EVGA SuperNOVA 1300 G2 Power Supply Question
klanham40
2015/01/12 08:44:23 (permalink)
I received my EVGA SuperNOVA 1300 G2 Power Supply  today and wanted to see if anyone could help me figure out how to hook it to my gpus they are ASUS GeForce GTX 780 Ti  with two 8pin sockets on top of each card, do I connect a separate cable to each 8pin to say vga 1 then vga 2 for one card?
Thanks for any help.
5 Replies Related Threads
    OGM3X
    Re: EVGA SuperNOVA 1300 G2 Power Supply Question 2015/01/12 08:58:59 (permalink)
    It doesn't matter which VGA connector you are using on the PSU , anyone from VGA1-VGA6 will work fine.If you are running SLI then use four VGA connections of your choice
    • Ribbons : 282
    Re: EVGA SuperNOVA 1300 G2 Power Supply Question 2015/01/12 08:59:21 (permalink)
    You can use one cable for each or two cable one for each.
    Myself I use two cables per GPU, but like I said you can use the one cable that has two connectors as well.
    klanham40
    Re: EVGA SuperNOVA 1300 G2 Power Supply Question 2015/01/12 09:01:55 (permalink)
    That was fast replies, thanks alot for the info I think I will go with 2 cables per gpu. Thanks
    OGM3X
    Re: EVGA SuperNOVA 1300 G2 Power Supply Question 2015/01/12 09:04:27 (permalink)
    Definitely use two cables for each card
    WarGasimXDi
    Re: EVGA SuperNOVA 1300 G2 Power Supply Question 2015/01/12 11:28:19 (permalink)
    According to EVGA there is a certain way you would hook up the video card or cards to the actual power supply its self. You would use VGA 1-4 for 6+2 pin only hook ups, if your using 6+2pin + 6pin then you would use 5 and 6 only.
    http://www.evga.com/suppo...s/120-G2-1300-1000.pdf
    post edited by WarGasimXDi - 2015/01/12 11:34:36
      I7-6700k | MSI Gaming 7 motherboard | Corsair Dominator Platinum 3400mhz 8GB | 530 cherry SSD 128gb - Win 10 64bit OS | 2 x 500GB raid | Samsung 850 EVO PRO | MSI GTX 980ti |  EVGA 850 P2 | Corsair Air 540 case | Corsair H105 liquid cooler
    http://www.heatware.com/eval.php?id=86108
    Need a place to relax? Need a place to hangout and enjoy gaming the way it was meant to be? Come join
