Helpful ReplyEVGA Flow Control Detecting High temperatures (Over 100C) when it is not
mmenszak
2019/12/01 14:56:53 (permalink)
I just installed a new 2700x and B450 strix over my b350 and 1700. I had the cooler before and it worked fine. Now EVGA flow control is telling me my cpu is at over 100C sometimes. Obviously this is wrong because hwinfo and other sources tell me this (and my computer hasnt blown up). What is happening now? I have reinstalled the software. Im running windows 10
mmenszak
Re: EVGA Flow Control Detecting High temperatures (Over 100C) when it is not 2019/12/01 15:16:57 (permalink)
Also my LED is very dim and I cant change the color at all. Even tho my cooler is in the usb 2.0 port
bob16314
  • Ribbons : 474
Re: EVGA Flow Control Detecting High temperatures (Over 100C) when it is not 2019/12/02 02:36:10 (permalink) ☄ Helpfulby mmenszak 2019/12/02 22:59:12
Make sure you're using Flow Control Version 2.0.9 (the latest) which is supposed to fix AM4 CPU package temperature error.
You can grab it in the EVGA Download Center in the Other Products tab -> Closed Loop Coolers.
Uninstall your current version first and restart your PC..Close all other programs running in the Task Bar and Sytem Tray (clock area) before installing.
* Corsair Obsidian 450D Mid-Tower - Airflow Edition * ASUS ROG Maximus X Hero (Wi-Fi AC) * Intel i7-8700K @ 5.2GHz * 16GB G.SKILL Trident Z 4000MHz * Crucial MX500 M.2 1TB * WD Black 500GB (x2) * Seasonic M12 II 750W * Corsair H80i V2 * EVGA GTX 760 SC * Dual-Boot Win7 Home 64-bit/Win10 Home 64-bit (Winver 1909) *
Confucius say "He who has the most guns wins"
coolmistry
  • Ribbons : 26
Re: EVGA Flow Control Detecting High temperatures (Over 100C) when it is not 2019/12/02 07:14:03 (permalink)
Where did you plug the Fan pin on your motherboard for the cooler pump?
Did you use > AIO Pump connector?
Use my Affiliate Code: RWYTPFDMCP
My Rigs
 Windows 10 Home 64bits v1909
i7 8086k @ 5200Ghz || EVGA Z370 Classifieds K || 2 x EVGA GTX 1080 Classified  || 16 gb Dominator Platinum DDR3 3200mhz XMP || 500gb Samsung 970 EVO plus NVMe || 256gb Samsung 970 EVO NVMe M.2 (3 x SSD and 1xHHD) || Killer Wireless AC1550 || EVGA CLC 280 Cooler || EVGA Supernova 1000w G2 || EVGA Z10 Keyboard || EVGA TORQ X10 mouse || EVGA DG 77 case || Acer Predator Z35 35" 160Hz G-Sync v2 Pro
 MSI Z87 X-Power
 Old Nforce 780sli
mmenszak
Re: EVGA Flow Control Detecting High temperatures (Over 100C) when it is not 2019/12/02 23:00:14 (permalink)
bob16314
You can grab it in the in the Other Products tab -> Closed Loop Coolers.
I have done that and this did not work.
coolmistry
I have done this and this did not work but it did seem to make my temps cooler for whatever reason and the brightness of the rgb is back
mmenszak
Re: EVGA Flow Control Detecting High temperatures (Over 100C) when it is not 2019/12/02 23:01:35 (permalink)
Also none of the LED sync effects seem to work
EVGATech_JoseC
EVGA Tech Support
Re: EVGA Flow Control Detecting High temperatures (Over 100C) when it is not 2019/12/05 10:29:33 (permalink)
You can also try increasing the fan speed of that header in BIOS to 100%, this typically resolves that as well. May also resolve your LED difficulties. Are you using LED Sync to change the LED lighting on the cooler? Please reach out to us at support@evga.com if the issues continue.
Hoggle
Re: EVGA Flow Control Detecting High temperatures (Over 100C) when it is not 2019/12/05 11:02:44 (permalink)
What stands out to me is the Pump Speed is saying 960RPM and we are not getting a reading for Fan Speed. Are the fans working on the CLC? Also that pump speed is very low so I would make sure the fan header you are plugging it into does not reduce the power to help the system be quiet.
