Evga 2080ti Kingpin Oled problem
cffcc00cc
2019/11/08 22:14:08 (permalink)
Hello, can anyone help? My graphic card Oled did'not function, what problem? Did i miss some setup for it?
7 Replies Related Threads
    TwoEvilOne
    Re: Evga 2080ti Kingpin Oled problem 2019/11/08 23:09:22 (permalink)
    Looks bran new still with all that plastic on the screens. Check the oled connection to the board, and rip that plastic! Then keep it cool and push it to its limits.
    Here's mine:
    My 3DMark HALL OF FAME high scores on Nvidia GeForce RTX EVGA 2080 Ti K|NGP|N Hybrid: Port Royal HOF 10856,
    Time Spy v1.0 HOF 16961, Fire Strike Extreme v1.1 HOF 18976, Fire Strike Ultra v1.1 HOF 10049, Superposition v1.1 4K 14838;  Superposition v1.1 1080P Medium 30822; Superposition v1.1 1080P High 23905; Superposition v1.1 1080P Extreme 10802; Superposition v1.1 8K 6397.
    <-- over here go to my Mods Rig in red, and +1 rate it and leave a comment and ill +1 you back, Thanks.
    cffcc00cc
    Re: Evga 2080ti Kingpin Oled problem 2019/11/08 23:19:47 (permalink)
    Oled connection to motherboard? Which one?
    sparetimepc
    • Ribbons : 18
    Re: Evga 2080ti Kingpin Oled problem 2019/11/09 02:14:23 (permalink)
    The OLED on the shroud plugs into a connection on the pcb, there is no way to turn it off so if thats a brand new card then its either defective or the connection is messed up where it plugs in.  You might try to reflash the firmware though and see if that helps. Download PX1 software from EVGA  https://www.evga.com/precisionx1/     , then install and open it, when open down in the lower right corner click the circle by the version number, when that window opens click where it says update, then a different window will open with firmware versions, choose the E200-FA42 file, thats the newest firmware for the Kingpin Card. Disable any anti-virus before doing it though. If thats doesnt do it i would say an RMA is in the future.
    cffcc00cc
    Re: Evga 2080ti Kingpin Oled problem 2019/11/09 03:44:51 (permalink)
    it is a new card. i try update precision x1 already, did not help for it
    sparetimepc
    • Ribbons : 18
    Re: Evga 2080ti Kingpin Oled problem 2019/11/09 03:48:54 (permalink)
    cffcc00cc
    I would say its defective then and time for an RMA, if you open it up yourself and the connection is messed up then they could say you caused the issue, if you send it in and the factory seal that covers one of the screws is still in tact then thy will know its an issue from the get go and nothing you did.
    sparetimepc
    • Ribbons : 18
    Re: Evga 2080ti Kingpin Oled problem 2019/11/09 08:07:43 (permalink)
    I just remembered though, if you open pxi and go to the OLED section if there is no boxes checked at all and its set for monitoring the OLED screen will be blank like its not working. Make sure you have boxes checked there.
    cffcc00cc
    Re: Evga 2080ti Kingpin Oled problem 2019/11/09 08:24:11 (permalink)
    Got click the option, the oled look like some aspect plugin is missed. I try to wait the reply from evga customer service.
