EVGA Pro SLI Bridge LED will NOT work with older 970s (does work with new SSC and FTW+)
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/01/30 16:08:51 (permalink)
ManBearPig
I'm guessing those are the new SSCs?  The new SSC and FTW+ have been reported to light up the SLI bridge.  This thread was created before the new cards were made.  The old 970s will not light up the SLI bridge.
+1
#31
exilelrrp
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/01/30 17:07:31 (permalink)
ManBearPig
grimmace
Mine lights up fine on the 970 SSC. EVGA sli 2 card bridge and EVGA SSC 970s. If it makes a difference, I use it on the connectors to the inside of the card. Pics or no proof? Well, here you go. Shows they are 970SSC
Lit up
Maybe only the fitrst ones don't light up?
Hold On!? Hold On!?....You're telling me that my EVGA GTX 970 ACX 2.0 are old for this EVGA SLI Bridge and that's why it doesn't light up for me?
or is that my EVGA SLI Bridge I purchase when they came out is the problem!?
*Lian Li PC-011D Mini (Black) *i9-10900K *ROG Strix Z490-G *Nzxt Kraken Z73/Lian Li UNI SL120 Series *Corsair Vengeance Pro RGB 64GB (4x16GB) DDR4 *Corsair HX1200i *EVGA GeForce RTX 3080 Ultra FTW3 *Samsung 970 Evo M.2 1TB *Samsung 960 Evo M.2 500GB *Samsung 840 Evo Series 1TB SSD *Asus ROG Swift PG43UQ *Corsair K70 MK.2 RGB *Corsair Dark Core *Corsair Gaming MM800 *Corsair ST100 *Razer Nari Ultimate.
#32
ManBearPig
  • Ribbons : 20
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/01/30 17:27:41 (permalink)
The 970, 970 SC, 970 SSC, and 970 FTW were not made with the part that was needed to light up the SLI bridge.  The new 970 SSC and 970 FTW+ now have the part needed and will indeed light up the SLI bridge.  So older 970 models don't get the LED while the new 970s do.
#33
exilelrrp
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/01/30 17:32:37 (permalink)
ManBearPig
And the fact that EVGA made the SLI Pro Bridge way before the 970's, ain't that some bull****!
#34
grimmace
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/01/30 17:48:27 (permalink)
ManBearPig
+1
Yep, mine are the new SSCs the 3975s. Something to be on the look out for in the future then. Good to know.
#35
Squall_Rinoa86
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/01/30 17:50:55 (permalink)
Yea, I was pretty annoyed that the 970 GTX FTW 2978 Dont have LED lights.. Was like WTH? Lame...
post edited by Squall_Rinoa86 - 2015/01/30 17:54:12
PSU: EVGA SuperNOVA 1300 G2
My Affiliate Code: AN1FW0VMG6
#36
the_Scarlet_one
formerly Scarlet-tech
  • Ribbons : 79
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/01/30 17:59:01 (permalink)
EVGA made an oversight. It happens. They are supposedly working on something new at this time.
They corrected the oversight with the 2 newest cards. They acknowledged the oversight. It's unfortunate, but for the same of being open minded to mistakes, the pro SLI shows it will work with the 700 and titan series. At least they didn't, and still don't, advertise it to work with any 900 card. That would be frustrating.
post edited by Scarlet-Tech - 2015/01/30 18:01:04
#37
jmike00
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/01/30 18:45:21 (permalink)
Scarlet-Tech
That depends on your definition of advertising. Jacob made this post back in Sept but then retracted it later in November it looks like. I remembered reading it and using that as an assurance that they would work. I didn't think about having to go back and check on the post regularly to make sure it wasn't inaccurate. So I bought them and they don't work.
edit: and while I know the thread wasn't asking about the 970, the EVGA LED bridges were working fine on MSI and ASUS 970s so there was no reason to think they wouldn't do the same on EVGAs 970s.
post edited by jmike00 - 2015/01/30 18:51:53
#38
the_Scarlet_one
  • Ribbons : 79
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/01/30 18:51:15 (permalink)
jmike00
Scarlet-Tech
Advertising:
http://www.evga.com/Produ...aspx?pn=100-2W-0021-LR
That is advertising.
