EVGA SuperNOVA 1000 PS Power Supply issue
AngryAce
2018/02/16 19:13:29 (permalink)
Hi all,
I just got another 1080 ti hydro copper and now have 2 in SLI. I have a EVGA SuperNOVA 1000 PS PSU. I am running into an issue after installing the 2nd card. Gaming, I have no issues but when I start folding, the machine restarts itself. If I run just one card at a time, I have no issues. If I can get past the initial "run" up to full power with both cards, it will run normally and fold all night. I am leaning towards a PSU issue but wanted to some input before I set up an RMA.
Thanks
9 Replies Related Threads
    Re: EVGA SuperNOVA 1000 PS Power Supply issue 2018/02/16 19:16:16 (permalink)
    AngryAce
    Yep, sounds like it's a psu problem.
    • Ribbons : 282
    Re: EVGA SuperNOVA 1000 PS Power Supply issue 2018/02/16 20:51:46 (permalink)
    It has been a very long time since you have Folded, glad you are starting backup.
    Before you started to Fold Overnight did you Disable SLI?
    Are you using 4 Separate PCIe Power Cables 2 Each for Each Graphics Card?
    post edited by bcavnaugh - 2018/02/16 20:55:45
    AngryAce
    Re: EVGA SuperNOVA 1000 PS Power Supply issue 2018/02/18 08:36:32 (permalink)
    I don't believe I should have to use 4 separate cables. I never have in the past and my rigs always ran fine. I have switch the PSU out for another and the issue gone. I can't remember the last time I had a bad PSU. As far as folding, I am usually looking for aliens (SETI).
    Thanks Sajin for the solid support as usual!
    Re: EVGA SuperNOVA 1000 PS Power Supply issue 2018/02/18 12:19:11 (permalink)
    No problem. Glad to hear switching out the psu fixed the issue.
    • Ribbons : 282
    Re: EVGA SuperNOVA 1000 PS Power Supply issue 2018/02/18 12:34:19 (permalink)
    Common Sense is not dead on the Forum After all.
    AngryAce
    Folding @ home is a project focused on disease research.
    The problems we’re solving require so many computer calcul­ations – and we need your help to find the cures! Not looking for aliens (SETI).
    But I am glad your replacement of your Power Supply Corrected your issue.
    post edited by bcavnaugh - 2018/02/18 13:26:45
    AngryAce
    Re: EVGA SuperNOVA 1000 PS Power Supply issue 2018/02/20 00:14:39 (permalink)
    AngryAce
    Bro!! Aliens could have the cure for many diseases, Just need to find them via SETI!!!!
    Interestingly enough, I placed the "defective" PSU back in the system and was going to set up an advanced RMA (I had to put the other PSU back in the machine I borrowed it from). It seems to be functioning normally now. I usually perform maintenance every few months if not monthly and I was able to give the PSU some extra attention since it was out of the system. So far so good!
    Re: EVGA SuperNOVA 1000 PS Power Supply issue 2018/02/20 11:44:55 (permalink)
    Must have had some loose cables, or maybe the psu is just working at the moment.
    AngryAce
    Re: EVGA SuperNOVA 1000 PS Power Supply issue 2018/02/20 14:32:17 (permalink)
    I initially checked the cables when it first started happening but you know computers, could be anything... If it happens again, I'll simply RMA the unit.  :D
    • Ribbons : 115
    Re: EVGA SuperNOVA 1000 PS Power Supply issue 2018/03/09 22:49:38 (permalink)
    Could be the PSU just works sometimes. Hopefully it stays good.
                My Affiliate Code: 8WEQVXMCJL
     &nbsp
