Hey so I recently installed my EVGA Z87 Classified motherboard to replace my old OEM from my prebuilt and the issue that I am having is that I am unable to restart my PC. Shutting down works perfectly fine and and boots up correctly but for some reason I cannot restart.
So what happens is when I hit the restart in windows, windows enters the normal restart sequence. However, once the monitor, keyboard and mouse turn off, the motherboard and everything directly connected to it is on for some reason. The fans continue to spin and it is as if the computer is still on but the keyboard and mouse are off.. I have attached a picture of the PC. Also, the error code reads "FF" but when I tried googling the FF error code none of the issues are related to restarting.
But basically, when I hit restart, the PC is indefinitely in this weird state where everything is on but the monitor, keyboard and mouse have already turned off as a normal PC would restart.
Also, this issue did NOT happen with my old OEM motherboard. I tried to disable Windows Fast boot but that did nothing to help this issue.
Also, another issue that is not as big of a deal is the fact that there is a very low quiet hum/static noise when I connect headset. This issue was also not on my previous OEM motherboard and I made sure to check the HD audio cable was plugged in snug.
I appreciate any help and guidance!
Thank you