Yes, Jacob made a mistake. It happens. He isn't an engineer. It happens.
#39
jmike00
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/01/30 19:08:46 (permalink)
I guess I feel a bit differently then. When a question about a product is posted on the official message boards of a manufacturer and an official rep for that manufacturer confirms they work then I consider that advertising. If that's not the case then there shouldn't be an official comment on the matter from anyone at EVGA.
Sorry I guess I'm just really frustrated at this point with my new build that I have been piecing together over the last few months. I went with 2x 970s to break into 4k gaming, I went with EVGA cards because of the excellent service history, I bought the back plates because I like a nice streamlined look and I bought the EVGA bridges because I wasn't a fan of the nvidia bridges and wanted the EVGA LED's to match my cards. Well 4k gaming is crap in a few games due to the ram issue and my bridges don't function as I expected(yah i know first world problems). My only option is to step up to a 980 which I could afford to do with one possibly in the next month or so, leaving me with 2 back plates and 2 bridges and 1 970 as paper weights.
#40
the_Scarlet_one
  • Ribbons : 79
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/01/30 19:39:43 (permalink)
I completely understand the frustration.
#41
paullongy326
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/01/31 03:57:02 (permalink)
jmike00
+1  exactly the same as you bud they offered me a step up but like you say
leaving me with 2 back plates and 2 bridges and 1 970 as paper weights what a waste for us just to add to this a big argument with 4k monitor just to actually go with 1440 dell cause of the gpus , thanks next time more research and maybe different manufacturer
post edited by paullongy326 - 2015/01/31 03:59:31
CASE= corsair a 540
MOTHERBOARD =ASUS X99 PRO
CPU=intel i7 5820K   4.0GHZ@1.1V
MEMORY=32gb dominator platinum3000MHz memory
HARD DRIVES=ssd samsung pro 250 gb /western digital cavier black 1 tb
GPU=EVGA GTX980 CLASSIFIED ACX 2.0
COOLER=h100 i water cooler
MONITOR=  Dell U2715H 27" QHD IPS Monitor 2560x1440
#42
sander11111
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/02/08 10:24:27 (permalink)
How do i now witch gpu is the new one?I want to buy de ftw 970's
#43
grimmace
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/02/08 11:08:43 (permalink)
I think it's only the new cards, the SSC and the FTW+. I have the SSC the 3975, and it lights up the bridge.
#44
paullongy326
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/02/08 11:28:34 (permalink)
i have now got rid of the 2 x 970s and got 980 classified and it works ok  i tried with another 980 of a friends just to see if it works and it does  but i now have to save for another 980 classi lol
it must just be with the 970 sc acx  on the older versions  sorry guys i have managed to sort mine by upgrading  but i do hope you get it sorted
CASE= corsair a 540
#45
  • Ribbons : 270
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/02/08 13:31:06 (permalink)
exilelrrp
ManBearPig
grimmace
Lit up
It's like placing sprinkles on a turd. I don't know why folks are so annoyed that the ugly bridge doesn't light up with their card.
It was an oversight on EVGA's part. You could easily correct the oversight yourself with some basic tools and electrical skills. But why even waste the time?
#46
sander11111
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/02/08 14:13:39 (permalink)
Well i am going for 980's now, just to be sure.
