staypuft
- Ribbons : 31
OK, so after searching around I have not found a single thread on this topic that gives photos and detail about fan maintenance on these cards. This method does not require any re-application of TIM or replacement of thermal pads. This is the least intrusive method to either change out your fans or open them up for some preventative oiling. Here goes, broken into multiple posts: Tools used: Ball-end Hex key, 1.5mm Phillips #0 screwdriver (#1 works as well, depending upon the driver) STEP 1: Identifying the screws that you need to remove. Total of 4. 3 are identical and are removed out the side, 1 is shorter and is removed from underneath. This last one requires the ball end to reach inside the pocket at an angle.
post edited by staypuft - 2021/03/12 16:28:32
Interested in a discount on EVGA products? Click here for details and enter this Associates code at checkout >> 2ILPLQQ8IWY8DPN 2021 Build: Gigabyte Z590 Ultra | Core i7-10700K | be quiet! Dark Rock Pro 4 | 32GB G.Skill Trident Z DDR4-3200 EVGA RTX 3080 FTW3 Ultra | Samsung 970 EVO 500GB | Seasonic Focus GX-850 | Fractal Design Meshify C | Asus TUF VG27AQL1A
staypuft
- Ribbons : 31
Re: EVGA GTX 1080 Ti SC teardown for fan maintenance
2021/03/12 13:21:08
STEP 2: Identify any connectors that you must disconnect. This may vary based upon the card (my sample has one connection for the LED, 011G-P5-6393-KR). Generally the same principle for all designs, be careful and don't use sharp tools. Step 3: Disconnect using rounded needle-nosed pliers, or leverage it out (like I did) using the ball-end hex key shaft. It takes time and patience to work it out. Step 4: Lift and remove the shroud. Be careful to hold the wires aside so that they do not get snagged and cut on the heatsink fins.
post edited by staypuft - 2021/03/12 13:30:50
staypuft
- Ribbons : 31
2021/03/12 13:21:15
Step 5: Identify the screws that you need to remove in order to remove the fans - total of 6, 3 per fan. Once the screws are out, you can flip the fans over for oiling (skip to Step 8) or continue teardown for replacement (Step 6). Step 6: Unhook the fan wires from the heatsink. Step 7: Snip the zip tie and disconnect the fan header. Be careful not to cut the wires. Don't pull on the wires directly. Remove the fan assembly.
post edited by staypuft - 2021/03/12 16:15:01
staypuft
- Ribbons : 31
2021/03/12 13:21:21
Step 8: Flip fans over for oiling. Cut a hole in the middle with a very sharp x-acto knife. Place a couple drops of oil in the hole. Tape it back up. Clear 3M packing tape works great, won't yellow, will last years. I used something equivalent to this oil.
post edited by staypuft - 2021/03/12 13:57:03
kougar
- Ribbons : 22
2021/03/13 03:46:27
Interesting idea for where to place the oil. I just flip the fans over and place a couple drops between the inner/outer frame layers, then spin in both directions a few times to spread it around until I can feel the bearing lubricate. Probably overkill but it still lasts longer than the original config from the factory did. One of those very cheap plastic pipette's is flexible enough to just get between the housing and frame without having to take everything apart. Might try your trick next time I need to oil one though.
Have water, will cool.
- Ribbons : 271
2021/03/13 08:48:37
kougar I just flip the fans over and place a couple drops between the inner/outer frame layers, then spin in both directions a few times to spread it around until I can feel the bearing lubricate.
Oof. Don't you have issues with dust sticking and building up on the magnets and windings? Placing the oil directly on the bearing and sealing it back up is a much better method, in my opinion. It's the method I use.
atfrico
- Ribbons : 25
2021/03/13 13:45:32
Dude!! This is a great home mod. Thank you for sharing and well deserved BR
coolmistry
- Ribbons : 45
2021/03/14 12:26:48
That good explain and photos
Windows 11 Home 64bits up to Dated i9 11900K 5,328 MHz (3,500 MHz) || EVGA Z590 FTW WIFI || Nvidia RTX 3080 Ti FE || 32Gb Dominator Platinum DDR3 3600mhz XMP OC 3762mhz || 500gb Samsung 980 Pro NVMe || 500gb Samsung 970 EVO and Sata M.2 (1 x SSD and 1xHHD) || EVGA CLCx 360 Cooler || EVGA Supernova 1300w X3 || EVGA Z10 Keyboard || EVGA TORQ X10 mouse ||EVGA DG 77 case || Acer Predator X35 35" 200Hz G-Sync || EVGA Nu Audio Soundcard || Logitech Z906 5.1 system sounds SPDIF|| Kaspersky Internet Security
kougar
- Ribbons : 22
2021/03/15 10:25:32
ty_ger07 Oof. Don't you have issues with dust sticking and building up on the magnets and windings? Placing the oil directly on the bearing and sealing it back up is a much better method, in my opinion. It's the method I use.
Not that I've noticed, but with my method I've only ever had to oil fans once. Staypuft's method is probably best though, yeah.
staypuft
- Ribbons : 31
2021/03/24 16:49:01
Lotust251
2021/03/26 16:48:51
awesome write up but yeah a DROP of oil will do. I used RC car shock oil. works awesome
staypuft
- Ribbons : 31
2021/07/07 06:11:42
Lotust251 awesome write up but yeah a DROP of oil will do. I used RC car shock oil. works awesome
New fans still going strong. Oil didn't do it for one of the fans, but the other got quiet right away. Really depends on how far gone the bearings are.
lisidas
2022/06/28 01:39:20
Thank you for all these details. It is the time to buy a fan replacement and I am happy that I found this information. Do I need thermal paste? And are these fans the same: gpufanreplacement.com/products/evga-gtx-1080-ti-sc-fan-replacement-model-pla09215b12h I have bought from these guys before but just to be sure.
post edited by lisidas - 2022/06/28 01:41:25
kougar
- Ribbons : 22
2022/06/29 18:50:31
lisidas Thank you for all these details. It is the time to buy a fan replacement and I am happy that I found this information. Do I need thermal paste? And are these fans the same: gpufanreplacement.com/products/evga-gtx-1080-ti-sc-fan-replacement-model-pla09215b12h I have bought from these guys before but just to be sure.
You only need thermal paste if you take the heatsink itself off the card. Those fans look to be correct, yes.
cvt01
2022/07/02 12:31:08
How did you find out the part number? I need to replace a fan on my EVGA GTX 1050. Thanks
lastsamurairick
- Ribbons : 6
2022/07/03 09:53:06
Very nicely done how to. This come in handy if I need Oil my fans or replace who knows.
Intel 10900k @ 3.7 Stock EVGA Z490 Dark EVGA GEFORCE RTX 3070Ti FTW3 G SKILL TRIDENT Z ROYAL 32GB EVGA 1000G5
