random_matt
Anyone have a fix for the X299 bios concerning fan speeds? Locked at 1480RPM, my Noctuas do 2000RPM and max setting changes nothing.
Corsair 5000D Airflow | EVGA 1000 G6 | EVGA X570 FTW | Ryzen 5800X | EVGA 360 CLC | Corsair 4000MHz 32GB| Corsair MP600 2TB | EVGA 3080 Ti FTW Hybrid | Alienware AW2721D | Windows 11
EVGA_Lee
Moderator
- Ribbons : 14
Re: Fan speed
2020/01/14 13:37:43
Need more information. Which BIOS are you on, which Noctua fans are you using, and which fan headers are you using? Can you give me a screenshot of your BIOS with the fan configuration?
random_matt
Re: Fan speed
2020/01/14 14:34:16
EVGATech_LeeM Need more information. Which BIOS are you on, which Noctua fans are you using, and which fan headers are you using? Can you give me a screenshot of your BIOS with the fan configuration?
X299 M-ATX 2 - Bios is the one before the newest. NF-A12x25 x 3 on CLC 360. Using the splitter from the pump. However, I may return them to amazon anyway, the FLX are cheaper and I get a full refund to my account.
EVGA_Lee
Moderator
- Ribbons : 14
Re: Fan speed
2020/01/14 14:38:39
Ah. If you're using the pump to drive the fans, that will probably explain why your fans are running at a lower speed. If you ran them directly off the motherboard, the speed shouldn't be an issue.
random_matt
Re: Fan speed
2020/01/14 14:43:57
EVGATech_LeeM Ah. If you're using the pump to drive the fans, that will probably explain why your fans are running at a lower speed. If you ran them directly off the motherboard, the speed shouldn't be an issue.
Why do they only run the way they do off pump? Will non-pwm do the same of the splitter?
EVGA_Lee
Moderator
- Ribbons : 14
Re: Fan speed
2020/01/14 14:56:41
☼ Best Answerby Cool GTX 2020/01/15 06:45:35
random_matt
Because the CLC ultimately controls the fans, not the motherboard. The motherboard fan header should be at 100%/Max (as opposed to auto or SMART) to make sure the CLC is recognized and operates properly, but that doesn't really affect the fan speed. You could try adjusting the fans through Flow Control first, if you haven't already, to see if the fan speed will go higher. Otherwise, the motherboard fan headers will recognize the fans and treat them properly. Pretty much all of the fan headers are auto PWM/DC, so they will detect which type it is and set the speed according to PWM or voltage.
random_matt
Re: Fan speed
2020/01/14 15:40:02
EVGATech_LeeM
random_matt
So buying the non-pwm version wouldn't make a difference? Was trying to save using more cables, I'll buy some if my idea does not work.
coolmistry
- Ribbons : 45
Re: Fan speed
2020/01/15 05:29:57
☄ Helpfulby Cool GTX 2020/01/15 06:46:29
For your EVGA X299 M-ATX 2 you have PWM fans header and CPU1 and CPU2. You can put cooler pump pin on to PWN fan and set 100% speed for pump and those two CPU fan and CPU2 headers you can plug 3 NF-A12x25 pins together on to CPU1 fan header because you have 1 amp per fan headers page 40 therefore your NF-A12x25 draw is 0.14amp that mean you can use 3 x NF-A12x25 fans 0.14amp x 3 = 0.42amp that plenty left for 1 amp. You can use 6 fans split 3 each cpu1 and cpu2 for push and pull for your cooler radiator! Make sure less than 1 Amp is safe! I don't use EVGA Cooler software cos the problem with fans too high loud!! Have a look my post #4 here what I did on my Rig!
Windows 11 Home 64bits up to Dated i9 11900K 5,275 MHz (3,500 MHz) || EVGA Z590 FTW WIFI || 2 x Nvidia RTX 2080 Ti FE || 32Gb Dominator Platinum DDR3 3600mhz XMP OC 3800mhz || 500gb Samsung 980 Pro NVMe || 500gb Samsung 970 EVO and Sata M.2 (1 x SSD and 1xHHD) || EVGA CLCx 360 Cooler || EVGA Supernova 1300w X3 || EVGA Z10 Keyboard || EVGA TORQ X10 mouse ||EVGA DG 77 case || Acer Predator X35 35" 200Hz G-Sync || Logitech Z906 5.1 system sounds SPDIF|| Kaspersky Internet Security
coolmistry
- Ribbons : 45
Re: Fan speed
2020/01/15 05:30:19
random_matt
EVGATech_LeeM
random_matt
I agree!
random_matt
Re: Fan speed
2020/01/15 05:39:34
coolmistry For your EVGA X299 M-ATX 2 you have PWM fans header and CPU1 and CPU2. You can put cooler pump pin on to PWN fan and set 100% speed for pump and those two CPU fan and CPU2 headers you can plug 3 NF-A12x25 pins together on to CPU1 fan header because you have 1 amp per fan headers page 40 therefore your NF-A12x25 draw is 0.14amp that mean you can use 3 x NF-A12x25 fans 0.14amp x 3 = 0.42amp that plenty left for 1 amp. You can use 6 fans split 3 each cpu1 and cpu2 for push and pull for your cooler radiator! Make sure less than 1 Amp is safe! I don't use EVGA Cooler software cos the problem with fans too high loud!! Have a look my post #4 here what I did on my Rig!
Hmm, thought the pump ran at 100% anyway on the CPU headers. I'll mess around and see what happens. I gave up on EVGA software, barely any of them work, Eleet broke a long time ago and flow never opens for me.
coolmistry
- Ribbons : 45
Re: Fan speed
2020/01/15 05:46:47
random_matt
Yeah I don't use software because you can use this for changing led setting and Fan curve but it will save setting into pump firmware then no need software after as we have fans control on our motherboard!! Give a go and test! You will happy it more quiet using motherboard fan control rather software!!