#47
geezer357
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/02/11 07:59:03 (permalink)
Just received my SLI bridge. Knowing that it wouldn't light up with my 970's, I still wanted the EVGA logo. HOWEVER, it seems as if EVGA redesigned the bridge. It now has a reflective strip where the logo used to be. I thought I got a bootleg bridge and called the website that I bought it from to yell at them. While I was on the phone, I noticed an imprint on the underside of the reflective strip. I think it acts as a two-way mirror. Now I have no lights or logo!
post edited by geezer357 - 2015/02/11 08:06:02
Thaal Sinestro
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/04/15 20:49:11 (permalink)
Crap, what the hell EVGA? Will it work with the 04G-P4-2974-KR? Cus I just bought 2...and the EK waterblocks...and nickel backplates...crap...again...
#49
Thaal Sinestro
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/04/15 20:56:09 (permalink)
Acrylic nickel plated by the by:) And grimmace(Can't PM you. I'm new) tell me sweet sweet lies. Your cards look identical to mine...please, sweet, sweet lies...tell me they're 04G-P4-2974-KR...
#50
StealthArsenal
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/04/16 04:12:27 (permalink)
I've got the three way EVGA sli bridge on my Asus X99 Deluxe and it lights up just fine with my 970 FTW+.  I could post a photo of it.
My Affiliate Code: PGAH4ZMWSG
Main Rig:  |Intel Core i7 7820X||Aorous Z299 Ultra Gaming ||Asus Xonar DSX||Corsair Air 740||EVGA Supernova P2 1000||EVGA RTX 2080TI Ultra FTW3||Samsung 950 Pro 250gb NVME||Samsung Evo 500GB SSD x 2||Fractal Design Celcius S36||Logitech Z5500||Acer Predator XB271HU||Alienware AW34 Curved||32GB Corsair Vengeance 3000 mHZ ||EVGA Torq X10||Corsair K70||Cablemod PSU Cables (Green/Black)|
#51
stalinx20
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/04/16 04:17:19 (permalink)
EVGA_JacobF
Unfortunately the NVIDIA SLI bridge will not light up on 970 either, 970 does not support the LED function on SLI bridges.
Are you talking about the earlier version of the EVGA SLI bridge?
EVGA X79 Dark
2080 Black edition
980
EVGA 1000 gold PSU (Gold)
4820K CPU
16x G-skill
#52
StealthArsenal
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/04/16 05:42:25 (permalink)
You can see the EVGA lit up.  It's one of the original 3 way bridges.
#53
nycx360
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/04/16 06:42:38 (permalink)
Yes you can see working on other brands because of the pcb they used. Lots of the 970s use 980 pcbs. Best buy reference version, msi, strix, etc. If your 970 uses a reference 980 pcb or has the same pcb as a non ref 980 it will light up.
#54
ManBearPig
  • Ribbons : 20
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/04/16 06:51:04 (permalink)
This is an old thread created before the new SSC or FTW+ was made.  I brought it to eVGA's attention and now the newer cards have the LED SLI bridge feature.  This was discussed in the thread already that the new cards have the feature.
#55
sydneyblue
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2015/04/16 19:55:49 (permalink)
this thread is too much I mean the bridge still looks great with or with out lights personally I would want one without leds
#56
oriddlero
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2017/02/27 15:55:54 (permalink)
Thread resurrection time!  The new bridges have WRGB LEDs, all colors will run off ATX 5v except for the white whitch needs around 7v.  The Orange lead is your positive and the colored wires correspond to each LED ground color... Just run the leads of black/red 5v molex connector.  For white connect to yellow (12v) and red (5v) for 7v.
Tested and applied hack with my dual 970's when i plugged it in and realized it did not work and was overrun with sadness lol. I can solder it back together the way it was if i ever want to use it with future cards.
#57
oriddlero
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2017/02/27 17:08:19 (permalink)
#58
eXor78
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2017/03/07 17:31:09 (permalink)
Does anyone know if the led light up with only one new card SSC+ or FTW+ and an older one ?
#59
the_Scarlet_one
  • Ribbons : 79
Re: EVGA Pro SLI Bridge LED will NOT work with 970s 2017/03/07 17:32:41 (permalink)
eXor78
No. That is actually what this entire thread is about.
#60
