FTW-K stability and boot problems issues linked to USB
man114
2021/06/17 05:12:54 (permalink)
I’ve had numerous issues with stability on this board that were hard to pin down because of their randomness, to the point where even a CMOS battery was suggested. Well I think I’ve pinned it down to the USB.
My configuration as it currently stands is 9820x, 64gb RAM, XFX 6900xt, nu audio, WD sn730 256gb boot drive, team 1tb SATA m.2 PSU is one of the many EVGA ones I’ve bought from a sale, I think it’s a GQ 850w.
Most of these problems have persisted though several hardware changes. The video card I switched out from a 1070ti recently.
I finally isolated this when using an external USB SSD. From a cold shutdown the PC never boots without some sort of blue screen. Well when you added the USB SSD you trigger some random sequence of beep codes at post. Through a bunch of testing I’ve concluded this all has something to do with the USB. Usually I’ll have a wifi, keyboard, mouse, and controller plugged in. What seems to throw it for a loop is switching what port the USB devices are plugged into. While it beeps a bunch doing this it doesn’t ever freeze with a code, it instead boots to windows then freezes or on occasion black screens with no video. Most of the time it works on the reset. Worst case I have to unplug all USB stuff, plug it back in at the log on screen or just the mouse then reboot.
It’s like it can’t sync the USB devices during the POST sequence. The closest comparison I can offer is I have a bunch of JBOD HDD docks hooked to one of my media computers and if the drives occasionally don’t seem to sync properly despite assigned drive letters then go offline.
I did the resizable bar BIOS upgrade but was only whatever BIOS the board shipped with since got it prior to that.
But I’m out of ideas what to do to try and correct it. Other than just resetting it whereas once it works it works fine.
post edited by man114 - 2021/06/17 05:13:59
3 Replies Related Threads
    wmmills
    • Ribbons : 40
    Re: FTW-K stability and boot problems issues linked to USB 2021/06/17 07:01:35 (permalink)
    Other than going through the bios settings to make sure you have it set to auto or at least allow legacy detection, windows power options for the usb selective suspend and make sure its disabled. Ive had issues with usb devices messing up my boots also, but usually its because of a cell phone or a backup battery for cellphones that i have thats made by Coolermaster called a powerfort. Every once in awhile it makes it crazy and i have to unplug it.
    MOBO: EVGA x299 Dark, CPU: I9 10900X, RAM: Patriot Viper RGB 3600 32gb, SSD: Samsung 860 EVO 1TB, M2: Samsung 970 EVO+ 1TB, PSU: CoolerMaster M2 1500, CPU HSF: EVGA 240 CLC HSF~ P/P EK Furious Vardar, G-CARD:EVGA RTX3090 FTW3 Ultra Gaming w/Hybrid kit and Noctua IPPC 3000 P/P, CASE: LIAN-LI PC-V2010B w/ Window mod, OS: Windows 10 Pro 64bit, MON: Alienware AW3821DW
     New EVGA product? Register it NOW with this link:
    http://www.evga.com/register/default.asp?affiliatecode=4QFQRAMOII
     Help Our Vets From K-2!
    [link=https://strongholdfreedom
    ZoranC
    • Ribbons : 16
    Re: FTW-K stability and boot problems issues linked to USB 2021/06/17 10:17:40 (permalink)
    Aside USB options wmmills pointed out have you considered possibility it isn't motherboard but your USB SSD is not compatible / functioning properly and tried using different model?
    Hillguy
    • Ribbons : 10
    Re: FTW-K stability and boot problems issues linked to USB 2021/06/17 14:59:47 (permalink)
    Have you counted the beeps to see what they mean ?  Beep codes are on pg.141 of the owners manual     https://www.evga.com/supp.../files/142-SX-E297.pdf
    eVGA RTX 3090 Kingpin Hydrocopper | eVGA X299 Dark | Intel i9 10980XE | Heatkiller IV CPU Block | 32 GB GSkill Trident Z 3200  | 500GB Samsung 860 Evo | Dual Corsair AX1200i PSU's | Dual Koolance RP-1000 Pumps | Dual Koolance EHX-1320 4x120mm Rads | W10 | Asus PB278Q | Acer 20" | Razer Death Stalker | Razer Death Adder | Thermaltake Armor+
