EVGA_Lee
Moderator
- Ribbons : 14
Re: EVGA Nu Audio - No Sound when waking up from sleep mode
2019/05/21 18:02:44
MackWage Can confirm the new driver update does NOT fix it.
Thanks. What do you have your sample rate/bit-depth set to when you put your system to sleep?
MackWage
2019/05/21 18:04:56
I typically have it set to 32bit/192k. In my prior testing, I discovered the problem exists at each setting until you lower it to 32bit/96k. At that lower setting, I stopped having issues.
EVGA_Lee
Moderator
- Ribbons : 14
2019/05/22 10:29:00
MackWage I typically have it set to 32bit/192k. In my prior testing, I discovered the problem exists at each setting until you lower it to 32bit/96k. At that lower setting, I stopped having issues.
Our Audio team tested and had no issues at 32/192. They recommended to close the program, delete all temporary App Data folders for the NU Audio Card, here (you might have more than one): Go ahead and open the program at that point, then try to put it to sleep and see if the issue persists.
inkey
2019/05/22 17:45:04
Hello, I can also confirm the new driver update does not fix this as well. Also I found that most of the time, unless I remove the headphone jack and reboot the sound card cannot fully drive a 250ohm headphone. So 2 issues- -The going to sleep with Youtube open crashes the driver. This does not happen if I close the tab out, thats the work around. -Yet, I do bealive that after putting the computer asleep the amp does not fully power and drive anything above 100 or so Ohm's my 250 Ohm headphone are not as loud as my 40ohm headphones. They are night and day. My 250ohm headphones are better quilty and louder then my 40ohm headphones. Thanks John
EVGA_Lee
Moderator
- Ribbons : 14
2019/05/22 18:22:19
inkey, since installing the drivers, did you delete the folder(s) from the temp location in App Data as I showed above?
inkey
2019/05/28 07:42:22
Hello, Yes, I did deleted the temp folder a bunch of times.
van6ogh
2019/12/26 14:30:57
What's the status with this? I just purchased a card a month ago. I'm on the latest driver / firmware and I have this problem, no sound when waking from sleep.
silentknyght
2020/01/21 12:53:29
I've also started having this same or a similar problem. Nothing seems to fix it except a reboot. No sound, and no program suggests it's outputting sound, either. Not to my headphones or my speakers (both plugged into my Nu Audio card).
TrueCouchSurfer
2020/01/26 01:01:22
Hi, I have similiar problems, after sleep mode the EVGA nu audio card will not work (meaning I've got no sound in headphones/soundspeakers (via SPIF). Furthermore even after i reset the computer it will not work (soft reset and hard reset). I have to go to Control Panel Soundsettings and click resolve the problem (translated I use different language version of Windows than EN), click twice that I'am not hearing sound and then restart the computer. My sample rate is set on 24 bit, 48000. I've tried deleting temp folder as specified in this topic but to no effect. The problem is persistent and annoying for 'premium' product. I use Windows 10, newest software drivers 0.2.1.7 with Nahimic. Other audio sources are disabled in hardware settings. My computer is: AMD 2600x ROG STRIX B350-F GAMING (newest BIOS) EVGA GeForce GTX 1080 FTW2 GAMING EVGA SuperNOVA 650 G3 EVGA Nu Audio G.Skill Trident Z RGB DDR4, 2x8GB, 3200MHz, CL16 (F4-3200C16D-16GTZR) Hope you can resolve the problem.
van6ogh
2020/01/26 13:02:48
This topic has been open almost a year with no resolution. Currently released driver still experiences the issue, but now I get the error "Audio renderer error. Please restart your computer" on youtube when trying to play a video, which adds insult to injury.
wikksmith
2020/02/13 05:37:28
Similar problem. PC is set to never go to sleep or hibernation modes, but after several hours of inactivity, the sound card becomes unresponsive. I have to reboot the or go into the Nu Audio Pro setup and click on the speaker icon under Playback to "activate" the card. BIOS and all drivers are up to date. All Windows power-saving options, including the PCI-E Link State Power Management, are set to NEVER or OFF. Internal audio is disabled. Tech support suggests disabling C state in BIOS, which I'm reluctant to do, or use a different slot (not available). Very disappointing for "high end" sound card. System: 9900k, Gigabyte Z390 Aorus Pro, EVGA GTX1070, GSkill DDR4 2x16GB, 3200
Talon2020
2020/02/20 12:52:46
i9 13900K | EVGA Z690 DARK | NVIDIA RTX 4090 FE | 32gb DDR5 8000 CL36 SK Hynix A-Die | Samsung 980 Pro 2TB | EVGA 1000 P6 | LG C1 55 OLED 4K 120Hz G-Sync
