FTW3 max Power is 373W (150%)
striker890
2018/09/29 02:38:56 (permalink)
Jacob just announced that the FTW3 has a much higher power limit and will draw up to 373W. Who else might need a new PSU? Will 650W be enough?
https://twitter.com/EVGA_...us/1045836253545979904
100 Replies Related Threads
    SimonOcean
    Re: FTW3 max Power is 373W (150%) 2018/09/29 03:41:22 (permalink)
    IMO no. If you are getting a FTW3 I imagine that you will be pushing the GPU and have O/Ced CPU too? You really ought to get a beefier PSU. But I suppose to can try and find out seeing as you already have the PSU.
    Think 1: Caselabs Mercury S5 | Retired
    Think 2 rev B: Caselabs Magnum SMA8/A | MSI X570 Tomahawk | R7-5800X | G.Skill DDR4 3200 MHz 14-14-14-34 | MSI RTX 3090 Suprim | 2x Samsung 970 Evo 2TB | EVGA SuperNOVA P2 1200 | Dell UP2715K 5K monitor | Twin custom water-cooling loops with Hardware Labs GTX 560 and GTS 480 with D5 pumps and Aquaero 6 XT control
    Johnny_Utah
    • Ribbons : 8
    Re: FTW3 max Power is 373W (150%) 2018/09/29 03:46:45 (permalink)
    Nice!  Looking forward to seeing the OC's you guys picking up the FTW3 can achieve.
    • Ribbons : 84
    Re: FTW3 max Power is 373W (150%) 2018/09/29 03:55:39 (permalink)
    EVGA is having a large sale of power supplies in the USA. I just looked at a 850 watt EVGA PSU and once placed into the checkout cart the price was 99 dollars.
    • Ribbons : 84
    Re: FTW3 max Power is 373W (150%) 2018/09/29 03:58:44 (permalink)
    A semi-modular 1000 watt in the checkout cart was 119 dollars.
    GTXJackBauer
    • Ribbons : 48
    Re: FTW3 max Power is 373W (150%) 2018/09/29 04:46:07 (permalink)
    striker890
    Yeah you should be fine as long as you're not going nuts on OC the CPU and GPU.
    LMD3DNZM9LGK8GJ
    xblackvalorx
    Re: FTW3 max Power is 373W (150%) 2018/09/29 04:48:04 (permalink)
    Feels good to have 1000w
    Bought one ages ago just because I didn't wanna face this question again lol
    d.burnette
    • Ribbons : 17
    Re: FTW3 max Power is 373W (150%) 2018/09/29 04:55:26 (permalink)
    Yeah I got a 1000w Corsair Modular about 5 years ago when I did my current build.
    Doing a new build here hopefully before end of year, and debating a new power supply.
    EVGA sale looks tempting.
    Don
    EVGA Z390 Dark MB | i9 9900k CPU @ 5.2 GHz all cores | EVGA RTX 3090 FTW3 Ultra | 32 GB G Skill Trident Z 3200 MHz CL14 DDR4 Ram | Corsair H150i Pro Cooler | EVGA T2 Titanium 1000w Power Supply | Samsung 970 Pro 1TB m.2 Nvme | Samsung 970 Evo 1TB m.2 Nvme | Samsung 860 Evo 1TB SATA SSD | EVGA DG 87 Case |
    rv112
    Re: FTW3 max Power is 373W (150%) 2018/09/29 05:27:55 (permalink)
    Don‘t worry guys. Even 600W is more than enough if its not from china.
    KarmNelis
    Re: FTW3 max Power is 373W (150%) 2018/09/29 05:35:29 (permalink)
    rv112
    600W probably won't be enough if next-gen CPU is overclocked too.
    And all EVGA's power supplies are from China though.
    post edited by SilentMarket - 2018/09/29 05:37:37
    CPU - Intel 8700K - 5.1GHz core, 5.0GHz cache, 1.37v
    GPU - EVGA FTW3 1080Ti SLI - 2.0GHz core, 12GHz memory
    Motherboard - Asus Maximus X Hero
    Memory - Corsair Dominator 4x16GB - 3000MHz default XMP 15-17-17-35
    PSU - EVGA 1600T2
    Fire Strike 36838 Extreme 25250 Ultra 14464
    spye435
    Re: FTW3 max Power is 373W (150%) 2018/09/29 05:56:21 (permalink)
    I've seen a few FE 2080Ti reviews where total (maximum) system power draw is between 500 - 600 Watts, this obviously depends on system to system. I think a 650W PSU would be enough, but only just, and would not be running anywhere near peak efficiency.
