EVGA 850 G3 PSU power cable compatibility
wolf-r1
2021/07/30 10:55:29 (permalink)
I have had this PSU for a few years and need to add a video card to the system it is in. However I cannot find the 'official' power cables for the modular power supply. I have a bunch of Seasonic cables but am not sure if the pinout is industry standard or if everyone's cables are proprietary. Does anyone know if I can use the Seasonic cables or do I have to figure out where my EVGA cables are?
4 Replies Related Threads
    Re: EVGA 850 G3 PSU power cable compatibility 2021/07/30 17:46:46 (permalink)
    Find the evga cables.
    wolf-r1
    Re: EVGA 850 G3 PSU power cable compatibility 2021/07/30 19:51:57 (permalink)
    I forgot that I got an EVGA PSU with a NewEgg bundle that's got modular cables. This PSU is the 700BQ. Are the cables from that PSU compatible with the older 850?
    Alternatively is there a way to buy new cables? I can't find these cables to save my life! LOL
    Final edit:
    I answered the question on buying them:
    However it would be nice to know if the cables from the 700BQ will work.
    post edited by wolf-r1 - 2021/07/30 19:59:55
    Re: EVGA 850 G3 PSU power cable compatibility 2021/07/30 19:59:19 (permalink)
    https://www.evga.com/support/faq/FAQdetails.aspx?faqid=59698
    You can get cables by contacting evga tech support or getting custom cables from cablemod.com
    wolf-r1
    Re: EVGA 850 G3 PSU power cable compatibility 2021/07/30 20:01:36 (permalink)
    Thanks... looks like my link didn't post. I found Cablemod (dot) com and it looks like if the 700BQ doesn't work then I'll just buy some.
