Re: EVGA GeForce RTX 2080 FTW3 ULTRA - Buzzing sound?
2019/05/01 22:55:40
Zange
So after dealing with RED LEDS and middle fan going crazy i also been dealing with the buzzing souns and this whole time i thought it was coming from my speakers but it was defintely from the GPU.
It isnt a PSU issue as not only did i swap between a 800w and 1000w Corsair but i also purchased the 1600w t2 evga PSU and still getting the same problems. I just recieved my RMA and it also does the same buzzing sound im awaiting 42 hours to confirm if i am still dealing with the same red led and middle fan issue. I gone through all the bios flashes as instructed and PX1 verisions and it is not helping. So currently dealing with two $1400 GPUs that seem to be having similiar issues.
Just so I am certain if we are getting buzz from the VRM to the extent in this video we should RMA? I understand it is common with the 2080 Ti but the amount of buzzing can vary and it is possible to get a card without the buzz at all. Is the above video an example of an extreme amount of buzz? It's the level of buzz I have.
