Re: EVGA_Flow_Control_Setup_v2.0.9 has not been Patched for the Correct AM4 CPU Temp.
2020/05/07 20:19:53
Just bought the system, so no previous version. Installed version is 2.0.9 I can tell you that my CPU temperature is reading in flow control as 84.9 C and in HWMonitorPro as 35.5 C, one degree below flow controls reported coolant temperature. The system appears to be cooling ok, but the fans will have to be replaced. I've never heard such loud fans, they have to be twice the decibel level of my old Corsair h110i system this was replacing. I tried isolating them like i did the radiator, on rubber washers, but they are still just insanely loud at low rpm's..Bad bearing in mine, idk, but these are brand new and should be silent and quality RGB fans for this price..Im pretty disappointed in the system as a whole and it will go in the trash when I can afford to hard loop it..Stick to video cards guys..I have zero complaint on my 2070 super..It's silent in comparison, even at full rpm..
