EVGA_JacobF
- Ribbons : 26
cerisettex
Re: EVGA Power Supply Reviews
2014/02/14 16:47:54
What about 1500W Supernova review at JonnyGuru ;)
http://www.modsrigs.com/detail.aspx?BuildID=33501Rig: CPU : Intel Core i7 3930k 5Ghz offset+ LLC High 150%cpu Mother Board : ASUS Rampage IV Extreme X79 RAM : GSkill TridentX 16Gb 2400Mhz (2666Mhz OC!)Video Card : 4-way CrossfireX (QUAD-Fire) MSI R7970 Lightning Boost EditionPSU : LEPA P1700M Maxplatinium 80+PlatiniumSSD : OCZ Agility 4 256GbHDD : X1 1,5Tb + X3 750Gb + X1 3TbWatercooling : SWIFTECH H2O-220 EDGE HD LUQUID : PHOBYA SEXY RED UVCase :Antec DF-85 modded!Total FANs : 16 fans !OS :Windows 8.1 Pro 64bits
EVGA_JacobF
- Ribbons : 26
2014/04/02 18:08:59
EVGA_JacobF
- Ribbons : 26
2014/05/21 11:22:05
Updated with 750 G2 reviews.
EVGA_JacobF
- Ribbons : 26
2014/06/17 13:34:42
MSim
- Ribbons : 38
2014/06/18 13:07:24
How come we don't see any reviews by HardOCP anymore Jacob.
EVGA_JacobF
- Ribbons : 26
2014/07/28 09:22:16
EVGA_JacobF
- Ribbons : 26
2014/08/06 16:10:24
vsg28
- Ribbons : 18
2014/08/07 09:17:58
vsg28
- Ribbons : 18
2014/08/18 09:13:08
EVGA 1600G2 review up at JonnyGuru: http://www.jonnyguru.com/modules.php?name=NDReviews&op=Story&reid=391 I thought it was harsh they removed the 0.5 points for the ATX connector being loose but then again they didn't remove points for the unit not adhering to 15A at near full load so it evens out. Interesting also how it is a new platform, only borrowing some things from the Leadex.
post edited by vsg28 - 2014/08/18 09:17:35
EVGA_JacobF
- Ribbons : 26
2014/08/18 13:21:25
Updated with 1600G2 and 750B1
Vlada011
- Ribbons : 11
2014/08/20 09:19:32
1600G2 follow quality of other models. Excellent for such strong PSU, 1600W Performance 10 will be interesting for enthusiasts who build multi GPU configurations with sleeve cables. -Performance 10 -Functionality 10 -Value 10 -Build Quality 9.5 TOTAL 9.9 EVGA SuperNOVA 1600G2 - JayZ Unboxing Video http://youtu.be/GisFXbmWpKY Almost 15.000 views for 2 days.
post edited by Vlada011 - 2014/08/21 18:30:16
muhd86
2014/08/24 06:04:29
why is there not much info on the 1500watt watt evga psu ....
EVGA SR - 2 WITH DUAL XEONS E-5645 @ 3GHZ 24GB GSKILL RIPJAWS @ 1600 MHZ SOUND BLASTER ZXRCOOLER MASTER SELEDON 120M * 2 4 * 1000GB HDD , 1 * 1000GB EXTERNAL HDD , 1 KINGSTON V300+ 256GB SSD BLU RAY BURNER AEROKOOL TOUCH 1000 FAN CONTROLER XLF SERIES FANS 30 INCH HP LCDXIGMATIC MODDED ELYSIUM CASING 1200WATT COOLER MASTER GOLD PSU CYBORG RAT 9 / RAZOR MAMBA 4G BATTLEFIELD 4 MECHANICAL RAZOR
Vlada011
- Ribbons : 11
2014/08/24 06:49:18
No 1500W unit more, production is stopped and manufacturer changed because Super Flower make better power supplies. Now have 1600W Gold quality is almost Platinum. Super Flower is better than Etasis. Even if they need to design new platform completely they done excellent that. Only one accident with cables stop 1600 G2 to get 10/10 score. Nothing with power supply. Pity. If you read Johnny Guru review he talk how production over 1200/1300W is not easy task and PSU to stay perfect. But SF now produce much higher units than 1300W easy. Seasonic never go over 1200W. But 1600G2 is same as NEX1500, nothing miss, cables are present in different colors, same huge power cable, PSU is huge and look great... difference is only because 1600G2 have better performance in every segment. I think two od these 1600G2 with black sleeve sets are enough side by side in some CASELABS Magnum for 4Way SLI and Xeons, two pumps and 10 HDD for little data center + workstation + gaming rig in same time...under water... 3.2KW - 3200W
post edited by Vlada011 - 2014/08/24 06:56:01
vsg28
- Ribbons : 18
2014/09/01 09:40:31
Wopschi
2014/09/08 12:22:42
Anyone here got a link to a evga 650 watt gold psu review ? I only found a hardocp one and that one is full with hatred.
