Helpful ReplyHot!EVGA GTX780ti SC ACX - Fans at max and no display signal
lordmag95
2018/06/22 06:08:30 (permalink)
Hi there,
I have a EVGA GTX780ti SC and last night I was playing Prepar3D and during the flight, suddenly I lost signal on both monitors.
I heard the fans at maximum before this, but I tought it was normal (hot temperatures in the room ~27oC). When this happenned, the fans kept at max, no display and I still heard sound.
Now I'm connected via onboard display and pc is working normally except for the graphics card that continues at max and isn't detected by the pc on both PCI-e Express slots.
I have already checked the PSU but seems okay and I tried to switch PCI-e cables positions on the psu and switch between slots PCI-e express. Nothing worked
My rig:
PSU:Corsair AX850
MB: Asus P8z77 pro
CPU: Intel i7 3770k
Memory: 12GB DDR3
GPU:EVGA GTX780ti SC
Best Regards,
Pedro
bob16314
  • Ribbons : 392
Re: EVGA GTX780ti SC ACX - Fans at max and no display signal 2018/06/22 06:40:48 (permalink) ☄ Helpfulby lordmag95 2018/06/22 06:57:07
Welcome to the forums.
Sounds like the card up and died..You might try it in another PC or take it to a PC repair shop for testing to be sure.
It's probably out of warranty and can't be RMA'd if it's bad..If it is, you can disassemble the thing and bake only the PCB like this which should reflow any solder cracking on the PCB, and hope for the best..Solder cracking can cause all kinds of different problems..Sounds like an actual component failure though and is a paperweight now.
If you bake it, do it with the GPU side up..200C for 10 minutes.
* Cooler Master NV-334 * ASUS ROG Maximus X Hero (Wi-Fi AC) * Intel i7-8700K @ 5.2GHz * 16GB G.SKILL Trident Z 4000MHz * Crucial MX500 M.2 1TB * WD Black 500GB (x2) * Seasonic M12 II 750W * Corsair H80i V2 * EVGA GTX 760 SC * Dual-Boot Win7 Home 64-bit/Win10 Home 64-bit *
"If it ain't broke, fix it untill it is"
lordmag95
Re: EVGA GTX780ti SC ACX - Fans at max and no display signal 2018/06/22 07:10:49 (permalink)
So one of the symtomps of dead card is fan at max and no display?
It is normal that the card can't be detected by anything, I tought the card would give a "signal" when was going to die.
EVGA doesn't repair cards like this?
bob16314
  • Ribbons : 392
Re: EVGA GTX780ti SC ACX - Fans at max and no display signal 2018/06/22 09:19:39 (permalink)
The most common symptoms are artifacting, freezing and BSOD, but anything can happen.
EVGA doesn't have a repair service for cards that are out of warranty.
  • Ribbons : 189
Re: EVGA GTX780ti SC ACX - Fans at max and no display signal 2018/06/22 11:25:48 (permalink)
See if the card will work in another pc.
lordmag95
Re: EVGA GTX780ti SC ACX - Fans at max and no display signal 2018/06/22 12:00:10 (permalink)
I will bring the card to a pc repair shop, today.
  • Ribbons : 105
Re: EVGA GTX780ti SC ACX - Fans at max and no display signal 2018/07/17 21:43:00 (permalink)
lordmag95
Any update?
            My Affiliate Code: 8WEQVXMCJL
My Heatware: https://www.heatware.com/u/117599/to
 &nbsp
lordmag95
Re: EVGA GTX780ti SC ACX - Fans at max and no display signal 2018/07/18 04:51:52 (permalink)
lordmag95
Any update?
They didn't accepted the card.
I bought another one, a GTX1060 and its working flawless.
  • Ribbons : 105
Re: EVGA GTX780ti SC ACX - Fans at max and no display signal 2018/07/18 20:46:53 (permalink)
lordmag95
lordmag95
Any update?
At least you have another now. Sorry to hear about your problems you had.
 &nbsp
