EVGA SuperNova 1000 P2 upgrade to a SuperNova 1000 P6... Same cable compatibility?
zuckuss00
2022/07/29 20:15:04 (permalink)
Hello folks,
I ordered up a new EVGA SuperNova 1000 P6 (220-P6-1000-X1) to replace my 8 year old SuperNova 1000 P2 (220-P2-1000-XR) which is getting a bit on the old side for my newest rig.
I'd like to reuse my sleeved cables which came with my old P2 which are still fine and routed well. I know this is typically a bad idea with a new PSU however, I figured if the pinouts are identical it shouldn't be an issue.
Will this new SuperNova 1000 P6 work safely with the old cables? I can't find a pinout graph for these newest P6 power supplies. I'll give tech support a call when I can on Monday to double check.
What do you folks think? Bad idea?
post edited by zuckuss00 - 2022/07/29 20:27:33
Intel Core i7-12700k 3.6GHz
Asus ROG Strix Z690-E Wi-Fi
EVGA GeForce RTX 3080 FTW3 Ultra 12GB
Corsair Dominator Platinum 32GB DDR5 5200Mhz
WD Black SN850
EVGA SuperNOVA 1000w P2
Windows 11 Pro
2 Replies Related Threads
    Epsolike
    • Ribbons : 17
    Re: EVGA SuperNova 1000 P2 upgrade to a SuperNova 1000 P6... Same cable compatibility? 2022/07/30 05:18:43 (permalink)
    Hey zuck,
    According to cablemod the pinouts match, and since a G2 to G6 i saw confirmed before to match logic also reinforces this.
    I also have a P6 personally, but since i used the cables that it came with i can't say from my end.
    Enjoy the new unit!
    EVGA X570 DARK (1.09) [manual SoC, AUTO high!]
    AMD Ryzen 5800X3D [-25 -25 -25 -20 -25 -25 -25 -25]
    GSKILL Royal Elite (Gold) 3600C14 (B-die) [F4-3600C14D-32GTEGA]
    EVGA 3080 Ti FTW3 Ultra
    EVGA SuperNOVA P6 1000
    • Ribbons : 84
    Re: EVGA SuperNova 1000 P2 upgrade to a SuperNova 1000 P6... Same cable compatibility? 2022/08/01 07:52:52 (permalink)