Grey_Beard
- Ribbons : 10
2014/11/12 08:42:45
Any reviews of the 1600W P2? I am thinking of purchasing one.
Vlada011
- Ribbons : 11
2014/11/22 09:36:55
Difference between EVGA 1200 P2 with numbers (220-P2-1200-X1) and (220-P2-1200-X2) is power cable (USA/EU) or something else?
flopticalcube
2014/11/23 09:45:59
Affiliate Code: QX8LPD9RSI
Vlada011
- Ribbons : 11
2014/11/26 11:22:47
vsg28
- Ribbons : 18
2014/12/22 14:10:32
MSim
- Ribbons : 38
2014/12/23 07:03:34
Vlada011
- Ribbons : 11
2014/12/31 04:31:28
Newegg should fix their list with EVGA SuperNOVA Power Supplies. Some models are 100% Japanese Capacitors and reviews explain that nicely and clear for Polymer and Electrolytic Capacitors but Newegg didn't mark good.
BOYANDY
2015/01/13 09:04:14
I find this quote by HiTechLegion in their SuperNOVA 750 B1 review to be highly amusing: "While performing reliably, the NEX750B also maintained quiet operation from the 135mm double ball bearing fan, which produces very minimal fan noise." Quiet operation!? Minimal fan noise!!?? Did he do a long distance review? Maybe he wrote it in his studio while the PSU was in fact placed outdoors, on the moon....
- Ribbons : 282
2015/01/13 09:25:32
BOYANDY I find this quote by HiTechLegion in their SuperNOVA 750 B1 review to be highly amusing: "While performing reliably, the NEX750B also maintained quiet operation from the 135mm double ball bearing fan, which produces very minimal fan noise." Quiet operation!? Minimal fan noise!!?? Did he do a long distance review? Maybe he wrote it in his studio while the PSU was in fact placed outdoors, on the moon....
I find user that the PSU Fan runs high Speed are generally running the PSU at 90 to 100 Percent. My neighbor install a new GTX 780 Graphics Card using a new 650 Watt PSU and runs really well. They installed a Second GTX 780 Graphics Card and are now having random power outage while gaming. I setup a Test PSU for the Second GTX 780 Graphics Card and for a few days the had now issues at all while gaming. We took off the Test PSU and soon after starting having random power outages once more while gaming. We removed the 650 PSU and install a 860i PSU and now they are running fine. Long story short is their fan was running high performance, they could here the fan I had to put my ear next to it and I could here it but it was normal as far I felt. Their son said it was to loud and I asked him about the fans on the GPU's and he said well that they too are loud but you should expect that from high end video cards. He is 12 Years old. Sometimes I think that the young base everything on their Mobile Devices level of sound.
BOYANDY
2015/01/13 09:54:27
I hear you and agree about some being to sensitive over sound, myself included and I realize this is a "budget" PSU, but since the fan on this particular PSU runs at 100% at any load it really doesnt really matter what GPU I have, but just for the sake of conversation, I have a single EVGA GTX 970 SC ACX 2.0 so I think a 750w psu should cope. The GPU is also whisper quiet at idle, as is the rest of my setup, only noise is the damn PSU with it´s 100% fan speed.....
vsg28
- Ribbons : 18
2015/01/13 18:14:00
HiTechLegion has very little in terms of proper testing equipment or thinking. I have seen this before with their cooler temps and noise numbers which make me skeptical of most of their reviews.
Grey_Beard
- Ribbons : 10
2015/01/28 19:22:55
vsg28
- Ribbons : 18
2015/04/06 17:41:27
Vlada011
- Ribbons : 11
2015/04/16 05:20:53
