Re: EVGA Cable Kit 8PIN EPS connector - doesn't split - can I put it in a 4 pin EPS?
2021/07/22 06:50:03
Like bob16314 said, plugging in half the 8 pin connector should be just fine if it will physically do so on your motherboard. Also check your manual, usually you only need the extra 4 pin if you're overclocking or using certain top end CPUs, you might not even need it.