    NZXT S340
    I7 8086K @5.0 GHz
    Kraken X62 AIO
    16 Gb Corsair DDR4 3000
    256 Gb Samsung SM961 M.2 SSD, 512 Gb 850 Evo SSD WD Blue 2TB
    Asus Maximus X Hero MOBO
    EVGA Supernova P2 850W PSU
    EVGA RTX 2080Ti FTW3 ULTRA
    ACER Predator XB321HK
    GTXJackBauer
    • Ribbons : 48
    Re: FTW3 max Power is 373W (150%) 2018/09/29 06:21:34 (permalink)
    SilentMarket
    What he means is a unheard of no-brand and or knock off PSU.  Stay away like the plague because I learned my lesson around 15 years ago when the cheap PSU I purchased for $20 on ebay started smoking while the PC was still running and than all of a sudden everything went blank.  Luckily I knew everything survived once I installed a quality PSU from a known brand.
    LMD3DNZM9LGK8GJ
    rv112
    Re: FTW3 max Power is 373W (150%) 2018/09/29 06:49:23 (permalink)
    SilentMarket
    rv112
    You know what I mean. 50$ 1000W PSU... I have a 550W with 8700K @ 5,2 GHz and 1080 @ 2 GHz drawing 450W peak. Don't think that the 2080Ti will need 200W more.
    striker890
    Re: FTW3 max Power is 373W (150%) 2018/09/29 07:19:00 (permalink)
    GNielson
    Can we get a 2080Ti XC Ultra bios with a 140% power limit? The design looks like it can handle that no problem. In the old days I'd just mod the bios myself, but I don't know what the status of bios-modding current cards is. Still possible?
    The FTW3 has more vrms. Also EVGA is most likely also limited by Nvidia on what they are allowed to do with the reference pcb.
    Yeah I hope the 650W will do just fine. Manufacturer also states the 650W is able to perform at 720W at peaks.
    • Ribbons : 282
    Re: FTW3 max Power is 373W (150%) 2018/09/29 08:25:44 (permalink)
    striker890
    Best bet would be a 750 Watt Power Supply on a Non-Overclocked CPU/Memory/Motherboard and an 850 Watt Power Supply with an Overclocked CPU/Memory/Motherboard.
    720W at Peak = 30 milliseconds in real time before the Power Supply Starts Tripping.
    post edited by bcavnaugh - 2018/09/29 08:30:25
    ThrashZone
    Re: FTW3 max Power is 373W (150%) 2018/09/29 09:58:11 (permalink)
    striker890
    Hi,
    Anyone willing to pay 1350.+ tax... wouldn't be skimping on a psu at 650w
    850w minimum and depending on cpu might be best at 1000w
    These items are cheap compared
    My first build,
    Case 450D/ ASUS Sabertooth X99/ 5930k with EK mono block / Water loop EK 280p-GTX240 radiators with D5 pump res combo before rads and D5 top after / Trident-Z 3200C14 4x8gb/ EVGA 1000 P2/ EVGA 1080ti FTW3 with EK copper water block.
    2nd build,
    Case D450/ ASUS x299 Prime Deluxe/ i9-7900x delidded with EK mono block/ Trident-Z 3600C16 4x8gb/ Water loop EK-280p-GTX240 radiators with D5 pump-res combo before rads and D5 top after/ EVGA 1200 P2 / Titan Xp with EK water block.
    badboy64
    Re: FTW3 max Power is 373W (150%) 2018/09/29 09:59:08 (permalink)
    I would like to see the clocks on them. I got 1 preordered and from what I heard that they are shipping them starting next week. I wouldn't go with nothing less than a 850+Watt PSU.
    post edited by badboy64 - 2018/09/29 10:01:32
    14th Intel® Core™ i9 14900KF CPU 3.2GHz@6.0ghz, Memory 2x24GB GSkill Trident Z Trident Z5 7200 mhz DDR5 Ram,4,000 GB MSI M480 PRO 4TB , Motherboard eVga 690 Dark , Operating System Windows 11 Pro 64-Bit, Msi Suprim X24G 4090, Monitor Acer CG437K, Logitech G910, Razer Lancehead Tournament Edition, Thermaltake View 91 RGB plus, eVga 1600w P2 PSU, Custom watercooling.
