JSB85
hello there i was hoping someone could help me out i just installed 2080 ftw3 ultra and was about to play around with latest version of X1 when i installed the software, it prompt me to update LED firmware so i pressed start which failed then i accidentally closed flash tool and now no Led is working and middle fan is spinning at 100% all the time Could anyone tell me how i could go around and flash led firmware again? any tip is appreciated
Re: Evga 2080 Ftw3 Ultra failed to update led firmware now middle fan is spinning at 100%
2018/11/08 18:22:28
☄ Helpfulby JSB85 2018/11/08 18:34:41
JSB85
2018/11/08 18:34:35
thank you so much Sajin that fixed my problem! i did look at the thread you linked but i didn't think solution applied to my situation thanks again you saved my day!
2018/11/08 19:36:55
No problem.
IronRinn
2018/11/09 07:02:09
Is there any other way to download the MCU updater? I have tried multiple computers, browsers, and connections and none of them will download from the links provided. I keep getting a network timeout error.
2018/11/09 11:07:06
IronRinn Is there any other way to download the MCU updater? I have tried multiple computers, browsers, and connections and none of them will download from the links provided. I keep getting a network timeout error.
Try your phone.
2018/11/09 11:18:26
trwortley
2018/11/17 13:33:35
I am super bummed. My 2080 TI FTW3 is also having this issue. I just built this rig and I'm really hoping to get it setup and game ready. I installed precision x1 and it immediately tried to install a firmware update. The update failed and now there are 3 red LED's lighting up over the power connection. The middle fan is also spinning at 100% and the logo is not longer lighting up. I did try this fix ( but its not working. It wont launch. It just says "This device is not supported!". I did try running it was administrator. I also updated my BIOS and ran all driver and windows updates that I am ware of. I also tried flipping the switch to overclock mode and still no luck. I am running a GIGABYTE Aorus Ultra z390 Mother board and an Intel 8086k. Nothing is over clocked and not settings have been messed with. I just set this rig up and was installing the basics before messing with anything. Is there another link that may work for me or something else I need to be doing?! Help! :(
post edited by trwortley - 2018/11/17 15:57:43
2018/11/17 15:57:39
trwortley I am super bummed. My 2080 TI FTW3 is also having this issue. I just built this rig and I'm really hoping to get it setup and game ready. I installed precision x1 and it immediately tried to install a firmware update. The update failed and now there are 3 red LED's lighting up over the power connection. The middle fan is also spinning at 100% and the logo is not longer lighting up. I did try this fix () but its not working. It wont launch. It just says "This device is not supported!". I did try running it was administrator. I also updated my BIOS and ran all driver and windows updates that I am ware of. I also tried flipping the switch to overclock mode and still no luck. I am running a GIGABYTE Aorus Ultra z390 Mother board and an Intel 8086k. Nothing is over clocked and not settings have been messed with. I just set this rig up and was installing the basics before messing with anything. Is there another link that may work for me or something else I need to be doing?! Help! :(
Time to contact evga support.
2018/11/18 13:52:07
sparetimepc
- Ribbons : 27
2018/11/19 06:33:33
Mine is the same problem, 3 red lights above power connections and the logo is no longer lit up like it should be. It happened after the newest firmware update in px1
lezus123
2018/11/19 08:53:20
I have the same problem too.
i9 9900K @ 5.1 GHzAsus Maximus Hero XIHOF Hall Of Fame 16GB (2x8GB) @ 4000 MhzEVGA GeForce RTX 2080 Ti FTW3 ULTRA GAMINGAsus Xonar Essence STX IILepa G1000M
2018/11/19 11:31:19
Sorry to hear you guys are having so many issues.
DisplacerGoat
2018/11/19 17:27:28
Newest version PX1. Three LEDs lit. No nameplate lights. Middle fan spins on normal. Three fans spinning on oc mode. Both modes do not accept firmware update. I'm still working with tech support. No solution yet.
Intel i7-8700K @ 5.2 Ghz Asus ROG Maximus X Apex EVGA 2080 TI FTW3 2x 16 GB G. Skill F4-3000C14 2x Samsung 960 Pro 1 TB m.2 EVGA Supernova 1300 G2
kyleqianlima
2018/11/19 21:42:26
Same issue please update if you have any fixes. Happened after update to 0.3.7. Device not supported for mcu update
lezus123
2018/11/20 11:13:34
There is no way to repair the problem. Support told me to make a RMA... :(
2018/11/20 11:21:42
lezus123 There is no way to repair the problem. Support told me to make a RMA... :(
Sounds like the newest version of px1 needs to be pulled.
sparetimepc
- Ribbons : 27
2018/11/20 12:04:37
Are you serious, if the firmware update in px1 0.3.7 was used on a 2080ti ftw3 the cards need to be rma'd?
kyleqianlima
2018/11/20 12:25:10
If there is a firmware window pop up and you close it for some reason the firmware update didn’t go through the card will be rma’d. No fix for it so far
2018/11/20 13:06:17
dwexpress Are you serious, if the firmware update in px1 0.3.7 was used on a 2080ti ftw3 the cards need to be rma'd?
That is what it sounds like to me.
sparetimepc
- Ribbons : 27
2018/11/20 16:27:37
Has anyone else had the problem on there rtx 2080ti ftw3 after this update that has caused resolution issues or problems updating nvidia drivers or is it just a fluke on mine right now? i also just updated to the Windows 10 1809 version so maybe thats causing issues as well.
post edited by dwexpress - 2018/11/21 05:52:51
DisplacerGoat
2018/11/21 07:09:46
yes, contact support. I second that.
lezus123
2018/11/21 13:30:46
HAd the same problem. I already RMA the card...
2018/11/29 12:08:19
JSB85 hello there i was hoping someone could help me out i just installed 2080 ftw3 ultra and was about to play around with latest version of X1 when i installed the software, it prompt me to update LED firmware so i pressed start which failed then i accidentally closed flash tool and now no Led is working and middle fan is spinning at 100% all the time Could anyone tell me how i could go around and flash led firmware again? any tip is appreciated
This issue has been addressed by X1 version 0.3.9 Beta ... currently the newest version of X1
