EVGA DG Tuner: No Fan Control Options
Strangis04
2018/12/11 21:47:51 (permalink)
Hi Team,
I recently downloaded and installed the DG Tuner Software for my DG-76 Case.
The product information informs users that it allows an individual to control their fan speed via the software.
However, when I open the software, I am merely allowed to control RGB functions on the case and not the fan speed.
Now, as a disclaimer, I did download directly from EVGAs website and it is the most up-to-date version.
If someone has some experience in this manner and wouldn't mind lending a hand to the new guy on the block, I'd appreciate it!
PS. I was unable to inset a third picture BUT I did check the setting tab and it did not provide an option to adjust fan controls.
Regards,
Strangis04
Strangis04
"Ales Iacta Est" - Suetonius
3 Replies Related Threads
    saunderse4
    Re: EVGA DG Tuner: No Fan Control Options 2019/01/24 20:21:06 (permalink)
    I have this exact same issue as well.  I would also love some help with this if any one knows why or has figured it out.
    Strangis04
    Re: EVGA DG Tuner: No Fan Control Options 2019/01/24 21:20:50 (permalink)
    Hi saunderse4,
    I had reached out to EVGA Customer Support Team directly after having asked this question on the forum.
    According to EVGA, DG Tuner does not have Fan Control for the DG-7 Series cases; the "Fan Control" feature is only supported on DG-8 Series cases.
    Regards,
    Strangis04
    AvGas68
    Re: EVGA DG Tuner: No Fan Control Options 2020/11/17 07:29:43 (permalink)
    Same.  Dammit.  :(