    Speed Way  Score 11,055 points.
    https://www.3dmark.com/sw/1112818
    streetglide420
    Re: FTW3 max Power is 373W (150%) 2018/09/29 10:16:41 (permalink)
    I'm running OC 7700k with 2x8gb ddr4, one m2, 3 SSD, and one HDD. I am running 750w g3.... Been nervous if it's gonna be enough
    • Ribbons : 282
    Re: FTW3 max Power is 373W (150%) 2018/09/29 10:18:07 (permalink)
    streetglide420
    Post your Findings.
    streetglide420
    Re: FTW3 max Power is 373W (150%) 2018/09/29 10:32:31 (permalink)
    i will, if i dont get an update on shipping soon im gonna just cancel my order and keep my 1080. communication for this release is bad
    post edited by Sajin - 2018/09/29 12:05:13
    striker890
    Re: FTW3 max Power is 373W (150%) 2018/09/29 10:39:57 (permalink)
    ThrashZone
    striker890
    Hi,
    Though it's only one year old... I've seen a video where they ran 3x 1080 TI's and a I7-7820X of a 750W psu. So I propably will give it a try. In theory it should be right at the border.
    streetglide420
    Re: FTW3 max Power is 373W (150%) 2018/09/29 10:44:25 (permalink)
    i have no issues buying a new PSU as well, but like you said Striker, my PSU is less than a year old, and id rather not buy another PSU for no reason.
    JDauwalter
    Re: FTW3 max Power is 373W (150%) 2018/09/29 11:16:36 (permalink)
    I got an EVGA G3 1000W for 99 bucks on Amazon just a couple weeks ago. It was a major sale, and I don't think my current 650W will be enough for the 9900k and 2080 Ti combo. Lol
    #23
    Zybane
    Re: FTW3 max Power is 373W (150%) 2018/09/29 11:23:12 (permalink)
    Looks like the FTW3 may turn out to the best 2080 Ti. Best air cooler and among the best power limit.
    Also, never use a power supply maxed out. Efficiency drops off and power regulation worsens maxed out. 40-60% load is where PSU's shine. For a OC'd 2080 Ti system, I'd buy at least a 1000w power supply. I use a EVGA 1600w!
    #24
    Ti-1000
    Re: FTW3 max Power is 373W (150%) 2018/09/29 11:24:43 (permalink)
    People greatly overstate PSU needs. A 650w would almost certainly be fine for this and an OC’ed CPU. Thing is, the difference between a 650 and 750 is typically like 20 bucks, so if you’re about to buy a new one it wouldn’t hurt to go higher. Doesn’t mean you need to replace your current unless you have a TON of other power draw from various devices.
    Current build: DCS4VR (Custom Loop)
    7700k + Cuplex KRYOS Vision block @ 5Ghz
    EVGA 1080Ti FE + EK block/backplate
    Maximus IX Code
    16GB Corsair Vengeance LED DDR43000
    500GB Samsung 960 EVO m.2
    Dell U3415W
    VIVE Pro
    #25
    brianrubin
    Re: FTW3 max Power is 373W (150%) 2018/09/29 12:01:59 (permalink)
    Thanks for the heads up. Gonna get a 1000w PSU for my next rig rather than the 850.
    #26
    SimonOcean
    Re: FTW3 max Power is 373W (150%) 2018/09/29 12:31:24 (permalink)
    FYI: the official Nvidia guidance on RTX 2080 Ti is 650W minimum recommended system power. If you are overclocking a FTW3 card and / or overclocking a HEDT CPU/Motherboard then you obviously need more power. And operating a PSU at full rated power is not smart. You want to operate the PSU at a point with headroom so that under normal system draw is at a point 50-70% up the draw limit where efficiency peaks.
    Also I'd rather buy a 1000W once, rather than buy a 650W, then upgrade to a 850W to O/C then upgrade to a 1000W if I change my mind and decide to go SLI. If you are throwing $1500 at a FTW3 why would you even question spending an extra $50-100 to get a more capable PSU?
    I think you are doing the right thing going for 1000W personally speaking. This was my choice too.
    #27
    • Ribbons : 282
    Re: FTW3 max Power is 373W (150%) 2018/09/29 12:34:29 (permalink)
    You should be going by card you have in hand for Requirements.
    https://www.evga.com/products/product.aspx?pn=11G-P4-2487-KR
    Requirements
    • Minimum of a 650 Watt power supply.
    • Two available 8-pin or 6+2pin PCI-E power dongles
    • Total Power Draw : 250 Watts
    post edited by bcavnaugh - 2018/09/29 12:39:08
    #28
    brianrubin
    Re: FTW3 max Power is 373W (150%) 2018/09/29 12:47:35 (permalink)
    I don't plan to overclock, I just wanna spend the money now to have options later. I think it'll be worth it.
    #29
    GTXJackBauer
    • Ribbons : 48
    Re: FTW3 max Power is 373W (150%) 2018/09/29 14:05:08 (permalink)
    Everyone needs to calm down with the PSU histeria.  lol
    If you're only doing a CPU + GPU (single), you won't want to go above 650w-750w.
    If you're going to SLI, 850w at a min.  That should give you more than enough room for high OCs, custom cooling, HDs, etc.
    LMD3DNZM9LGK8GJ
    #30
