3DMark or wait till its on sale.
post edited by GTXJackBauer - 2022/01/23 18:12:55
fugly16
2022/01/24 06:01:57
GTXJackBauer
rjbarker
I agree, use 3dmark and go with Timespy and Port Royal benchmark tests.
3080 FTW3 Ultra Hybrid
rjbarker
- Ribbons : 21
2022/01/24 13:21:40
GTXJackBauer
rjbarker
Agreed...I have been under water since 2013....this present build will be my last "Full Custom Loop" as well....done moving around my 60 lb 900D !!! Im quite sure the OP will definitely see temps in excess of 49c once he starts "laying the boots to that GPU"....no doubt!
post edited by rjbarker - 2022/01/24 13:22:53
yaggaz
2022/01/24 22:30:06
Okay so fired up AC Valhalla and played it for 2 hours on Extreme settings, every graphic option set to it's highest, then monitored it in HWMonitor. (I don't have those other benchmarkers...yet) Watching the UI with MSI it still sat at average of 48c, HWMonitor caught a maximum spike of 53c at one point. 348 maximum wattage. It seems to be fine. What does "Temperature Limit" and "Reliable Voltage Limit" at 1 under max mean? If anybody can see anything else odd in this data? Thanks.
GTXJackBauer
- Ribbons : 48
2022/01/25 00:58:49
yaggaz (I don't have those other benchmarkers...yet)
Found it on sale here.
kevinc313
- Ribbons : 22
2022/01/25 05:27:13
Those logs seems normal, but again, peak values don't really tell you much. If you were pegged at 350w for 10 minutes and hit 53C with 1700rpm fans, that's pretty good cooling performance. But maybe you were hovering around 250w and just had a few power spikes to 350w, for you be peaking at 53C is kinda poor. The Hybrid cooler is a mass of water that takes a little while to warm up. You can hit the GPU with 500w for 10 seconds and the temps won't go above 40C. What matters is sustained average or a plot. You need to start a game, get into a sustained high load scene for several minutes, RESET LOGGING, then run it for about 10-15 minutes in the high load scene and report the *AVERAGE* TEMP, CLOCK, POWER LEVEL and FAN SPEED. Use OSD to watch those parameters live.
