EVGA Hybrid Kit - cut off fan cable, void warranty?
SadCapriSonne
2019/07/30 13:58:57 (permalink)
Hey guys,
i think about getting a Hybrid Kit for my 2080 Ti FTW3 Ultra. I do not need the fan cable on the pump. I control the radiator fan with my mainboard or commander pro.
Can i cut off the fan cable or should i just hide it under the shroud ? Does cutting of the cable void my Hybrid Kit's warranty?
Thanks for your answers.
post edited by SadCapriSonne - 2019/07/30 14:01:09
i9-9900K @5.0GHz 1.315v
Asus Z390 Hero XI Wifi
Corsair 32GB DDR4 3200MHz RGB Pro White
EVGA GTX 1080 Classified
Be Quiet! Dark Power Pro 11 850W
Custom Loop: EKWB Velocity, Kinetic D5, Alphacool 420 UT60
Be Quiet! Dark Base Pro 900 White
Samsung 970 Pro 1TB
5 Replies Related Threads
    Re: EVGA Hybrid Kit - cut off fan cable, void warranty? 2019/07/30 14:00:11 (permalink)
    Cutting the cable off the hybrid kit would void the warranty on the kit itself.
    SadCapriSonne
    Re: EVGA Hybrid Kit - cut off fan cable, void warranty? 2019/07/30 14:02:22 (permalink)
    @Sajin ok thanks. Hiding it under the shroud it is, then.
    Samsung 970 Pro 1TB
    Re: EVGA Hybrid Kit - cut off fan cable, void warranty? 2019/07/30 14:03:58 (permalink)
    • Ribbons : 115
    Re: EVGA Hybrid Kit - cut off fan cable, void warranty? 2019/08/13 20:16:12 (permalink)
    That's the trick.
                My Affiliate Code: 8WEQVXMCJL
     &nbsp
    • Ribbons : 122
    Re: EVGA Hybrid Kit - cut off fan cable, void warranty? 2019/08/13 21:03:21 (permalink)
    Hide it
    warranty requires the product to be in stock condition
