Hi everyone, I'm in the process of installing an EVGA GeForce RTX 2080 Ti Xc Hybrid. Should I run 2 individual power cables to the card or is the one Y cable that splits into two connectors ok to use? If either is ok, which do you recommend?
Edit: Also, if 2 separate cables, do you have any recommendations on which to purchase? My PSU only came with two Y cables, not single cables.
post edited by davidmaurio - 2020/01/25 13:35:28
