Sport Wagon
Greetings, Is there a way to control the fan headers (case fans) on the MOBO other than BIOS? via software?
Nereus
Captain Goodvibes
- Ribbons : 58
Re: Fan Control (Case Fans)
2021/08/13 21:35:31
I'm a little surprised EVGA have not added access to bios fan control from inside Windows via their Eleet X1 software, but ¯\_(ツ)_/¯. Depending how far you want to go and what sort of fans you have, the top end is probably using Corsair iCue software with their Corsair Commander Pro [ link]. There are apparently 3rd party software apps that may work, but I can't speak for reliability or that they might even damage your motherboard, but here's one I found online - SpeedFan for Windows [ link].
post edited by Nereus - 2021/08/13 21:36:40
Sport Wagon
2021/08/13 22:23:18
I tried SpeedFan, it showed the two headers I ha Submit Postve fans attached to, but I couldn't get them configured when messing with the advanced settings...ref old Jayz2cents video.
frankd3
- Ribbons : 14
2021/08/14 04:31:32
Here's one I was thinking of trying when I finally get my system up and running. I'm planning on using it to tie the case fans to GPU temp. Argus Monitor. https://www.argusmonitor.com/
post edited by frankd3 - 2021/08/14 05:23:43
- Ribbons : 84
2021/08/14 04:43:12
I have a 5000X chassis using iCUE to control the RGB and case fans.
Sport Wagon
2021/08/17 10:20:05
I've tried both argus and speedfan. No luck with either. Argus did show the EVGA CLC, but no love with with the mobo fan headers.
Sport Wagon
2021/08/17 10:22:21
rjohnson11 I have a 5000X chassis using iCUE to control the RGB and case fans.
Thanks! I'll give this a try.
- Ribbons : 84
2021/08/17 10:28:45
Sport Wagon
I set my fans at 50 percent using iCUE. So far I haven't had a need to exceed that even at full GPU/CPU load. If you're in a hot temperature state/country you might ned to take that setting higher than mine.
Sport Wagon
2021/08/17 11:01:03
I'm not seeing fan control....? Are you using iCUE and a commander? or Just iQUE software? Nevermind...you have a 5000X. I'm in a O11D XL. rjohnson11
Sport Wagon
post edited by Sport Wagon - 2021/08/17 11:05:08
Sport Wagon
2021/08/31 17:27:49
Has anyone been able to get Argus Monitor to work on the Z590 FTW3?
frankd3
- Ribbons : 14
2021/09/01 04:54:48
Sport Wagon Has anyone been able to get Argus Monitor to work on the Z590 FTW3?
Haven't been able to try yet. Graphics card is on the way but it will be a little while before I can start testing.
cristian0215
2021/09/19 06:55:33
Has anyone tied using Fan Control by Rem0o? I remember it would work with my asus z590 I returned but doesn’t seem to be detecting the fans on my FTW z590.
