beiker44
Love the CLC 280 and I do like the flow control. When I put my computer to sleep and turn on my computer later on it says "Device Not Found" when it's clearly still working. Any idea how to fix this issue so the device is found at all times? Don't know if there is any update coming to fix this but it's really annoying that I have to restart my computer to get it to work again. Thanks!!
Re: EVGA Flow Control Sleep issue!!
2018/05/17 08:25:51
make sure MB BIOS has the fan header @ 100% is the first step to prevent issues Does your system "hibernate" or Sleep ? what level of sleep have you tested ? OS ? if 10 what build ?
GObonzo
2019/05/06 04:26:41
same issue. fan ports are set correctly in BIOS. maybe 1 out of every 3 times waking up the device not found error regarding Flow Control happens. does not matter what level of sleep or hibernation, still happens. many on other threads and forums are saying it has to do with LED Sync and maybe a problem with it trying to run before the Flow Control software can get started up again. if it is such a simple issue, why the hell is EVGA not fixing it? also, neither Flow Control or Precision XOC will run my default profiles at startup. both of them revert back to a default profile at startup no matter what settings I choose. CLC 280 / 1080 Ti | all using the latest software/firware.
ASUS ROG Strix Z370-E | i7-8700K 5GHz \ ASUS Ryujin 360 | G.Skill DDR4 3200 CL14 16GB(2x 8GB) | EVGA FTW3 1080 Ti | M.2: 480GB \ SSDs: 5.25TB \ HDs: 8TB | be quiet! Dark Power Pro 11 750w | Fractal Design Vector RS \ 5x be quiet! Silent Wings 3 140mm PWM Hi-Speed | Logitech G600 \ Corsair Vengeance M95 | Corsair K70 LUX RGB | Corsair Gaming VOID 7.1 | One S Gamepad | Alienware AW3420DW | Windows 10 x64 | Lenovo IdeaPad
Dan_Shortt
2019/06/12 01:23:39
I have the same Issue on my 240, I have found that upping the cpu voltage on my OC helps, potentially something to do with voltage drop when coming out of sleep and USB devices can blip out for a second. It's worth a shot, but I still do suffer this issue sometimes, I imagine some basic software updates could help this issue. When it occurs the software often shuts down and the pump and fan revert to default which is not optimal and require manually starting them up again. Also the LED settings don't get remembered when I reboot.
Hoggle
2019/06/12 01:38:43
Dan_Shortt I have the same Issue on my 240, I have found that upping the cpu voltage on my OC helps, potentially something to do with voltage drop when coming out of sleep and USB devices can blip out for a second. It's worth a shot, but I still do suffer this issue sometimes, I imagine some basic software updates could help this issue. When it occurs the software often shuts down and the pump and fan revert to default which is not optimal and require manually starting them up again. Also the LED settings don't get remembered when I reboot.
That is odd since it’s my understanding the USB would be optional and the settings are saved to the CLC instead of Windows. It should only be the lighting that would go out and not the fans.
Hoggle
2019/06/12 01:58:23
One thing you might want to try is go into “Power Options” in settings then click “change plan settings” and “change advanced power settings” finally click “USB selective suspend setting” put to disabled. Now going into sleep mode will not turn off the USB ports.
If you would rather you can do this by going into device manager and clicking on the USB Root Hub that is connected to the CLC and unchecking the box “Allow the computer to turn off this device to save power”. But it’s harder to figure out which hub it is.
GObonzo
2020/01/12 07:23:00
changing USB settings does not help the issue. EVGA, please update your software to a more reliable state.
coolmistry
- Ribbons : 45
2020/01/12 07:42:07
GObonzo changing USB settings does not help the issue. EVGA, please update your software to a more reliable state.
'Changing USB settings does not help the issue'. What is the exactly you mean not changing or you mean software not working? Please bit more detail?
Windows 11 Home 64bits up to Dated i9 11900K 5,275 MHz (3,500 MHz) || EVGA Z590 FTW WIFI || 2 x Nvidia RTX 2080 Ti FE || 32Gb Dominator Platinum DDR3 3600mhz XMP OC 3800mhz || 500gb Samsung 980 Pro NVMe || 500gb Samsung 970 EVO and Sata M.2 (1 x SSD and 1xHHD) || EVGA CLCx 360 Cooler || EVGA Supernova 1300w X3 || EVGA Z10 Keyboard || EVGA TORQ X10 mouse ||EVGA DG 77 case || Acer Predator X35 35" 200Hz G-Sync || Logitech Z906 5.1 system sounds SPDIF|| Kaspersky Internet Security
GObonzo
2020/01/12 17:49:25
coolmistry
try reading the comments directly above mine. this is not a new thread with a new comment. this is an ongoing conversation.
coolmistry
- Ribbons : 45
2020/01/13 05:15:59
GObonzo
coolmistry
It up to you want to use software but Have a look my post here> #Post 4
